Pre-purchasing Concerns
We are at the final stage of purchasing VoiceGuide for our IVR needs. However, we encountered some problems during our evaluation period. Below are what we encountered:
1. VG Scripts did not load properly when the "Load Script" icon is clicked.
- Sometimes I need to click it 10 times to get the script loaded
- I notice that if I reload a script, changes made prior loading was not loaded.
The old script was running. Memory problem?
- In order for changes to take effects, I have to rename it to another file name
and loads it.
2. After a flow is setup. It runs flawlessly with the same sets of input but once in a while, it will prompt me MS VB RuntimeError. ..Input was the same but error occurs and hangs up. This doesn't look too good when it happened during our demo to the upper management level. It works again after the script is reloaded.
3. We tried the email module. The status of the email is OK, but no email was sent and no email received( no email after 1 month either, so no queue mail problem there ). SMTP setup was verified. What is the possible problem with this situation? Why the password field in the smtp setup is not masked?
Any known bugs that in the current version that we should know of? Thanks.
Also, any plans for a virtual dialer? Calling in to test our scripts cost us too. Thanks.
Which "Load Script" icon are you referring to?
When a new version of the script is saved that version will be used for new calls. existing calls will still use the version which was current at the start of the call.
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going on.
You can enable the automatic saving of the logs to files in \log\ directory as well.
Please see here for instructions on how to debug the email sending: http://voiceguide.com/forums/index.php?sho...ic=2222&hl=smtp
Hi
Well, this is not the case. After the script is saved. The flow in the system is still the flow from the previous script. I tried this by having an entire script change and saved having the same filename and the script loaded is the old script. Exiting and Reopening voiceguide won't make anything change at least 80-90% of the time.
The Blue/White button which says "Set and Run Current Script" in the script editor. This button won't do anything if VoiceGuide is running. If I terminate voiceguide and click on this button (sometimes more than once), the script loaded was not the current script shown but the script from the last session (most of the time-- 80%-90% of the time).
Good. This is not a common error, so we will try to duplicate it and post an error log here. Thanks.
Alrite. First try in the morning and it produces that error. Below gives me a VB Run time error on the first "Get Number" prompt i think.
075307.52  0 ApiMode=[TAPI]
075307.61  0 Tapi device 6 is: H323 Line
075307.61  0 Tapi device 5 is: IPCONF LINE
075307.61  0 Tapi device 4 is: LPT1T
075307.61  0 Tapi device 3 is: WAN Miniport (L2TP)
075307.61  0 Tapi device 2 is: RAS VPN Line 0
075307.61  0 Tapi device 1 is: RAS PPPoE Line0000
075307.61  0 Tapi device 0 is: Creative Modem Blaster PCI DI5633
075307.84  0 init  vgmulti ver 5.2.3063
075307.91  0 Inband Signaling Config file not specified
075308.03  0 Loading VMB data begin
075308.03  0 Loading VMB data - about to delete old entries
075308.09  0 vm    sort start on 8 entries.
075308.09  0 vm    sort end.
075308.09  0 Loading VMB data end
075309.44  0 init  clear settings on 1 devices.
075309.48  0 Initialising...
075309.48  0 init  attach vgs on 1 devices.
075309.48  0 Script Load C:\Program Files\VoiceGuide\Scripts\PROFIT\PROFIT_UPDATE_1_1.vgs
075309.83  0 init  lineopen on 1 devices.
075309.83  0 Calling .lineOpen on device 1
075310.80  0 lineOpen(0)=>
075310.80  0 Calling .GetLineHandle on LineId 0
075310.80  0 hLine=66201
075310.84  0 Calling .GetProviderInfo on LineId 0
075310.84  0 tapi  ProviderInfo: Windows Telephony Service Provider for Universal Modem Driver
075310.84  0      set provider type: PROVTYPE_MODEM
075310.84  0 Calling lineSetNumRings on lLineHandle 66201
075310.84  0 Waiting for a call...
