Answering Machine Script
I am having trouble with an answering machine script. In the script I want to use the RV(Called Number) variable to select information from and access database (Subject First and Last Name), Then when the welcome message is complete I want VG to play a wav file, then have a text to speech engine say the subjects name based on the DBQuery above, then play a final wav file and hang up.
I have an dialout script that performs these functions flawlessly if a real person answers the call. So I copied the module, changed the wav files to the messages I wanted left on the answering machine. However, when I test the call, the script hangs up on the Text to Speech play module.
Any suggestions as to why the script would work perfectly when a real person answers the phone and crashes when I try to use it as an answering machine script?
You can enable the automatic saving of the logs to files in \log\ directory as well.
Here are the traces for a successful call when a person answers and the unsuccessful call when the AM answers.
Successful call with human answer
151740.61 0 cl Dialer_OutDialQueAdd 93036363119, 0, 1000, 2000, MoTuWeThFrSaSu, 7, 1, , \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs, \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs, , 60, 3, 2, ,
151740.61 0 DialListDB_AddCall '93036363119', 0, 1000, 2000, MoTuWeThFrSaSu, 7, 1, , \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs, \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs, , 60, 3, 2, ESCALATION:
151740.93 7 dial [159,93036363119,0,1000,2000,MoTuWeThFrSaSu,,7,,1,NONE,\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs,\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs,none,60,3,2,,none]
151740.93 0 dial callque update id=159 next call time 0502101519
151740.95 0 dial callque DB update returned
151740.95 7 dial found entry: tel[93036363119] ann[NONE] vgs[\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs] am[\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs]
151740.95 7 Dialing: 93036363119
151740.95 7 MakeCall => 65984
151740.95 7 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE
151740.96 7 TapiCbTrigSet 65984 7002
151740.96 0 dial start any summary:|7:dial=0|8:idx=0|9:idx=0|10:idx=0|
151741.54 7 tapi Reply (LineEvReply) ok 65984 0
151741.56 7 TapiCbTrigClear
151741.56 7 linedevstate 2048 0 0
151741.56 7 callstate DIALTONE 65829 0 0
151741.56 7 callstate DIALING 65829 0 0
151741.56 7 callstate PROCEEDING 65829 0 0
151741.56 7 callinfo CALLEDID
151741.57 7 callinfo REASON
151741.57 7 Lev_CallerID [0000,,93036363119]
151741.57 7 rv add [DNIS]{93036363119}
151741.57 7 callinfo ORIGIN
151750.71 7 callstate CONNECTED 65829 1 0
151750.71 7 callstate CONNECTED 65829,1,0
151750.71 7 WorkingModeTAPI@Connected=
151750.71 7 WorkingModeScript@Connected=
151750.73 7 rv add [OutDial_RetriesLeft]{3}
151750.73 7 rv add [$RV_STARTTIME]{2/10/2005 3:17:50 PM}
151750.73 7 rv add [$RV_DEVICEID]{7}
151750.73 7 rv add [$RV_CIDNAME]{}
151750.73 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
151750.73 7 rv add [$RV_CALLEDNUMBER]{93036363119}
151750.75 0 dial callque delete id=159
151750.75 7 AddRVns [OutDial_Result]{Contacted_Human}
151750.75 7 Live person answered, starting \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs
151750.75 2 tr NewVgsVgm_Goto \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs,,,,,0
151750.75 7 rv add [scriptEnd_Time]{2/10/2005 3:17:50 PM}
151750.76 7 rv add [scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}
151750.76 7 rv add [scriptEnd_Goto_Module]{}
151750.76 7 rv add [scriptStart_Time]{2/10/2005 3:17:50 PM}
151750.78 0 Script Load \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs
151750.95 7 Loaded \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs into:3
151750.96 7 AddRVns [scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}
151750.96 7 AddRVns [scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}
151750.96 7 cl NewVgsVgm_RunModule module not found:
151750.96 7 timer clear
151750.96 7 [setIncomingCall] Evaluate [0]
151750.96 7 .Eval(0)
151750.98 7 AddRVns [setIncomingCall_Input]{0}
151750.98 7 AddRVns [setIncomingCall]{0}
151750.98 7 AddRVns [isIncomingCall]{0}
151750.98 7 Eval Expr result:[0] stored in $RV[isIncomingCall]
151750.98 7 timer clear
151750.98 7 [GetPatientInfo] DB Query
151750.00 7 db Jet mode used (To use ODBC mode specify ODBC Connect string)
151751.15 7 rv replace start: [sELECT FirstName, LastName, HRN, LastCallNumber,PatientID FROM Patient WHERE PhoneNumber ='$RV_CALLEDNUMBER' AND IncorrectNumber = 0]
