3-Way with D/4PCI taking too long
Hi there
I am in need of your help again. The transfer is not working in my
script. I transfer a call to a 800#.
It's a 3-way call. My phone lines are such that it should be
1) flash
2) 1 second pause then dial number
3) another 1 second pause then flash again. This works fine manually
That's it...4 or 5 seconds. For some reason it takes 15 seconds.
Can you
help. I've included a trace and the vgs file.
It starts does the first flash:
232921.54 4 [HookFlash1-Office] Playing
232921.55 4 tapic lineGenerateDigits(66255,!,100) => 0
(5 secs difference)
then dials:
232926.16 4 [Dial800#-Office] Playing
232926.19 4 tapic lineGenerateDigits(66255,,18005497066,,100) => 0
(7 secs)
then flashes again:
232933.05 4 [HookFlash2-Office] Playing
232933.06 4 tapic lineGenerateDigits(66255,!,100) => 0
What does the ,100 mean? Also I've set the ! length at 250ms and pause time of 400ms in TSP
Please help and thanks so much!
Adam
akonecny@rogers.com
Here is the complete trace.
232714.02 0 Script Load C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs
232714.09 0 Loaded Script Id 3: C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs
232714.09 0 Erasing Script (new loaded) Id 2
232840.83 0 Script Load C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs
232840.89 0 Loaded Script Id 2: C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs
232840.90 0 Erasing Script (new loaded) Id 3
232855.03 4 dial [28109,15032331555,502282320,1,2359,MoTuWeThFrSaSu,,1,NONE,C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs,C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-msg.wav,none,60,0,9999,,none]
232855.10 4 rv clear
232855.10 0 dial callque update id=28109 next call time 0503072207
232855.11 0 dial callque DB update returned
232855.11 4 dial found entry: tel[15032331555] ann[NONE] vgs[C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs] am[C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-msg.wav] LineSelection:[]
232855.12 4 Dialing: 15032331555
232855.13 4 MakeCall => 65569
232855.13 4 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE
232855.13 4 TapiCbTrigSet 65569 7002
232857.66 4 tapi Reply (LineEvReply) ok 65569 0
232857.66 4 TapiCbTrigClear
232857.66 4 linedevstate 2048 0 0
232857.66 4 callstate DIALTONE 66255 0 0
232857.66 4 callstate DIALING 66255 0 0
232857.66 4 callstate PROCEEDING 66255 0 0
232857.66 4 callinfo CALLEDID
232857.67 4 callinfo REASON
232857.70 4 Lev_CallerID [0000,,15032331555]
232857.70 4 rv add [DNIS]{15032331555}
232857.70 4 callinfo ORIGIN
232902.95 0 dial start any summary:|4:dial=0|5:idx=0|6:idx=0|7:idx=0|
232910.41 4 callstate CONNECTED 66255 1 0
232910.41 4 callstate CONNECTED 66255,1,0
232910.41 4 WorkingModeTAPI@Connected=
232910.41 4 WorkingModeScript@Connected=
232910.43 4 rv add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
232910.43 4 rv add [PathApp]{C:\Program Files\VoiceGuide\}
232910.45 4 rv add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
232910.45 4 rv add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
232910.45 4 rv add [OutDial_RetriesLeft]{0}
232910.45 4 rv add [$RV_STARTTIME]{2/28/2005 11:29:10 PM}