075310.97  0 dial  start any summary:|0:idx=0|
075405.14  0 sys  cleanup Start
075405.14  0 sys  cleanup End
080751.56  0 callstate OFFERING 66150 0 4
080751.58  0 ring 1
080752.06  0 dial  start any summary:|0:hc>0|
080757.56  0 ring 2
080757.56  0 rv    clear
080757.58  0 Answer the call at 3/16/2005 8:07:57 AM
080757.58  0 lineAnswer(66150) => 66133
080757.58  0 callstate ACCEPTED 66150 0 0
080759.81  0 tapi  Reply (LineEvReply) ok 66133 0
080759.81  0 callstate CONNECTED 66150 0 0
080759.81  0 callstate CONNECTED 66150,0,0
080759.81  0 WorkingModeTAPI@Connected=
080759.81  0 WorkingModeScript@Connected=
080759.81  0 Inband detection not enabled
080759.83  0 StartLoadedVgs at 3/16/2005 8:07:59 AM, v5.2.3063
080759.83  0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}
080759.83  0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}
080759.83  0 rv    add [$RV_STARTTIME]{3/16/2005 8:07:59 AM}
080759.84  0 rv    add [$RV_DEVICEID]{0}
080759.84  0 rv    add [$RV_CIDNAME]{}
080759.84  0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
080759.84  0 rv    add [$RV_CIDNUMBER]{}
080759.86  0 timer clear
080759.86  0 [Check CID] Evaluate [$RV_CIDNUMBER]
080759.86  0 rv    replace start: [$RV_CIDNUMBER]
080759.88  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
080759.88  0 rv    replace end: []
080759.88  0 .Eval()
080759.88  0 rv    add [Check CID_Input]{}
080759.88  0 rv    add [Check CID]{}
080759.88  0 rv    add [CID_EXIST]{}
080759.89  0 Eval Expr result:[] stored in $RV[CID_EXIST]
080759.89  0 path {} not found
080759.89  0 timer clear
080759.89  0 [Get AuthID] Number Input
080759.91  0 tts generate start[Please enter your Authorization Number follow by the pound sign now. . ]
080759.92  0 tts generate wait
080801.03  0 tts  generate finish. lineCallState=CONNECTED
080801.03  0 [Get AuthID] Playing (C:\Program Files\VoiceGuide\data\tts_0_1.wav)
080801.05  0 play set playid=950593
080801.09  0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts_0_1.wav]
080801.11  0 timer clear
080801.11  0 wa(4186,95059300)
080805.31  0 play  end current play (playid=950593)
080805.31  0 ScriptEventCode 8001 iLineState=1300
080805.33  0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
080805.33  0 eng  set timer EV_TIMEOUT_REPLAYMSG time=5
080805.33  0 timer set 5  EV_TIMEOUT_REPLAYMSG
080805.88  0 dtmf 1  (66150,49,2)
080805.89  0 ScriptEventCode 49 iLineState=1301
080805.89  0 LsGetNbrsRxDigits 1
080805.89  0 [Get AuthID] Number Input 1
080805.89  0 path {1} not found
080805.89  0 timer set 10  EV_TIMEOUT_GOTOMODULE
080806.39  0 dtmf 2  (66150,50,2)
080806.41  0 ScriptEventCode 50 iLineState=1301
080806.41  0 LsGetNbrsRxDigits 2
080806.41  0 [Get AuthID] Number Input 12
080806.41  0 path {12} not found
080806.41  0 timer set 10  EV_TIMEOUT_GOTOMODULE
080807.13  0 dtmf 3  (66150,51,2)
080807.13  0 ScriptEventCode 51 iLineState=1301