151751.15 7 rv ns none[OutDial_RetriesLeft]{3}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{2/10/2005 3:17:50 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:17:50 PM}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}
151751.15 7 db About to execute a Retrieve type operation [sELECT FirstName, LastName, HRN, LastCallNumber,PatientID FROM Patient WHERE PhoneNumber ='93036363119' AND IncorrectNumber = 0]
151751.17 7 db [GetPatientInfo] row count=1
151751.17 7 rv add [GetPatientInfo_RowCount]{1}
151751.17 7 db get RecordsetGetRowsMax
151751.18 7 db get 999 records. (row count=1)
151751.18 7 db update RVs
151751.18 7 db about to close dbDbqDatabase
151751.21 7 db going down path [True]
151751.21 7 timer clear
151751.21 7 [iniate1] Playing
151751.21 7 [iniate1] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach1.wav)
151751.25 7 play set playid=510718
151751.48 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach1.wav]
151751.48 7 timer clear
151751.48 7 RunModule PLAY end
151751.50 7 wa(9246,51071800)
151751.50 7 callinfo MONITORMODES
151800.79 7 play end current play (playid=510718)
151800.81 7 ScriptEventCode 8001 iLineState=1100
151800.81 7 LsPlayMsg EV_PLAY_FINISHED
151800.81 7 timer set 10 EV_TIMEOUT_HANGUP
151800.81 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151800.81 7 ScriptEventCode 9002 iLineState=1101
151800.81 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151800.82 7 timer clear
151800.82 7 [sayPatientName] Playing
151800.82 7 rv replace start: [$RV[GetPatientInfo_1_1] $RV[GetPatientInfo_2_1]]
151800.82 7 rv ns none[OutDial_RetriesLeft]{3}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{2/10/2005 3:17:50 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:17:50 PM}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}[G
tPatientInfo_RowCount]{1}[GetPatientInfo_1_1]{Steve}[GetPatientInfo_2_1]{Bensen}
GetPatientInfo_3_1]{555555555}[GetPatientInfo_4_1]{2}[GetPatientInfo_5_1]{13}
151800.82 7 rv replace end: [steve Bensen]
151800.84 7 tts generate start[steve Bensen]
151800.84 7 tts generate wait
151800.84 7 RunModule PLAY end
151800.95 7 tts generate finish. lineCallState=CONNECTED
151800.95 7 [sayPatientName] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
151800.96 7 play set playid=520437
151800.96 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
151800.96 7 timer clear
151800.98 7 wa(1487,52043700)
151800.98 7 callinfo MONITORMODES
151802.48 7 wb(52043700)
151802.53 7 play end current play (playid=520437)
151802.53 7 ScriptEventCode 8001 iLineState=1100
151802.54 7 LsPlayMsg EV_PLAY_FINISHED
151802.54 7 timer set 10 EV_TIMEOUT_HANGUP
151802.54 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151802.54 7 ScriptEventCode 9002 iLineState=1101
151802.54 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151802.54 7 timer clear
151802.56 7 [iNITIATE2] Playing
151802.56 7 [iNITIATE2] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach2.wav)
151802.57 7 play set playid=522046
151802.96 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach2.wav]
151802.96 7 timer clear
151802.96 7 RunModule PLAY end
151802.96 7 wa(16496,52204600)
151802.96 7 callinfo MONITORMODES
151819.51 7 play end current play (playid=522046)
151819.53 7 ScriptEventCode 8001 iLineState=1100
151819.53 7 LsPlayMsg EV_PLAY_FINISHED
151819.53 7 timer set 10 EV_TIMEOUT_HANGUP
151819.53 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151819.53 7 ScriptEventCode 9002 iLineState=1101
151819.54 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151819.54 7 timer clear
151819.54 7 [iNTIATE3] Playing
151819.54 7 [iNTIATE3] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INTIATE3.wav)
151819.56 7 play set playid=539031
151819.65 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INTIATE3.wav]
151819.65 7 timer clear
151819.67 7 RunModule PLAY end
151819.67 7 wa(2746,53903100)
151819.67 7 callinfo MONITORMODES
151822.43 7 wb(53903100)
151822.48 7 play end current play (playid=539031)
151822.48 7 ScriptEventCode 8001 iLineState=1100
151822.48 7 LsPlayMsg EV_PLAY_FINISHED
151822.50 7 timer set 10 EV_TIMEOUT_HANGUP
151822.50 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151822.50 7 ScriptEventCode 9002 iLineState=1101
151822.50 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151822.50 7 timer clear
151822.51 7 [sayPatientNameTwo] Playing
151822.51 7 rv replace start: [$RV[GetPatientInfo_1_1] $RV[GetPatientInfo_2_1]]
