3 Way Blind Transfer Using Vg 4.8.45
I am using Dialogic D4PCI board and an Alcatel PBX and Voice guide 4.8.47
I am able to do this when I dial :
1)Transfer to any extension. Conference from that PHONE SET, manually using the EPABX feature : Flash,0,number- on connect - Flash,3.
It shows that conference feature is very well working with my PBX.
I need to do the same automatically voice guide. where voice guide should take the call and 3 way call to some external number and wait untill the conference is finished.
It is not happening. either It disconnects the first line or puts it on hold and hangs up the call. at times it also rings back and gets into the IVR loop again.
I tried 3 way blind conference. It connects the First line and called external no. and hangs itself. But this feature TOO is working only WITHING the Intercoms, not from external incoming call.
BLIND TRANSFER is WORKING VERY FINE in my complete system. That means, PBX settings are working very fine with the Voice Guide, Dialogic and PBX.
I have the hookflash time in my PBX setting as 20 and blind transfer is working fine.
Please help.
I am repeating my requirement -
I need to process the call, put a call to external number, conference the first line, called no. and voice guide and resume to another module when call is finished. if not resuming atleast conferencing is MUST.
Please advice.
Please help -
Further to my last note :
Dialogic PBX settings : Flash 30, Pause 200. Dail before Conf !, Complete Conf !3.
3 Way Blind conference as well Announced Conf works well when originating the call from any intercom. but it gives problem when originates from any external line.
Problem in 3 Way Announced conf : It puts the first call on hold at the caller side. Does dial the external line, play the announced message, on pressing any digit does nothing. and voice guide's rings back the first call and get into the ivr again. trace is as below :
22591 5 tapie linedevstate 2048 0 0
22591 5 tapie callstate OFFERING 65605 0 4
22591 5 Answer the call
22601 5 lineAnswer(65605) => 65588
22611 5 tapie callinfo CALLEDID
22611 5 tapie callinfo ORIGIN
22611 5 tapie ring 0
23142 5 tapie callstate CONNECTED 65605,1,0
23152 5 WorkingModeTAPI=
23152 5 WorkingModeScript=
23212 5 tapi Reply 65588 0
23212 5 TimeoutClear
23222 5 [AskLanguage] Playing
23222 5 [AskLanguage] Playing (Welcome.wav)
23262 5 PlaySoundStart ok [D:\TimesIVR\Welcome.wav]
23262 5 TimeoutClear
23262 5 RunModule PLAY end
23262 5 wa(12189,62322200)
23262 5 tapie callinfo MONITORMODES
23272 5 tapie callinfo MONITORMODES
26426 5 tapie monitordigits 35 2
26436 5 LsPlayMsg [#]
26486 5 PlaySoundStop ok
26486 5 TimeoutClear
26486 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
26817 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
26817 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
26817 5 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
26817 5 [TxTo789547125_onhash] Announced Conference to 0,9891364100 (TAPI)
26827 5 fn SrSetupConferenceTapi
26827 5 [TxTo789547125_onhash] Number: 0,789547125
26827 5 lineSetupConference(65605,66014,0,0) in SrSetupConferenceTapi => 66306
29150 5 tapi Reply 66306 0
29150 5 tapie callstate CONFERENCED 65605 0 0
29160 5 tapie linedevstate 2048 0 0
29160 5 tapie callstate DIALTONE 66289 2 0
29160 5 lineDial(66289,0,789547125)
29160 5 lineDial => 65656
29170 5 tapie linedevstate 2048 0 0
29170 5 tapie callstate ONHOLDPENDCONF 66271 0 0
29170 5 tapie callstate DIALING 66289 0 0
29170 5 tapie callstate PROCEEDING 66289 0 0
29170 5 tapie callinfo CALLEDID
34107 5 tapie callstate CONNECTED 66289,1,0
34107 5 WorkingModeTAPI=SetupConferenceAnnounced