080807.13  0 LsGetNbrsRxDigits 3
080807.13  0 [Get AuthID] Number Input 123
080807.13  0 path {123} not found
080807.13  0 timer set 10  EV_TIMEOUT_GOTOMODULE
080807.64  0 dtmf 4  (66150,52,2)
080807.64  0 ScriptEventCode 52 iLineState=1301
080807.64  0 LsGetNbrsRxDigits 4
080807.64  0 [Get AuthID] Number Input 1234
080807.64  0 path {1234} not found
080807.66  0 timer set 10  EV_TIMEOUT_GOTOMODULE
080808.45  0 dtmf #  (66150,35,2)
080808.47  0 ScriptEventCode 35 iLineState=1301
080808.47  0 LsGetNbrsRxDigits #
080808.47  0 timer clear
080808.47  0 rv    add [Get AuthID]{1234}
080808.47  0 path {1234} not found
080808.47  0 AddRVns [Get AuthID_PathTaken]{success}
080808.48  0 timer clear
080808.48  0 [Get PinpointID by AuthID] DB Query
080808.48  0 db    Jet mode used (To use ODBC mode specify ODBC Connect string)
080808.52  0 rv    replace start: [select PinpointID from AuthDB where AuthID='$RV[Get AuthID]';]
080808.52  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}
080808.52  0 rv    replace end: [select PinpointID from AuthDB where AuthID='1234';]
080808.52  0 db    About to execute a Retrieve type operation [select PinpointID from AuthDB where AuthID='1234';]
080808.55  0 db    [Get PinpointID by AuthID] row count=1
080808.55  0 rv    add [Get PinpointID by AuthID_RowCount]{1}
080808.55  0 db    get RecordsetGetRowsMax
080808.56  0 db    get 999 records. (row count=1)
080808.56  0 db    update RVs start
080808.56  0 db    update RVs cols=1 rows=1
080808.56  0 db    test vRetData(0, 0)=1
080808.56  0 db    test CStr(vRetData(0, 0))=1
080808.58  0 db    about to close dbDbqDatabase
080808.58  0 db    going down path [True]
080808.58  0 timer clear
080808.58  0 [AID_PINPOINT_ID] Evaluate [$RV[Get PinpointID By AuthID_1_1]]
080808.58  0 rv    replace start: [$RV[Get PinpointID By AuthID_1_1]]
080808.59  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}[Get PinpointID by AuthID_RowCount]{1}[Get PinpointID by AuthID_1_1]{1}
080808.59  0 rv    replace end: [1]
080808.59  0 .Eval(1)
080808.61  0 rv    add [AID_PINPOINT_ID_Input]{1}
080808.61  0 rv    add [AID_PINPOINT_ID]{1}
080808.61  0 rv    add [PINPOINT_ID]{1}
080808.61  0 Eval Expr result:[1] stored in $RV[PINPOINT_ID]
080808.61  0 path {1} not found
080808.63  0 timer clear
080808.63  0 [Get PIN by PinpointID] DB Query
080808.63  0 db    Jet mode used (To use ODBC mode specify ODBC Connect string)
080808.63  0 rv    replace start: [select PIN,Greetings,UserLevel,Username,Password, Email from PinpointDB where PinpointID='$RV[PINPOINT_ID]';]
080808.63  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}[Get PinpointID by AuthID_RowCount]{1}[Get PinpointID by AuthID_1_1]{1}[AID_PINPOINT_ID_Input]{1}[AID_PINPOINT_ID]{1}[PINPOINT_ID]{1}
080808.64  0 rv    replace end: [select PIN,Greetings,UserLevel,Username,Password, Email from PinpointDB where PinpointID='1';]