151822.51 7 rv ns none[OutDial_RetriesLeft]{3}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{2/10/2005 3:17:50 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:17:50 PM}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}[G
151822.51 7 rv replace end: [steve Bensen]
151822.51 7 tts generate start[steve Bensen]
151822.53 7 tts generate wait
151822.53 7 RunModule PLAY end
151822.54 7 tts generate finish. lineCallState=CONNECTED
151822.54 7 [sayPatientNameTwo] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
151822.54 7 play set playid=542015
151822.56 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
151822.56 7 timer clear
151822.56 7 wa(1487,54201500)
151822.57 7 callinfo MONITORMODES
151824.11 7 wb(54201500)
151824.12 7 play end current play (playid=542015)
151824.12 7 ScriptEventCode 8001 iLineState=1100
151824.12 7 LsPlayMsg EV_PLAY_FINISHED
151824.12 7 timer set 10 EV_TIMEOUT_HANGUP
151824.12 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151824.12 7 ScriptEventCode 9002 iLineState=1101
151824.14 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151824.14 7 timer clear
151824.15 7 [iNTIATE4] Playing
151824.15 7 [iNTIATE4] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INTIATE4.wav)
151824.18 7 play set playid=543656
151824.25 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INTIATE4.wav]
151824.25 7 timer clear
151824.25 7 RunModule PLAY end
151824.26 7 wa(1496,54365600)
151824.26 7 callinfo MONITORMODES
151825.81 7 play end current play (playid=543656)
151825.81 7 ScriptEventCode 8001 iLineState=1100
151825.81 7 LsPlayMsg EV_PLAY_FINISHED
151825.81 7 timer set 10 EV_TIMEOUT_HANGUP
151825.82 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151825.82 7 ScriptEventCode 9002 iLineState=1101
151825.82 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151825.82 7 timer clear
151825.84 7 [sayPatientNameThree] Playing
151825.84 7 rv replace start: [$RV[GetPatientInfo_1_1] $RV[GetPatientInfo_2_1]]
151825.84 7 rv ns none[OutDial_RetriesLeft]{3}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{2/10/2005 3:17:50 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:17:50 PM}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}[G
151825.84 7 rv replace end: [steve Bensen]
151825.84 7 tts generate start[steve Bensen]
151825.86 7 tts generate wait
151825.86 7 RunModule PLAY end
151825.90 7 tts generate finish. lineCallState=CONNECTED
151825.90 7 [sayPatientNameThree] Playing (C:\Program Files\VoiceGuide\data\tts7.wav)
151825.90 7 play set playid=545375
151825.92 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts7.wav]
151825.92 7 timer clear
151825.92 7 wa(1487,54537500)
151825.92 7 callinfo MONITORMODES
151827.46 7 play end current play (playid=545375)
151827.46 7 ScriptEventCode 8001 iLineState=1100
151827.46 7 LsPlayMsg EV_PLAY_FINISHED
151827.46 7 timer set 10 EV_TIMEOUT_HANGUP
151827.48 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151827.48 7 ScriptEventCode 9002 iLineState=1101
151827.48 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151827.48 7 timer clear
151827.48 7 [iNITIATE5] Playing
151827.50 7 [iNITIATE5] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INITIATE5.wav)
151827.51 7 play set playid=546984
151827.61 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\OutgoingInitCallValidateHRN\INITIATE5.wav]
151827.61 7 timer clear
151827.61 7 RunModule PLAY end
151827.62 7 wa(2496,54698400)
151827.62 7 callinfo MONITORMODES
151830.14 7 wb(54698400)
151830.20 7 play end current play (playid=546984)
151830.20 7 ScriptEventCode 8001 iLineState=1100
151830.20 7 LsPlayMsg EV_PLAY_FINISHED
151830.20 7 timer set 10 EV_TIMEOUT_HANGUP
151830.20 7 timer set 0 EV_TIMEOUT_GOTOMODULE
151830.21 7 ScriptEventCode 9002 iLineState=1101
151830.21 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151830.21 7 timer clear
151830.21 7 [sayPatientNameFour] Playing
151830.21 7 rv replace start: [$RV[GetPatientInfo_1_1] $RV[GetPatientInfo_2_1]]
151830.23 7 rv ns none[OutDial_RetriesLeft]{3}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{2/10/2005 3:17:50 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:17:50 PM}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}[G
151830.23 7 rv replace end: [steve Bensen]
151830.23 7 tts generate start[steve Bensen]
151830.23 7 tts generate wait
151830.25 7 RunModule PLAY end
151830.25 7 callstate DISCONNECTED 65829 0 0
Here's the log for a successful call answered by a real person (Hung up after the TTS module).