34117 5 WorkingModeScript=
34117 5 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
34127 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1
34147 5 PlaySoundStartNumbers ok
34147 5 TimeoutClear
34157 5 wa(6926,63412701)
34157 5 tapi Reply 65656 0
41198 5 wb(63412701)
41438 5 Play End line[5] (id=634127)
41438 5 LsXferPlayAnn EV_PLAY_FINISHED
41438 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
41448 5 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
41448 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1
41468 5 PlaySoundStartNumbers ok
41468 5 TimeoutClear
41478 5 wa(6926,64144801)
48478 5 Play End line[5] (id=641448)
48478 5 LsXferPlayAnn EV_PLAY_FINISHED
48488 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
48488 5 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
48498 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1
48508 5 PlaySoundStartNumbers ok
48518 5 TimeoutClear
48518 5 wa(6926,64849801)
55518 5 Play End line[5] (id=648498)
55518 5 LsXferPlayAnn EV_PLAY_FINISHED
55518 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
55528 5 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
55528 5 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1
55548 5 PlaySoundStartNumbers ok
55548 5 TimeoutClear
55548 5 wa(6926,65552801)
57751 5 tapie monitordigits 49 2
57751 5 LsXferPlayAnn [1]
57761 5 TimeoutSet 1 EV_PLAY_FINISHED
57811 5 PlaySoundStop ok
58713 5 Timer fired EV_PLAY_FINISHED
58713 5 LsXferPlayAnn EV_PLAY_FINISHED
58713 5 lineCompleteTransfer(65605,66289,0) (hCall_OnHoldPendConf=66271) in LsXferPlayAnn/SetupConference => LINEERR_INVALCALLHANDLE [80000018]
58723 5 ERROR: lineCompleteTransfer LINEERR_INVALCALLHANDLE [80000018]
58723 5 lineAddToConference(66271,66289) in LsXferPlayAnn => 65571
58723 5 TimeoutSet 600 EV_TIMEOUT_HANGUP
59153 5 tapi Reply 65571 0
59153 5 tapie callstate CONFERENCED 66271 0 0
59163 5 tapie callstate CONFERENCED 66289 0 0
59163 5 tapie callstate CONNECTED 66271,1,0
59163 5 WorkingModeTAPI=
59163 5 WorkingModeScript=
59173 5 hConsultCall=66289 and strWorkingModeTAPI not defined
69658 5 tapie monitordigits 53 2
69658 5 LsXferPlayAnn [5]
69668 5 TimeoutSet 1 EV_PLAY_FINISHED
69668 5 PlaySoundStop ok
70870 5 Timer fired EV_PLAY_FINISHED
70870 5 LsXferPlayAnn EV_PLAY_FINISHED
70870 5 ERROR: lineDrop(In Call) 66135
70880 5 TimeoutSet 1 EV_TIMEOUT_HANGUP
70880 5 tapi Reply 66135 LINEERR_OPERATIONFAILED [80000048]
70910 5 tapie linedevstate 2048 0 0
70920 5 tapi Reply 66186 0
71882 5 Timer fired EV_TIMEOUT_HANGUP
71882 5 LsXferPlayAnn EV_TIMEOUT_HANGUP
71882 5 PlaySoundStop ok
71882 5 Hanging up call...
71882 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
71892 5 PlaySoundStop ok
71892 5 fnHangupCall end
71902 5 tapie linedevstate 2048 0 0
71902 5 tapie callstate IDLE 65605 0 0
71902 5 WorkingMode@Idle=DropBothCallsAndHangUp
71912 5 TimeoutClear
71912 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
71912 5 tapie linedevstate 2048 0 0
71922 5 tapie callstate IDLE 66271 0 0
71922 5 WorkingMode@Idle=DropBothCallsAndHangUp
71922 5 TimeoutClear
71922 5 WriteToLogFiles not called in LineEvCallState LogEntryWritten=1
71922 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
71932 5 tapi Reply 66118 0
72903 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
72903 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
72903 5 Initialise telephony (due to IDLE)
72913 5 tapic lineDeallocateCall(hConsultCall_OriginalCallHandleBeforeTransferAttempted:65605) 0
72923 5 tapic lineDeallocateCall(hConfCall:66271) 0
72923 5 tapic lineDeallocateCall(MainCall:65605) LINEERR_INVALCALLHANDLE [80000018]
73113 5 Waiting for a call...