080808.64  0 db    About to execute a Retrieve type operation [select PIN,Greetings,UserLevel,Username,Password, Email from PinpointDB where PinpointID='1';]
080808.67  0 db    [Get PIN by PinpointID] row count=1
080808.67  0 rv    add [Get PIN by PinpointID_RowCount]{1}
080808.67  0 db    get RecordsetGetRowsMax
080808.67  0 db    get 999 records. (row count=1)
080808.67  0 db    update RVs start
080808.67  0 db    update RVs cols=6 rows=1
080808.69  0 db    test vRetData(0, 0)=
080808.69  0 db    about to close dbDbqDatabase
080808.69  0 db    going down path [True]
080808.69  0 timer clear
080808.69  0 [uSER_PIN] Evaluate [$RV[Get PIN by PinpointID_1_1]]
080808.70  0 rv    replace start: [$RV[Get PIN by PinpointID_1_1]]
080808.70  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}[Get PinpointID by AuthID_RowCount]{1}[Get PinpointID by AuthID_1_1]{1}[AID_PINPOINT_ID_Input]{1}[AID_PINPOINT_ID]{1}[PINPOINT_ID]{1}[Get PIN by PinpointID_RowCount]{1}[Get PIN by PinpointID_1_1]{}[Get PIN by PinpointID_2_1]{Hi Doctor George.}[Get PIN by PinpointID_3_1]{0}[Get PIN by PinpointID_4_1]{abcd}[Get PIN by PinpointID_5_1]{abcdefg}[Get PIN by PinpointID_6_1]{abcd.soh@integral.bz}
080808.70  0 rv    replace end: []
080808.70  0 .Eval()
080808.70  0 rv    add [uSER_PIN_Input]{}
080808.72  0 rv    add [uSER_PIN]{}
080808.72  0 Eval Expr result:[] stored in $RV[uSER_PIN]
080808.72  0 timer clear
080808.72  0 [Keypad] DB Query
080808.73  0 db    Jet mode used (To use ODBC mode specify ODBC Connect string)
080808.73  0 rv    replace start: [select KeyPad1, KeyPad2, KeyPad3, KeyPad4, KeyPad5, KeyPad6, KeyPad7, KeyPad8 from PinpointDB Where PinpointID='$RV[PINPOINT_ID]';]
080808.73  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}[Get PinpointID by AuthID_RowCount]{1}[Get PinpointID by AuthID_1_1]{1}[AID_PINPOINT_ID_Input]{1}[AID_PINPOINT_ID]{1}[PINPOINT_ID]{1}[Get PIN by PinpointID_RowCount]{1}[Get PIN by PinpointID_1_1]{}[Get PIN by PinpointID_2_1]{Hi Doctor George.}[Get PIN by PinpointID_3_1]{0}[Get PIN by PinpointID_4_1]{abcd}[Get PIN by PinpointID_5_1]{abcdefg}[Get PIN by PinpointID_6_1]{abcd.soh@integral.bz}[uSER_PIN_Input]{}[uSER_PIN]{}[uSER_PIN]{}
080808.73  0 db    About to execute a Retrieve type operation [select KeyPad1, KeyPad2, KeyPad3, KeyPad4, KeyPad5, KeyPad6, KeyPad7, KeyPad8 from PinpointDB Where PinpointID='1';]
080808.75  0 db    [Keypad] row count=1
080808.75  0 rv    add [Keypad_RowCount]{1}
080808.75  0 db    get RecordsetGetRowsMax
080808.75  0 db    get 999 records. (row count=1)
080808.75  0 db    update RVs start
080808.77  0 db    update RVs cols=8 rows=1
080808.77  0 db    test vRetData(0, 0)=Button1.REQ SNAPSHOT
080808.77  0 db    test CStr(vRetData(0, 0))=Button1.REQ SNAPSHOT
080808.77  0 db    about to close dbDbqDatabase
080808.77  0 db    going down path [True]
080808.78  0 timer clear
080808.78  0 [Populate KeyPad Variables] Running VB Script...
