Modem Hangs Up Couple Of Seconds After Call
I am evaluating this product and when I try to answer any call with any of the supplie scripts the modem answers and then disconnects after a couple of seconds.
No voice or prompts are heard.
Copy of log
121001.51 7 callstate OFFERING 65759 0 4
121001.57 7 ring 1
121002.25 0 dial start any summary:|0:ivd<0|1:ivd<0|2:ivd<0|3:ivd<0|4:ivd<0|5:ivd<0|6:ivd<0|7:hc>0|
121005.18 7 ring 2
121005.18 7 rv clear
121005.20 7 Answer the call at 15/02/2005 12:10:05
121005.21 7 lineAnswer(65759) => 65777
121005.23 7 callstate ACCEPTED 65759 0 0
121005.64 7 tapi Reply (LineEvReply) ok 65777 0
121005.76 7 callstate CONNECTED 65759 0 0
121005.78 7 callstate CONNECTED 65759,0,0
121005.78 7 WorkingModeTAPI@Connected=
121005.79 7 WorkingModeScript@Connected=
121005.82 7 Inband detection not enabled
121005.84 7 StartLoadedVgs at 15/02/2005 12:10:05, v5.2.3063
121005.84 7 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\}
121005.86 7 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Customer Enquiry}
121005.87 7 rv add [$RV_STARTTIME]{15/02/2005 12:10:05}
121005.87 7 rv add [$RV_DEVICEID]{7}
121005.89 7 rv add [$RV_CIDNAME]{}
121005.90 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
121005.90 7 rv add [$RV_CIDNUMBER]{}
121005.92 7 timer clear
121005.93 7 [select Query] Playing
121005.95 7 [select Query] Playing (DemoScript.wav)
121005.95 7 play set playid=166687
121006.93 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Customer Enquiry\DemoScript.wav]
121006.95 7 timer clear
121006.95 7 RunModule PLAY end
121006.00 7 wa(8517,16668700)
121015.57 7 wb(16668700)
121015.65 7 play end current play (playid=166687)
121015.67 7 ScriptEventCode 8001 iLineState=1100
121015.67 7 LsPlayMsg EV_PLAY_FINISHED
121015.68 7 timer set 10 EV_TIMEOUT_HANGUP
121015.70 7 timer set 10 EV_TIMEOUT_HANGUP
121026.53 7 timer fired EV_TIMEOUT_HANGUP
121026.53 7 ScriptEventCode 9001 iLineState=1101
121026.54 7 LsPlayMsgFinished EV_TIMEOUT_HANGUP
121026.56 7 rv add [Hangup Time]{15/02/2005 12:10:26}
121026.56 7 Hanging up call...
121026.61 7 RecSoundStop ok
121026.67 7 PlaySoundStop err=0
121026.67 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
121026.73 7 fnHangupCall end
121027.43 7 callstate DISCONNECTED 65759 1 0
121027.45 7 ScriptEventCode 9250 iLineState=900
121027.45 7 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
121027.46 7 rv add [Hangup Time]{15/02/2005 12:10:27}
121027.48 7 Hanging up call...
121027.53 7 RecSoundStop ok
121027.59 7 PlaySoundStop err=0
121027.59 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
121027.65 7 fnHangupCall end
121027.67 7 callstate IDLE 65759 0 0
121027.68 7 WorkingMode@Idle=
121027.70 7 timer clear
121027.73 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
121027.76 7 tapi Reply (LineEvReply) ok 65930 0
121027.78 7 tapi Reply (LineEvReply) ok 65913 0
121028.78 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
121028.78 7 ScriptEventCode 9008 iLineState=900
121028.79 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
121028.81 7 ReinitTelephony due to IDLE
121028.82 7 tapic lineDeallocateCall(MainCall:65759) 0
121029.18 7 lineOpen(7)=>
121029.20 7 Waiting for a call...
121029.21 7 LineHandle=65862
121029.25 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
121029.28 0 dial start any summary:|0:ivd<0|1:ivd<0|2:ivd<0|3:ivd<0|4:ivd<0|5:ivd<0|6:ivd<0|7:rdy=0|
121032.54 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
121032.56 7 ScriptEventCode 9013 iLineState=900
121033.31 0 dial start any summary:|0:ivd<0|1:ivd<0|2:ivd<0|3:ivd<0|4:ivd<0|5:ivd<0|6:ivd<0|7:idx=0|
Trace shows that the modem's Wave driver is accepting to sound file to be played:
Sounds like the cards Wave drivers were not correctly installed - can you
try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers.
You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.
