Odbc--call Failed.(sql Server 2k)
Hi Admin,
I have using Query database Module with SQL Server Database and I declared odbc Connect string like Help (Database Query). I also declared DNS with the same DNS name.
Please view this attachment and help me.
Thanks,
Trace Log:
104924.89 0 callstate OFFERING 65979 0 4
104924.89 0 Answer the call at 3/7/2005 10:49:24 AM
104924.89 0 lineAnswer(65979) => 65962
104924.89 0 ring 1
104924.91 0 callstate ACCEPTED 65979 0 0
104928.05 0 tapi Reply (LineEvReply) ok 65962 0
104928.05 0 callstate CONNECTED 65979 0 0
104928.05 0 callstate CONNECTED 65979,0,0
104928.06 0 WorkingModeTAPI@Connected=
104928.06 0 WorkingModeScript@Connected=
104928.06 0 Inband detection not enabled
104928.08 0 StartLoadedVgs at 3/7/2005 10:49:28 AM
104928.08 0 AddRVns [scriptsPath]{C:\Tra_cuu_TK\DienThoai\}
104928.08 0 AddRVns [scriptPath]{C:\Tra_cuu_TK\DienThoai}
104928.09 0 rv add [$RV_STARTTIME]{3/7/2005 10:49:28 AM}
104928.09 0 rv add [$RV_DEVICEID]{0}
104928.11 0 rv add [$RV_CIDNAME]{}
104928.11 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
104928.13 0 rv add [$RV_CIDNUMBER]{}
104928.13 0 timer clear
104928.17 0 [inputCC] Number Input
104928.22 0 [inputCC] Playing (Record\Input_cc.wav)
104928.27 0 play set playid=726828
104928.63 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_cc.wav]
104928.67 0 timer clear
104928.72 0 wa(19543,72682800)
104929.84 0 dtmf 1 (65979,49,2)
104929.89 0 ScriptEventCode 49 iLineState=1300
104929.94 0 LsGetNbrsPlayWelcMsg 1
104930.06 0 PlaySoundStop err=0
104930.11 0 [inputCC] Number Input 1
104930.16 0 path {1} not found
104930.20 0 ScriptEventCode 35 iLineState=1301
104930.25 0 LsGetNbrsRxDigits #
104930.30 0 timer clear
104930.34 0 rv add [inputCC]{1}
104930.39 0 path {1} not found
104930.44 0 AddRVns [inputCC_PathTaken]{success}
104930.48 0 timer clear
104930.53 0 [input_Nhom_LH] Number Input
104930.58 0 [input_Nhom_LH] Playing (Record\Input_Nhom_LH.wav)
104930.63 0 play set playid=729187
104930.98 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_Nhom_LH.wav]
104931.03 0 timer clear
104931.08 0 wa(23302,72918700)
104932.83 0 dtmf 8 (65979,56,2)
104932.88 0 ScriptEventCode 56 iLineState=1300
104932.92 0 LsGetNbrsPlayWelcMsg 8
104933.05 0 PlaySoundStop err=0
104933.09 0 [input_Nhom_LH] Number Input 8
104933.14 0 path {8} not found
104933.19 0 timer set 10 EV_TIMEOUT_GOTOMODULE
104933.23 0 dtmf # (65979,35,2)
104933.28 0 ScriptEventCode 35 iLineState=1301
104933.33 0 LsGetNbrsRxDigits #
104933.38 0 timer clear
104933.42 0 rv add [input_Nhom_LH]{8}
104933.47 0 path {8} not found
104933.52 0 AddRVns [input_Nhom_LH_PathTaken]{success}
104933.56 0 timer clear
104933.61 0 [input_Ten_LH] Number Input
104933.66 0 rv replace start: [Record\$RV[input_Nhom_LH].wav]
104933.70 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 10:49:28 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
104933.75 0 rv replace end: [Record\8.wav]
104933.78 0 [input_Ten_LH] Playing (Record\8.wav)
104933.83 0 play set playid=732390
104934.19 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\8.wav]
104934.23 0 timer clear
104934.28 0 wa(11273,73239000)
104935.45 0 dtmf 1 (65979,49,2)
104935.50 0 ScriptEventCode 49 iLineState=1300