232910.45 4 rv add [$RV_DEVICEID]{4}
232910.45 4 rv add [$RV_CIDNAME]{}
232910.45 4 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
232910.45 4 rv add [$RV_CALLEDNUMBER]{15032331555}
232910.45 0 dial callque delete id=28109
232910.53 4 AddRVns [OutDial_Result]{Contacted_Human}
232910.53 4 Live person answered, starting C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs
232910.53 2 tr NewVgsVgm_Goto C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs,,,,,0
232910.53 4 rv add [scriptEnd_Time]{2/28/2005 11:29:10 PM}
232910.53 4 rv add [scriptEnd_Goto_Script]{C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs}
232910.53 4 rv add [scriptEnd_Goto_Module]{}
232910.55 4 rv add [scriptStart_Time]{2/28/2005 11:29:10 PM}
232910.55 0 LoadedVgs_Find C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs at idx=2
232910.55 4 AddRVns [scriptsPath]{C:\VoiceGuideScripts\GOGI-NEW\}
232910.55 4 eng StartModuleDefault=[intro]
232910.56 4 timer clear
232910.56 4 [intro] Playing
232910.57 4 [intro] Playing (GOJINEW-human.wav)
232910.57 4 play set playid=55045
232910.91 4 PlaySoundStart ok [C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-human.wav]
232910.91 4 timer clear
232910.91 4 RunModule PLAY end
232910.91 4 wa(56105,5504500)
232910.91 4 callinfo MONITORMODES
232910.92 0 dial start any summary:|4:hc>0|5:idx=0|6:idx=0|7:idx=0|
232917.88 4 dtmf 1 (66255,49,2)
232917.88 4 ScriptEventCode 49 iLineState=1100
232917.88 4 LsPlayMsg 1
232917.93 4 PlaySoundStop err=0
232917.93 4 rv add [intro]{1}
232917.96 4 timer clear
232917.96 4 [CleanNum1] Evaluate [mid($RV_CALLEDNUMBER,2,10)]
232917.96 4 rv replace start: [mid($RV_CALLEDNUMBER,2,10)]
232917.96 4 rv ns none[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{0}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{
/28/2005 11:29:10 PM}[scriptEnd_Goto_Script]{C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/28/2005 11:29:10 PM}[scriptsPath]{C:\VoiceGuideScripts\GOGI-NEW\}[intro]{1}
232917.96 4 rv replace end: [mid(15032331555,2,10)]
232917.98 4 .Eval(mid(15032331555,2,10))
232917.98 4 AddRVns [CleanNum1_Input]{mid(15032331555,2,10)}
232917.98 4 AddRVns [CleanNum1]{5032331555}
232917.98 4 Eval Expr result:[5032331555]
232917.98 4 path {5032331555} not found
232917.98 4 timer clear
232917.98 4 [saveInfo] Run Program
232917.98 4 rv replace start: [command.com /c echo $RV[CleanNum1] $RV_STARTTIME >> c:\Goji#1_O.txt]
232917.98 4 rv ns none[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{0}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{
/28/2005 11:29:10 PM}[scriptEnd_Goto_Script]{C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-Office2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/28/2005 11:29:10 PM}[scriptsPath]{C:\VoiceGuideScripts\GOGI-NEW\}[intro]{1}[CleanNum1_Input]{mid(15032331555,2,10)}[CleanNum1]{5032331555}
232917.99 4 rv replace end: [command.com /c echo 5032331555 2/28/2005 11:29:10 PM >> c:\Goji#1_O.txt]
232917.99 4 eng run shell [command.com /c echo 5032331555 2/28/2005 11:29:10 PM >> c:\Goji#1_O.txt] window=NormalFocus, wait=0
232918.02 4 Run Program continuing...
232918.02 4 Going down Success path.