080808.78  0 rv    replace start (strlen>500)
080808.78  0 rv    ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\PROFIT}[$RV_STARTTIME]{3/16/2005 8:07:59 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check CID_Input]{}[Check CID]{}[CID_EXIST]{}[Get AuthID]{1234}[Get AuthID_PathTaken]{success}[Get PinpointID by AuthID_RowCount]{1}[Get PinpointID by AuthID_1_1]{1}[AID_PINPOINT_ID_Input]{1}[AID_PINPOINT_ID]{1}[PINPOINT_ID]{1}[Get PIN by PinpointID_RowCount]{1}[Get PIN by PinpointID_1_1]{}[Get PIN by PinpointID_2_1]{Hi Doctor George.}[Get PIN by PinpointID_3_1]{0}[Get PIN by PinpointID_4_1]{abcd}[Get PIN by PinpointID_5_1]{abcdefg}[Get PIN by PinpointID_6_1]{abcd.soh@integral.bz}[uSER_PIN_Input]{}[uSER_PIN]{}[uSER_PIN]{}[
eypad_RowCount]{1}[Keypad_1_1]{Button1.REQ SNAPSHOT}[Keypad_2_1]{Button2.REQ RANKING}[Keypad_3_1]{}[Keypad_4_1]{}[Keypad_5_1]{}[Keypad_6_1]{}[Keypad_7_1]{}[K
ypad_8_1]{}
080808.84  0 eng  run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_0_1.vbs" //I] copy of script in: vbs_0_1.vbs
080809.05  0 Run Script waiting. iRunWait=1 (shellid=3316, process=1112)
080809.05  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080810.03  0 timer fired EV_TIMEOUT_CHECKONSTATE
080810.03  0 ScriptEventCode 9007 iLineState=1501
080810.03  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080810.03  0 task still running (shellid=3316, process=1112)
080810.03  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080811.14  0 timer fired EV_TIMEOUT_CHECKONSTATE
080811.14  0 ScriptEventCode 9007 iLineState=1501
080811.14  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080811.14  0 task still running (shellid=3316, process=1112)
080811.14  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080812.23  0 timer fired EV_TIMEOUT_CHECKONSTATE
080812.23  0 ScriptEventCode 9007 iLineState=1501
080812.23  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080812.23  0 task still running (shellid=3316, process=1112)
080812.23  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080813.33  0 timer fired EV_TIMEOUT_CHECKONSTATE
080813.33  0 ScriptEventCode 9007 iLineState=1501
080813.33  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080813.33  0 task still running (shellid=3316, process=1112)
080813.33  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080814.42  0 timer fired EV_TIMEOUT_CHECKONSTATE
080814.42  0 ScriptEventCode 9007 iLineState=1501
080814.42  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080814.42  0 task still running (shellid=3316, process=1112)
080814.42  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080815.53  0 timer fired EV_TIMEOUT_CHECKONSTATE
080815.53  0 ScriptEventCode 9007 iLineState=1501
080815.53  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080815.53  0 task still running (shellid=3316, process=1112)
080815.53  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
080816.63  0 timer fired EV_TIMEOUT_CHECKONSTATE
080816.63  0 ScriptEventCode 9007 iLineState=1501
080816.63  0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
080816.63  0 task completed (shellid=3316, process=1112) vgm=14, iRunWait=1, iRunWait_ExeResult_NextVgm=0
080816.63  0 No information returned from program to VG (no VGRUNRESULT_0.TXT or SHLRESLT.TXT)
080816.64  0 rv    add [Hangup Time]{3/16/2005 8:08:16 AM}
080816.64  0 Hanging up call... [WaitTillFinished - next module not specified]
080816.64  0 RecSoundStop ok
080816.64  0 PlaySoundStop err=0
080816.66  0 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
080816.66  0 fnHangupCall end
080816.91  0 callstate DISCONNECTED 66150 1 0
080816.91  0 ScriptEventCode 9250 iLineState=900
080816.91  0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
080816.91  0 rv    add [Hangup Time]{3/16/2005 8:08:16 AM}
080816.92  0 Hanging up call...