104935.55 0 LsGetNbrsPlayWelcMsg 1
104935.67 0 PlaySoundStop err=0
104935.72 0 [input_Ten_LH] Number Input 1
104935.77 0 path {1} not found
104935.81 0 timer set 10 EV_TIMEOUT_GOTOMODULE
104935.86 0 dtmf # (65979,35,2)
104935.91 0 ScriptEventCode 35 iLineState=1301
104935.95 0 LsGetNbrsRxDigits #
104936.00 0 timer clear
104936.05 0 rv add [input_Ten_LH]{1}
104936.09 0 path {1} not found
104936.14 0 AddRVns [input_Ten_LH_PathTaken]{success}
104936.19 0 timer clear
104936.23 0 [inputSoTK] Number Input
104936.28 0 [inputSoTK] Playing (Record\Input_SoTK.wav)
104936.33 0 play set playid=734890
104936.67 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_SoTK.wav]
104936.72 0 timer clear
104936.77 0 wa(6512,73489000)
104937.73 0 dtmf 1 (65979,49,2)
104937.78 0 ScriptEventCode 49 iLineState=1300
104937.83 0 LsGetNbrsPlayWelcMsg 1
104937.95 0 PlaySoundStop err=0
104938.00 0 [inputSoTK] Number Input 1
104938.05 0 path {1} not found
104938.09 0 timer set 10 EV_TIMEOUT_GOTOMODULE
104938.27 0 dtmf # (65979,35,2)
104938.31 0 ScriptEventCode 35 iLineState=1301
104938.36 0 LsGetNbrsRxDigits #
104938.41 0 timer clear
104938.45 0 rv add [inputSoTK]{1}
104938.50 0 path {1} not found
104938.55 0 AddRVns [inputSoTK_PathTaken]{success}
104938.59 0 timer clear
104938.64 0 [iF] Evaluate [$RV[inputCC]]
104938.69 0 rv replace start: [$RV[inputCC]]
104938.73 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 10:49:28 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
put_Nhom_LH_PathTaken]{success}[input_Ten_LH]{1}[input_Ten_LH_PathTaken]{success
[inputSoTK]{1}[inputSoTK_PathTaken]{success}
104938.78 0 rv replace end: [1]
104938.83 0 .Eval(1)
104938.88 0 AddRVns [iF_Input]{1}
104938.92 0 AddRVns [iF]{1}
104938.97 0 Eval Expr result:[1]
104939.02 0 timer clear
104939.06 0 [ccBienHoa] DB Query
104939.11 0 db ODBC mode used
104939.59 0 rv replace start (strlen>500)
104939.64 0 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 10:49:28 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
[inputSoTK]{1}[inputSoTK_PathTaken]{success}[iF_Input]{1}[iF]{1}
104939.67 0 db About to execute a Retrieve type operation [select Pass_Num,bosung_GT from DTokhaiMD_1 where SoTK=1 and Ma_LH= IIf(8=1,'NDT', IIf(8=2,'NGC', IIf(8=3,'NKD', IIf(8=4,'NSX', IIf(8=5,'NTA', IIf(8=6,'NDT', IIf(8=7,'XGC', IIf(8=8,'XKD', IIf(8=9,'XSX','XTA')))))))))+ IIf(1=1,'01',IIf(1=2,'02', IIf(1=3,'03',IIf(1=4,'04', IIf(1=5,'05',IIf(1=6,'06', IIf(1=7,'07',IIf(1=8,'08', IIf(1=9,'09',1)))))))));]
104939.78 0 OpenRecordset: 3146:ODBC--call failed.
104939.83 0 path {0} not found
104939.88 0 path {} not found
104939.92 0 timer clear
104939.97 0 [Error_SoTK] Playing
104940.02 0 [Error_SoTK] Playing (Record\Error_SoTK.wav)
104940.06 0 play set playid=738625
104940.41 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Error_SoTK.wav]
104940.45 0 timer clear
104940.50 0 RunModule PLAY end
104940.55 0 wa(7264,73862500)
104942.33 0 dtmf # (65979,35,2)
104942.38 0 ScriptEventCode 35 iLineState=1100
104942.42 0 LsPlayMsg #
104942.47 0 path {#} not found
104944.16 0 btn Hangup on line 0
104944.20 0 ScriptEventCode 9001 iLineState=1100
104944.25 0 LsPlayMsg EV_TIMEOUT_HANGUP
104944.30 0 rv add [Hangup Time]{3/7/2005 10:49:44 AM}
104944.34 0 Hanging up call...