232918.03 4 timer clear
232918.03 4 [AnnounceXfer-Office] Playing
232918.03 4 [AnnounceXfer-Office] Playing (GOJINEW-xfer.wav)
232918.05 4 play set playid=62516
232918.12 4 PlaySoundStart ok [C:\VoiceGuideScripts\GOGI-NEW\GOJINEW-xfer.wav]
232918.12 4 timer clear
232918.12 4 RunModule PLAY end
232918.12 4 wa(3198,6251600)
232918.13 4 callinfo MONITORMODES
232921.37 4 wb(6251600)
232921.45 4 play end current play (playid=62516)
232921.45 4 ScriptEventCode 8001 iLineState=1100
232921.45 4 LsPlayMsg EV_PLAY_FINISHED
232921.45 4 timer set 10 EV_TIMEOUT_HANGUP
232921.45 4 timer set 0 EV_TIMEOUT_GOTOMODULE
232921.46 4 ScriptEventCode 9002 iLineState=1101
232921.46 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
232921.54 4 timer clear
232921.56 4 RunModule PLAY end
232923.45 4 generate LINEGENERATETERM_DONE
232923.45 4 timer set 1 EV_TAPI_GENERATE
232926.16 4 timer fired EV_TAPI_GENERATE
232926.16 4 ScriptEventCode 9602 iLineState=1100
232926.16 4 LsPlayMsg EV_TAPI_GENERATE
232926.16 4 timer set 10 EV_TIMEOUT_HANGUP
232926.16 4 timer set 0 EV_TIMEOUT_GOTOMODULE
232926.16 4 ScriptEventCode 9002 iLineState=1101
232926.16 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
232926.16 4 timer clear
232926.19 4 RunModule PLAY end
232930.26 4 generate LINEGENERATETERM_DONE
232930.26 4 timer set 1 EV_TAPI_GENERATE
232933.03 4 timer fired EV_TAPI_GENERATE
232933.03 4 ScriptEventCode 9602 iLineState=1100
232933.03 4 LsPlayMsg EV_TAPI_GENERATE
232933.03 4 timer set 10 EV_TIMEOUT_HANGUP
232933.05 4 timer set 0 EV_TIMEOUT_GOTOMODULE
232933.05 4 ScriptEventCode 9002 iLineState=1101
232933.05 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
232933.05 4 timer clear
232933.06 4 RunModule PLAY end
232935.09 4 generate LINEGENERATETERM_DONE
232935.09 4 timer set 1 EV_TAPI_GENERATE
232939.70 4 timer fired EV_TAPI_GENERATE
232939.70 4 ScriptEventCode 9602 iLineState=1100
232939.70 4 LsPlayMsg EV_TAPI_GENERATE
232939.70 4 timer set 10 EV_TIMEOUT_HANGUP
232939.70 4 timer set 0 EV_TIMEOUT_GOTOMODULE
232939.70 4 ScriptEventCode 9002 iLineState=1101
232939.70 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
232939.70 4 timer clear
232939.70 4 [Email-Office] Send Email
232939.72 4 rv replace start: [New Lead! (OFFICE) from $RV[CleanNum1] at $RV_STARTTIME]
232939.72 4 rv ns none[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{0}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{
232939.72 4 rv replace end: [New Lead! (OFFICE) from 5032331555 at 2/28/2005 11:29:10 PM]
232939.72 4 rv add [Email-Office]{gojiopp@yahoo.com;gogoji@excite.com}
232939.72 4 rv add [Email-Office_Subject]{New Lead! (OFFICE) from 5032331555 at 2/28/2005 11:29:10 PM}
232939.73 4 rv add [Email-Office_Message]{}
232939.73 4 rv add [Email-Office_Attachment]{}
232939.73 4 rv add [Email-Office_Cc]{}
232939.73 4 rv add [Email-Office_Bcc]{}
232939.73 4 email que to: gojiopp@yahoo.com;gogoji@excite.com
232939.73 0 sql INSERT INTO MsgQue (ToAddress, ToName, ReturnAddress, ReturnName, CcAddress, CcName, BccAddress, BccName, ReplyAddress, MsgSubject, MsgMessage, MsgAttachment, MsgAttachmentDeleteAfterSend, gw1_SmtpServ, gw1_UseAuthentication, gw1_UsePopAuthentication, gw1_AuthUserName, gw1_AuthUserPassword, gw1_POP3Host, gw1_SMTPPort, gw2_SmtpServ, gw2_UseAuthentication, gw2_UsePopAuthentication, gw2_AuthUserName, gw2_AuthUserPassword, gw2_POP3Host, gw2_SMTPPort, SendTime, SendRetriesLeft, SendDelayBetweenRetries) VALUES ('gojiopp@yahoo.com;gogoji@excite.com', 'gojiopp@yahoo.com;gogoji@excite.com', 'gojiopp@yahoo.com', 'AutoDialer#1', '', '', '', '', 'gojiopp@yahoo.com', 'New Lead! (OFFICE) from 5032331555 at 2/28/2005 11:29:10 PM', '