73113 5 hLine=66067
73123 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
73194 5 tapie linedevstate 2048 0 0
73204 5 tapie callstate OFFERING 66323 0 4
73214 5 Answer the call
73224 5 lineAnswer(66323) => 66340
73224 5 tapie callinfo CALLEDID
73224 5 tapie callinfo ORIGIN
73234 5 tapie ring 0
73774 5 tapie callstate CONNECTED 66323,1,0
73774 5 WorkingModeTAPI=
73774 5 WorkingModeScript=
73844 5 tapi Reply 66340 0
73844 5 tapie callinfo MONITORMODES
73854 5 TimeoutClear
73854 5 [AskLanguage] Playing
73864 5 [AskLanguage] Playing (Welcome.wav)
73905 5 PlaySoundStart ok [D:\TimesIVR\Welcome.wav]
73905 5 TimeoutClear
73915 5 RunModule PLAY end
73915 5 wa(12189,67386400)
73915 5 tapie callinfo MONITORMODES
Problem in 3 Way Blind conf : It stucks the first call by putting it on hold at the caller side. Does not dial the external line. and does not even Hangs the first call. and voice guide's called line keeps on saying 'hangin up call'. trace is as below for this :
62592 8 tapie linedevstate 2048 0 0
62592 8 tapie callstate OFFERING 66066 0 4
62602 8 Answer the call
62612 8 lineAnswer(66066) => 66083
62622 8 tapie callinfo CALLEDID
62622 8 tapie callinfo ORIGIN
62622 8 tapie ring 0
63153 8 tapie callstate CONNECTED 66066,1,0
63153 8 WorkingModeTAPI=
63153 8 WorkingModeScript=
63213 8 tapi Reply 66083 0
63213 8 tapie callinfo MONITORMODES
63223 8 TimeoutClear
63223 8 [AskLanguage] Playing
63223 8 [AskLanguage] Playing (Welcome.wav)
63273 8 PlaySoundStart ok [D:\TimesIVR\Welcome.wav]
63273 8 TimeoutClear
63283 8 RunModule PLAY end
63283 8 wa(12189,96322300)
63283 8 tapie callinfo MONITORMODES
71134 8 tapie monitordigits 35 2
71134 8 LsPlayMsg [#]
71194 8 PlaySoundStop ok
71194 8 TimeoutClear
71194 8 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
71595 8 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
71595 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
71595 8 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
71595 8 [TxTo789547125_onhash] Blind Conference to 0,789547125 (TAPI)
71605 8 fn SrSetupConferenceTapi
71605 8 [TxTo789547125_onhash] Number: 0,789547125
71625 8 lineSetupConference(66066,66296,0,0) in SrSetupConferenceTapi => 66031
73948 8 tapi Reply 66031 0
73948 8 tapie callstate CONFERENCED 66066 0 0
73948 8 tapie linedevstate 2048 0 0
73948 8 tapie callstate DIALTONE 66125 2 0
73948 8 lineDial(66125,0,789547125)
73958 8 lineDial => 66108
73958 8 tapie linedevstate 2048 0 0
73958 8 tapie callstate ONHOLDPENDCONF 66544 0 0
73958 8 tapie callstate DIALING 66125 0 0
73968 8 tapie callstate PROCEEDING 66125 0 0
73968 8 tapie callinfo CALLEDID
78885 8 tapie callstate CONNECTED 66125,1,0
78895 8 WorkingModeTAPI=SetupConferenceBlind
78895 8 WorkingModeScript=
78905 8 lineCompleteTransfer(66066,66125,0) in LineEvCallState/SetupConference => LINEERR_INVALCALLHANDLE [80000018]
78915 8 lineAddToConference(66544,66125) in LineEvCallState => 66484
78915 8 tapi Reply 66108 0
78915 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
79276 8 Timer fired EV_TIMEOUT_HANGUP
79276 8 LsXferStart EV_TIMEOUT_HANGUP
79276 8 PlaySoundStop ok
79286 8 Hanging up call...
79286 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
79286 8 PlaySoundStop ok
79286 8 fnHangupCall end
79296 8 tapi Reply 66484 0
79296 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
79306 8 tapi Reply 66467 LINEERR_RESOURCEUNAVAIL [8000004B]
79306 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
79696 8 Timer fired EV_TIMEOUT_HANGUP
79696 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
79696 8 PlaySoundStop ok
79696 8 Hanging up call...