104944.39 0 RecSoundStop ok
104944.53 0 PlaySoundStop err=0
104944.58 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104944.63 0 fnHangupCall end
104945.22 0 callstate DISCONNECTED 65979 1 0
104945.27 0 ScriptEventCode 9250 iLineState=900
104945.31 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
104945.36 0 rv add [Hangup Time]{3/7/2005 10:49:45 AM}
104945.41 0 Hanging up call...
104945.45 0 RecSoundStop ok
104945.50 0 PlaySoundStop err=0
104945.55 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104945.59 0 fnHangupCall end
104945.64 0 callstate IDLE 65979 0 0
104945.69 0 WorkingMode@Idle=
104945.73 0 timer clear
104945.78 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104945.83 0 tapi Reply (LineEvReply) ok 65945 0
104945.88 0 tapi Reply (LineEvReply) ok 65928 0
104946.91 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
104946.94 0 ScriptEventCode 9008 iLineState=900
104946.98 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104947.03 0 ReinitTelephony due to IDLE
104947.09 0 tapic lineDeallocateCall(MainCall:65979) 0
104947.14 0 lineOpen(0)=>
104947.19 0 Waiting for a call...
104947.23 0 LineHandle=65911
104947.30 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104948.08 0 dial start any summary:|0:rdy=0|
104949.13 0 dial start any summary:|0:rdy=0|
104950.23 0 dial start any summary:|0:rdy=0|
104951.22 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104951.33 0 ScriptEventCode 9013 iLineState=900
105017.41 0 sys cleanup Start
105017.59 0 sys cleanup End
110620.63 0 callstate OFFERING 65860 0 4
110620.63 0 Answer the call at 3/7/2005 11:06:20 AM
110620.63 0 lineAnswer(65860) => 65843
110620.63 0 ring 1
110620.64 0 callstate ACCEPTED 65860 0 0
110623.77 0 tapi Reply (LineEvReply) ok 65843 0
110623.78 0 callstate CONNECTED 65860 0 0
110623.78 0 callstate CONNECTED 65860,0,0
110623.78 0 WorkingModeTAPI@Connected=
110623.78 0 WorkingModeScript@Connected=
110623.78 0 Inband detection not enabled
110623.78 0 StartLoadedVgs at 3/7/2005 11:06:23 AM
110623.78 0 AddRVns [scriptsPath]{C:\Tra_cuu_TK\DienThoai\}
110623.78 0 AddRVns [scriptPath]{C:\Tra_cuu_TK\DienThoai}
110623.78 0 rv add [$RV_STARTTIME]{3/7/2005 11:06:23 AM}
110623.78 0 rv add [$RV_DEVICEID]{0}
110623.78 0 rv add [$RV_CIDNAME]{}
110623.78 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
110623.78 0 rv add [$RV_CIDNUMBER]{}
110623.78 0 timer clear
110623.80 0 [inputCC] Number Input
110623.80 0 [inputCC] Playing (Record\Input_cc.wav)
110623.80 0 play set playid=742359
110624.09 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_cc.wav]
110624.09 0 timer clear
110624.09 0 wa(19543,74235900)
110643.70 0 wb(74235900)
110643.77 0 play end current play (playid=742359)
110643.78 0 ScriptEventCode 8001 iLineState=1300
110643.78 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
110643.78 0 timer set 10 EV_TIMEOUT_HANGUP
110643.78 0 timer set 10 EV_TIMEOUT_GOTOMODULE
110654.61 0 timer fired EV_TIMEOUT_GOTOMODULE
110654.61 0 ScriptEventCode 9002 iLineState=1301
110654.61 0 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
110654.61 0 rv add [inputCC]{}
110654.61 0 AddRVns [inputCC_PathTaken]{timeout}
110654.61 0 timer clear
110654.61 0 [Goodbye] Playing
