Voicemail Continuous Message Retrieval
Is there a way whereby a listener can retrieve all new messages continuously without having to listen to the prompts (press 1 for next message, 2 to ????, 3 to ? etc) between each message?
I'm thinking of a typical ansaphone where the messages are played back one after the other without requiring the listener to do anything.
Alternatively is it possible to append new messages as they arrive, creating one single message file?
What about the appending bit? Is it possible to add new messages to an initial one creating a single, larger and larger message file?
This is possible.
You would need to modify the voicemail scripts in VG's \system\vm\ subdirectory.