79706 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
79706 8 PlaySoundStop ok
79706 8 fnHangupCall end
79756 8 tapie linedevstate 2048 0 0
79756 8 tapie callstate IDLE 66066 0 0
79756 8 WorkingMode@Idle=HangupCallAsap
79766 8 TimeoutClear
79776 8 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
79776 8 tapi Reply 65750 0
79786 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
80117 8 Timer fired EV_TIMEOUT_HANGUP
80117 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
80117 8 PlaySoundStop ok
80117 8 Hanging up call...
80127 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
80127 8 PlaySoundStop ok
80127 8 fnHangupCall end
80137 8 tapi Reply 65767 LINEERR_INVALCALLSTATE [8000001C]
80137 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
80538 8 Timer fired EV_TIMEOUT_HANGUP
80538 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
80548 8 PlaySoundStop ok
80548 8 Hanging up call...
80548 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
80558 8 PlaySoundStop ok
80558 8 fnHangupCall end
80568 8 tapi Reply 65835 LINEERR_INVALCALLSTATE [8000001C]
80568 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
80958 8 Timer fired EV_TIMEOUT_HANGUP
80968 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
80978 8 PlaySoundStop ok
80988 8 Hanging up call...
80988 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
80998 8 PlaySoundStop ok
81008 8 fnHangupCall end
81018 8 tapi Reply 65818 LINEERR_INVALCALLSTATE [8000001C]
81028 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
81419 8 Timer fired EV_TIMEOUT_HANGUP
81419 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
81429 8 PlaySoundStop ok
81429 8 Hanging up call...
81439 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
81439 8 PlaySoundStop ok
81449 8 fnHangupCall end
81459 8 tapi Reply 66433 LINEERR_INVALCALLSTATE [8000001C]
81459 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
81849 8 Timer fired EV_TIMEOUT_HANGUP
81849 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
81849 8 PlaySoundStop ok
81859 8 Hanging up call...
81859 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
81859 8 PlaySoundStop ok
81869 8 fnHangupCall end
81869 8 tapi Reply 66330 LINEERR_INVALCALLSTATE [8000001C]
81879 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
82270 8 Timer fired EV_TIMEOUT_HANGUP
82270 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
82270 8 PlaySoundStop ok
82280 8 Hanging up call...
82280 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
82280 8 PlaySoundStop ok
82290 8 fnHangupCall end
82290 8 tapi Reply 65665 LINEERR_INVALCALLSTATE [8000001C]
82290 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
82691 8 Timer fired EV_TIMEOUT_HANGUP
82691 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
82701 8 PlaySoundStop ok
82711 8 Hanging up call...
82711 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
82721 8 PlaySoundStop ok
82721 8 fnHangupCall end
82731 8 tapi Reply 66450 LINEERR_INVALCALLSTATE [8000001C]
82741 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
83131 8 Timer fired EV_TIMEOUT_HANGUP
83131 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
83131 8 PlaySoundStop ok
83131 8 Hanging up call...
83141 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
83141 8 PlaySoundStop ok
83151 8 fnHangupCall end
83151 8 tapi Reply 65648 LINEERR_INVALCALLSTATE [8000001C]
83151 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
83652 8 Timer fired EV_TIMEOUT_HANGUP
83662 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
83672 8 PlaySoundStop ok
83672 8 Hanging up call...
83682 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
83692 8 PlaySoundStop ok
83702 8 fnHangupCall end
83712 8 tapi Reply 65699 LINEERR_INVALCALLSTATE [8000001C]
83712 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
84103 8 Timer fired EV_TIMEOUT_HANGUP
84103 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
84103 8 PlaySoundStop ok
84103 8 Hanging up call...
84113 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
84123 8 PlaySoundStop ok
84133 8 fnHangupCall end
84133 8 tapi Reply 65682 LINEERR_INVALCALLSTATE [8000001C]
84133 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
84533 8 Timer fired EV_TIMEOUT_HANGUP
84533 8 LsAwaitingCalls EV_TIMEOUT_HANGUP
84533 8 PlaySoundStop ok
84543 8 Hanging up call...
84543 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
84543 8 PlaySoundStop ok
84553 8 fnHangupCall end
84563 8 tapi Reply 66228 LINEERR_INVALCALLSTATE [8000001C]
84563 8 TimeoutSet 0.4 EV_TIMEOUT_HANGUP
Please help.
Some changes to the way in which conference calls are established were made in v4.9.0 of VoiceGuide. Please download that version and try the transfers again.