110654.61 0 [Goodbye] Playing (Record\goodbye.wav)
110654.61 0 play set playid=773171
110654.91 0 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\goodbye.wav]
110654.91 0 timer clear
110654.91 0 RunModule PLAY end
110654.91 0 wa(3254,77317100)
110658.20 0 wb(77317100)
110658.30 0 play end current play (playid=773171)
110658.30 0 ScriptEventCode 8001 iLineState=1100
110658.30 0 LsPlayMsg EV_PLAY_FINISHED
110658.30 0 timer set 10 EV_TIMEOUT_HANGUP
110658.30 0 timer set 0 EV_TIMEOUT_GOTOMODULE
110658.30 0 ScriptEventCode 9002 iLineState=1101
110658.30 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
110658.30 0 timer clear
110658.30 0 rv add [Hangup Time]{3/7/2005 11:06:58 AM}
110658.30 0 Hanging up call... [Hangup Module]
110658.31 0 RecSoundStop ok
110658.31 0 PlaySoundStop err=0
110658.31 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110658.31 0 fnHangupCall end
110658.92 0 callstate DISCONNECTED 65860 1 0
110658.92 0 ScriptEventCode 9250 iLineState=900
110658.92 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
110658.92 0 rv add [Hangup Time]{3/7/2005 11:06:58 AM}
110658.92 0 Hanging up call...
110658.94 0 RecSoundStop ok
110658.94 0 PlaySoundStop err=0
110658.94 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110658.94 0 fnHangupCall end
110658.94 0 callstate IDLE 65860 0 0
110658.94 0 WorkingMode@Idle=
110658.94 0 timer clear
110658.95 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
110658.95 0 tapi Reply (LineEvReply) ok 65826 0
110658.95 0 tapi Reply (LineEvReply) ok 65809 0
110659.94 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
110659.94 0 ScriptEventCode 9008 iLineState=900
110659.94 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
110659.94 0 ReinitTelephony due to IDLE
110659.94 0 tapic lineDeallocateCall(MainCall:65860) 0
110659.95 0 lineOpen(0)=>
110659.95 0 Waiting for a call...
110659.95 0 LineHandle=65792
110659.95 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
110700.09 0 dial start any summary:|0:rdy=0|
110701.09 0 dial start any summary:|0:rdy=0|
110702.09 0 dial start any summary:|0:rdy=0|
110703.09 0 dial start any summary:|0:rdy=0|
110703.23 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
110703.23 0 ScriptEventCode 9013 iLineState=900
TCTT_TK.vgs
Your SQL query is pretty complex:
select Pass_Num,bosung_GT from DTokhaiMD_1 where SoTK=$RV[inputSoTK] and Ma_LH= IIf($RV[input_Nhom_LH]=1,'NDT', IIf($RV[input_Nhom_LH]=2,'NGC', IIf($RV[input_Nhom_LH]=3,'NKD', IIf($RV[input_Nhom_LH]=4,'NSX', IIf($RV[input_Nhom_LH]=5,'NTA', IIf($RV[input_Nhom_LH]=6,'NDT', IIf($RV[input_Nhom_LH]=7,'XGC', IIf($RV[input_Nhom_LH]=8,'XKD', IIf($RV[input_Nhom_LH]=9,'XSX','XTA')))))))))+ IIf($RV[input_Ten_LH]=1,'01',IIf($RV[input_Ten_LH]=2,'02', IIf($RV[input_Ten_LH]=3,'03',IIf($RV[input_Ten_LH]=4,'04', IIf($RV[input_Ten_LH]=5,'05',IIf($RV[input_Ten_LH]=6,'06', IIf($RV[input_Ten_LH]=7,'07',IIf($RV[input_Ten_LH]=8,'08', IIf($RV[input_Ten_LH]=9,'09',$RV[input_Ten_LH])))))))));
what happens when you try a simple SQL query, eg:
select * from DTokhaiMD_1
(I assume that DTokhaiMD_1 is a valid table name)
I already try export Sql database on Access database (.mdb) and It's success (including ODBC and direct .mdb)
Pls help me.
