Wrong Hookflash Length
I am using a D/4PCI card in a 4 line VG application. All is working well except when I try to do 3-way conference calling.
My service provider has enabled 3-way conferencing and I have tested it manually with a normal handset. When I perform the same action with VG the caller does not get a transfer in progress tone, but a different tone (as if the call was disconnected).
The called number does not ring and the 3 calls can not be connected together.
Why would it work manually but not automatically?
gerrit@cestates.co.za
Trace shows that hookflash is taking a long time:
012756.88 19 tapic lineGenerateDigits(65697,!,0) => 0
012757.55 19 generate LINEGENERATETERM_DONE
Have you set the hookflash length both in .PRM file and in the TSP? Did you restart the Dialogic service after making the changes?
Thank you, but how long should the hookflash length be?
100ms or 250ms ?