080816.92  0 RecSoundStop ok
080816.92  0 PlaySoundStop err=0
080816.92  0 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
080816.92  0 fnHangupCall end
080816.94  0 callstate IDLE 66150 0 0
080816.94  0 WorkingMode@Idle=
080816.94  0 timer clear
080817.03  0 timer set 1  EV_TIMEOUT_TIMETOREINITLINE
080817.03  0 tapi  Reply (LineEvReply) ok 66116 0
080817.05  0 tapi  Reply (LineEvReply) ok 66099 0
080818.03  0 timer fired EV_TIMEOUT_TIMETOREINITLINE
080818.03  0 ScriptEventCode 9008 iLineState=900
080818.03  0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
080818.03  0 ReinitTelephony due to IDLE
080818.03  0 tapic lineDeallocateCall(MainCall:66150) 0
080818.97  0 lineOpen(0)=>
080818.97  0 Waiting for a call...
080818.97  0 LineHandle=66082
080818.97  0 timer set 3  EV_TIMEOUT_ATERIDLE_ALLOWOUT
080818.98  0 dial  start any summary:|0:rdy=0|
080822.59  0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
080822.59  0 ScriptEventCode 9013 iLineState=900
080823.38  0 dial  start any summary:|0:idx=0|
As soon as the new version of the script is saved you should see entries i th etrace log showing you that the new version of the script was loaded:
092538.81  0 Script Load C:\TestLookup.vgs
092538.81  0 Loaded Script Id 2: C:\TestLookup.vgs
Can you see after you save that the file on the hard disk was updated?
We have not come across any problems with the "Set and Run Current Script" button ourselves (and we use it all the time) an did not have any other reports of problems with it from other customers.
You can use the "View"->"Line Device Config" menu in VoiceGuide to confirm which script is currently loaded on the line.
From the trace it looks like your VBScript in the module [Populate KeyPad Variables] did not run properly. We can see that the VBScript was started OK by VoiceGuide, but
What exactly did the error say? The error message will usually give you the line number of the VBScript on which the error occurred so you can see in your script where the error is. You can also look at the file mentioned in the trace (in this case C:\Program Files\VoiceGuide\data\vbs_0_1.vbs) - and indeed you can just run this file again to reproduce the error.
If you still can't resolve it then next time this occurs please post the screenshot of the error and the vbs file in the \data\ directory which is mentioned in the VG trace at the time.
I have similar problems occaisionally with loading scripts via Designer. However, I have noticed that during development, when the scripts may have some errors (not exactly sure which ones, but paths to missing modules maybe) then the script does not load properley. Sometimes, a new script will load, but fail on first play - it will play a module, then hangup. When the module is tidied up and "clean" it loads/runs without problems.
I am using winXP-pro and latest version of VG on dialogic 5.1.1.
I suggest this maybe a symptom of "newbie" developers (like me) and not a problem for the VG-pros like the support crew! Hope this helps! +Tim+
I'd suggest you have a good look at the VoiceGuide's Debug Printout whenever you think there is something not happening the way you expect it. The trace will show you what modules were executed and what they did.
I think I know what problem was causing that. It says "Path Not Found" When I try to open a file for writing. I have the path as "TTS/xxxxx.txt" in the VBS. If I run the script independently, it gives me the same error. Somehow I am assuming it's looking for the directory name "TTS" in the "Data" folder itself where the VBS is saved. Do you know why it's causing that? I will try have the full path in there using the $RV. Hope that might solve it.
Sounds like using the full path should solve this problem.
Always use the full path. Do not rely on Windows' "current path" setting.
Thanks. The $RV[scriptPath] does the job. Didn't seem to encounter this error anymore.
Funny that after registering, most bugs just disappear. There's still a lil but nothing serious at this point. Thanks.
Registration removes the limitations that the evaluation version has. Maybe some of those limitation seem to be bugs while the evaluation version is used.