Thanks.
What happens when you try a simple SQL query on the database that you have a problems with using?
eg:
On SQL Server 2000:
- Database name: TCTK_BienHoa (table DtoKhaiMD, DToKhaiMD_1, ...)
- DNS name: ccBienHoa (with default database name: TCTK_BienHoa, with true rules user:"sa", pass:"")
- SQL Server still running.
Lately, I have exported SQL database on Access database and setup DSN again.
I run VG by 2 method:
1. use file ccBienHoa.mdb
2. use ODBC (data source is Microsoft Access) with name is: ccBienHoa
All's success.
Trace Log:
150051.06 6 tapi Reply (LineEvReply) ok 65621 0
150051.06 6 callstate CONNECTED 65638 0 0
150051.06 6 callstate CONNECTED 65638,0,0
150051.06 6 WorkingModeTAPI@Connected=
150051.06 6 WorkingModeScript@Connected=
150051.06 6 Inband detection not enabled
150051.06 6 StartLoadedVgs at 3/7/2005 3:00:51 PM
150051.08 6 AddRVns [scriptsPath]{C:\Tra_cuu_TK\DienThoai\}
150051.08 6 AddRVns [scriptPath]{C:\Tra_cuu_TK\DienThoai}
150051.08 6 rv add [$RV_STARTTIME]{3/7/2005 3:00:51 PM}
150051.08 6 rv add [$RV_DEVICEID]{6}
150051.09 6 rv add [$RV_CIDNAME]{}
150051.09 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
150051.09 6 rv add [$RV_CIDNUMBER]{}
150051.11 6 timer clear
150051.11 6 [inputCC] Number Input
150051.11 6 [inputCC] Playing (Record\Input_cc.wav)
150051.13 6 play set playid=716703
150051.52 6 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_cc.wav]
150051.52 6 timer clear
150051.55 6 wa(19543,71670300)
150052.28 6 dtmf 1 (65638,49,2)
150052.30 6 ScriptEventCode 49 iLineState=1300
150052.33 6 LsGetNbrsPlayWelcMsg 1
150052.44 6 PlaySoundStop err=0
150052.47 6 [inputCC] Number Input 1
150052.48 6 path {1} not found
150052.52 6 ScriptEventCode 35 iLineState=1301
150052.55 6 LsGetNbrsRxDigits #
150052.58 6 timer clear
150052.61 6 rv add [inputCC]{1}
150052.63 6 path {1} not found
150052.66 6 AddRVns [inputCC_PathTaken]{success}
150052.72 6 timer clear
150052.73 6 [input_Nhom_LH] Number Input
150052.77 6 [input_Nhom_LH] Playing (Record\Input_Nhom_LH.wav)
150052.80 6 play set playid=718375
150053.13 6 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_Nhom_LH.wav]
150053.16 6 timer clear
150053.17 6 wa(23302,71837500)
150054.39 6 dtmf 8 (65638,56,2)
150054.42 6 ScriptEventCode 56 iLineState=1300
150054.45 6 LsGetNbrsPlayWelcMsg 8
150054.58 6 PlaySoundStop err=0
150054.61 6 [input_Nhom_LH] Number Input 8
150054.63 6 path {8} not found
150054.66 6 timer set 10 EV_TIMEOUT_GOTOMODULE
150054.80 6 dtmf # (65638,35,2)
150054.83 6 ScriptEventCode 35 iLineState=1301
150054.84 6 LsGetNbrsRxDigits #
150054.88 6 timer clear
150054.91 6 rv add [input_Nhom_LH]{8}
150054.92 6 path {8} not found
150054.95 6 AddRVns [input_Nhom_LH_PathTaken]{success}
150055.02 6 timer clear
150055.03 6 [input_Ten_LH] Number Input
150055.06 6 rv replace start: [Record\$RV[input_Nhom_LH].wav]
150055.09 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 3:00:51 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
150055.11 6 rv replace end: [Record\8.wav]
150055.14 6 [input_Ten_LH] Playing (Record\8.wav)
150055.17 6 play set playid=720750
150055.50 6 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\8.wav]
150055.52 6 timer clear
150055.55 6 wa(11273,72075000)
150056.88 6 dtmf 1 (65638,49,2)
150056.91 6 ScriptEventCode 49 iLineState=1300
150056.92 6 LsGetNbrsPlayWelcMsg 1