', '', 0, 'smtp.comcast.net', 0, 0, 'abcmarketing', 'abc12345', '', 0, 'MAPI', 0, 0, '', '', '', 0, 0, 3, 10)
232939.74 4 rv add [Email-Office_SendResult]{OK}
232939.76 4 timer clear
232939.76 4 [Record] Playing
232939.76 4 [Record] Playing ()
232939.76 4 ScriptEventCode 8001 iLineState=1100
232939.76 4 LsPlayMsg EV_PLAY_FINISHED
232939.76 4 timer set 10 EV_TIMEOUT_HANGUP
232939.77 4 timer set 80 EV_TIMEOUT_GOTOMODULE
232939.77 4 RunModule PLAY end
232953.53 0 btn Hangup on line 4
232953.53 4 ScriptEventCode 9001 iLineState=1101
232953.53 4 LsPlayMsgFinished EV_TIMEOUT_HANGUP
232953.55 4 rv add [Hangup Time]{2/28/2005 11:29:53 PM}
232953.55 4 Hanging up call...
232953.55 4 RecSoundStop ok
232953.55 4 PlaySoundStop err=0
232953.55 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
232953.56 4 fnHangupCall end
232953.60 4 linedevstate 2048 0 0
232953.62 4 callstate IDLE 66255 0 0
232953.62 4 WorkingMode@Idle=
232953.62 4 timer clear
232953.63 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
232953.63 4 tapi Reply (LineEvReply) ok 66540 0
232956.57 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
232956.57 4 ScriptEventCode 9008 iLineState=900
232956.57 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
232956.57 4 ReinitTelephony due to IDLE
232956.59 4 tapic lineDeallocateCall(MainCall:66255) 0
232956.94 4 lineOpen(4)=>
232956.94 4 Waiting for a call...
232956.94 4 LineHandle=65945
232956.94 4 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
233008.41 0 dial start any summary:|4:rdy=0|5:idx=0|6:idx=0|7:idx=0|
233015.73 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
233015.73 4 ScriptEventCode 9013 iLineState=900
GOJINEW_Office2.vgs
Please post the screenshot of the TSP config.
Is the 3-Way call established in the end?
Which version of VG are you using?
There does seem to be some problems with the timers on this system. Which version of Windows/Service Pack are you running?
Are you running any other software at the same time?
What is the CPU usage on this system when the transfer is being made?
-I'm running win2000 with SP2
-The system seems to be maxed at 100% resources...so that could explain the timer issue. It's a 128MB PII400 Mhz system. VGmulti.exe is taking 100% of the resources at all times. Also I have 50,000 names loaded.
-I've attached the TSP screenshots.
-the 3 way call is establishblished half the time, the other half it hangs up. but it takes 16 seconds instead of around 5.
-I am using the latest version of Voiceguide...5.2.3b
-the only other software is VNC, but as stated before, VG is running 99 to 100%
What hardware do you reommend? it is a 4 line D4PCI system.
Thanks, you guys are great!
Adam
TSP.zip
The system seems to be maxed at 100% resources... It's a 128MB PII400 Mhz system
Please add more memory... take it up to 256MB and see if that changes anything...
Also please post some screenshots of the Task Manager or the program which is showing the memory allocation status etc.
We received an email confirming that system was running at very high CPU utilization (probably from all the swapping to HD given the low RAM). This high CPU usage was causing the delays.
Customer has now updated to a faster system with more RAM.