150057.03 6 PlaySoundStop err=0
150057.06 6 [input_Ten_LH] Number Input 1
150057.09 6 path {1} not found
150057.13 6 timer set 10 EV_TIMEOUT_GOTOMODULE
150057.34 6 dtmf # (65638,35,2)
150057.36 6 ScriptEventCode 35 iLineState=1301
150057.39 6 LsGetNbrsRxDigits #
150057.42 6 timer clear
150057.47 6 rv add [input_Ten_LH]{1}
150057.50 6 path {1} not found
150057.53 6 AddRVns [input_Ten_LH_PathTaken]{success}
150057.58 6 timer clear
150057.59 6 [inputSoTK] Number Input
150057.63 6 [inputSoTK] Playing (Record\Input_SoTK.wav)
150057.67 6 play set playid=723250
150058.00 6 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\Input_SoTK.wav]
150058.03 6 timer clear
150058.05 6 wa(6512,72325000)
150059.17 6 dtmf 1 (65638,49,2)
150059.19 6 ScriptEventCode 49 iLineState=1300
150059.22 6 LsGetNbrsPlayWelcMsg 1
150059.33 6 PlaySoundStop err=0
150059.36 6 [inputSoTK] Number Input 1
150059.38 6 path {1} not found
150059.41 6 timer set 10 EV_TIMEOUT_GOTOMODULE
150059.61 6 dtmf # (65638,35,2)
150059.64 6 ScriptEventCode 35 iLineState=1301
150059.67 6 LsGetNbrsRxDigits #
150059.70 6 timer clear
150059.72 6 rv add [inputSoTK]{1}
150059.75 6 path {1} not found
150059.78 6 AddRVns [inputSoTK_PathTaken]{success}
150059.83 6 timer clear
150059.84 6 [iF] Evaluate [$RV[inputCC]]
150059.88 6 rv replace start: [$RV[inputCC]]
150059.91 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 3:00:51 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
150059.94 6 rv replace end: [1]
150059.95 6 .Eval(1)
150059.98 6 AddRVns [iF_Input]{1}
150100.02 6 AddRVns [iF]{1}
150100.05 6 Eval Expr result:[1]
150100.09 6 timer clear
150100.11 6 [ccBienHoa] DB Query
150100.16 6 db ODBC mode used
150100.23 6 rv replace start (strlen>500)
150100.27 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 3:00:51 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
150100.30 6 db About to execute a Retrieve type operation [select Pass_Num,bosung_GT from DTokhaiMD_1 where SoTK=1 and Ma_LH= IIf(8=1,'NDT', IIf(8=2,'NGC', IIf(8=3,'NKD', IIf(8=4,'NSX', IIf(8=5,'NTA', IIf(8=6,'NDT', IIf(8=7,'XGC', IIf(8=8,'XKD', IIf(8=9,'XSX','XTA')))))))))+ IIf(1=1,'01',IIf(1=2,'02', IIf(1=3,'03',IIf(1=4,'04', IIf(1=5,'05',IIf(1=6,'06', IIf(1=7,'07',IIf(1=8,'08', IIf(1=9,'09',1)))))))));]
150100.34 6 db [ccBienHoa] row count=1
150100.38 6 rv add [ccBienHoa_RowCount]{1}
150100.41 6 db get RecordsetGetRowsMax
150100.44 6 db get 999 records. (row count=1)
150100.47 6 db update RVs
150100.48 6 db about to close dbDbqDatabase
150100.55 6 db going down path [True]
150100.59 6 timer clear
150100.61 6 [Result1] Evaluate [$RV[ccBienHoa_1_1]]
150100.64 6 rv replace start: [$RV[ccBienHoa_1_1]]
150100.67 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Tra_cuu_TK\DienThoai\}[scriptPath]{C:\Tra_cuu_TK\DienThoai}[$RV_STARTTIME]{3/7/2005 3:00:51 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[inputCC]{1}[inputCC_PathTaken]{success}[input_Nhom_LH]{8}[i
[inputSoTK]{1}[inputSoTK_PathTaken]{success}[iF_Input]{1}[iF]{1}[ccBienHoa_RowCo
nt]{1}[ccBienHoa_1_1]{1}[ccBienHoa_2_1]{0}
150100.70 6 rv replace end: [1]
150100.73 6 .Eval(1)
150100.77 6 AddRVns [Result1_Input]{1}
150100.80 6 AddRVns [Result1]{1}
150100.83 6 Eval Expr result:[1]
150100.88 6 timer clear
150100.89 6 [GD1] Playing
150100.92 6 [GD1] Playing (Record\GD1.wav)
150100.97 6 play set playid=726546
150101.28 6 PlaySoundStart ok [C:\Tra_cuu_TK\DienThoai\Record\GD1.wav]
150101.31 6 timer clear
150101.34 6 RunModule PLAY end
150101.39 6 wa(4507,72654600)
150104.50 0 btn Hangup on line 6
150104.53 6 ScriptEventCode 9001 iLineState=1100
150104.56 6 LsPlayMsg EV_TIMEOUT_HANGUP
150104.58 6 rv add [Hangup Time]{3/7/2005 3:01:04 PM}
150104.61 6 Hanging up call...
150104.67 6 RecSoundStop ok
150104.78 6 PlaySoundStop err=0
150104.80 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
150104.83 6 fnHangupCall end
150105.47 6 callstate DISCONNECTED 65638 1 0
150105.50 6 ScriptEventCode 9250 iLineState=900
150105.53 6 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
150105.55 6 rv add [Hangup Time]{3/7/2005 3:01:05 PM}
150105.58 6 Hanging up call...
150105.63 6 RecSoundStop ok
150105.67 6 PlaySoundStop err=0
150105.69 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
150105.72 6 fnHangupCall end
150105.75 6 callstate IDLE 65638 0 0
150105.78 6 WorkingMode@Idle=
150105.81 6 timer clear
150105.84 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
150105.88 6 tapi Reply (LineEvReply) ok 65604 0
150105.91 6 tapi Reply (LineEvReply) ok 65587 0
150107.34 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
150107.41 6 ScriptEventCode 9008 iLineState=900
150107.47 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
150107.56 6 ReinitTelephony due to IDLE
150107.64 6 tapic lineDeallocateCall(MainCall:65638) 0
150107.77 6 lineOpen(6)=>
150107.84 6 Waiting for a call...
150107.91 6 LineHandle=65570
150107.98 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
150108.64 0 dial start any summary:|6:rdy=0|
150109.70 0 dial start any summary:|6:rdy=0|
150110.77 0 dial start any summary:|6:rdy=0|
150111.83 0 dial start any summary:|6:rdy=0|
150112.03 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
150112.09 6 ScriptEventCode 9013 iLineState=900
150148.09 0 sys cleanup Start
150148.09 0 sys cleanup End
Now, i want to use VG connect database by SQL Server 2k. I declared as in Voice Guide help but it's still error. Pls help me.
eg:
if i try a simple SQL query on the database (select * from DTokhaiMD_1) It's OK, but i can't understand when i use SQL query below in Access database to be success.
SQL query:
Although both database are the same.
Because i only understand a little English, i hope so you'll understand them and help me.
Thanks,
This looks like some sort of an SQLServer specific SQL query syntax problem, not an ODBC connectivity problem.
I'd recommend you debug your SQL statement by gradually increasing complexity and seeing at which stage it breaks.
VoiceGuide itself does not do any processing of the SQL statements - whatever is specified in script is just passed onto the database (after the RVs are replaced (if any)).
If I were you I'd look closely at how the IIF command (which you use a lot of) is supported by SQLServr.
Thanks your reply,
Because I used this Sql query on Access database (which I had exported from Sql Server 2k) to be OK. I will check careful them again.
In Query database, when it's check conection of database (eg: Sql Server), if Sql Server is not running, how do announce to the caller and hangup call?
Best way is to run a simple query which you know will always return something and if it does not return the expected data then the database must be down...