151830.25 7 ScriptEventCode 9250 iLineState=1100
151830.25 7 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
151830.25 7 rv add [Hangup Time]{2/10/2005 3:18:30 PM}
151830.26 7 Hanging up call...
151830.26 7 RecSoundStop ok
151830.26 7 PlaySoundStop err=0
151830.26 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
151830.29 7 fnHangupCall end
151830.29 7 tts generate finish. lineCallState=DISCONNECTED
151830.29 7 tts play abort as linestate not connected
151830.32 7 linedevstate 2048 0 0
151830.32 7 callstate IDLE 65829 0 0
151830.32 7 WorkingMode@Idle=
151830.34 7 timer clear
151830.42 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
151830.42 7 tapi Reply (LineEvReply) ok 65982 0
151831.40 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
151831.40 7 ScriptEventCode 9008 iLineState=900
151831.40 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
151831.40 7 ReinitTelephony due to IDLE
151831.42 7 tapic lineDeallocateCall(MainCall:65829) 0
151831.46 7 lineOpen(7)=>
151831.46 7 Waiting for a call...
151831.46 7 LineHandle=66137
151831.46 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
151832.14 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
151833.14 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
151834.14 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
151834.86 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
151834.86 7 ScriptEventCode 9013 iLineState=900
151835.79 0 btn Hangup on line 7
151835.81 7 rv add [Hangup Time]{2/10/2005 3:18:35 PM}
151835.81 7 Hanging up call...
151835.82 7 eng exit HangupCall_Common as LineCallState=IDLE already
Unsuccessful Answering Machine script. The call Hung on the TTS module. I had to click the hang up button.
152229.96 0 cl Dialer_OutDialQueAdd 93036363119, 0, 1000, 2000, MoTuWeThFrSaSu, 7, 1, , \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs, \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs, , 60, 3, 2, ,
152229.96 0 DialListDB_AddCall '93036363119', 0, 1000, 2000, MoTuWeThFrSaSu, 7, 1, , \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs, \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs, , 60, 3, 2, ESCALATION:
152230.87 7 dial [161,93036363119,0,1000,2000,MoTuWeThFrSaSu,,7,,1,NONE,\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs,\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs,none,60,3,2,,none]
152230.89 0 dial callque update id=161 next call time 0502101524
152230.89 0 dial callque DB update returned
152230.89 7 dial found entry: tel[93036363119] ann[NONE] vgs[\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\AnsweringMachine2.vgs] am[\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs]
152230.89 7 Dialing: 93036363119
152230.89 7 MakeCall => 66478
152230.89 7 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE
152230.90 7 TapiCbTrigSet 66478 7002
152230.90 0 dial start any summary:|7:dial=0|8:idx=0|9:idx=0|10:idx=0|
152231.48 7 tapi Reply (LineEvReply) ok 66478 0
152231.50 7 TapiCbTrigClear
152231.50 7 linedevstate 2048 0 0
152231.50 7 callstate DIALTONE 65796 0 0
152231.50 7 callstate DIALING 65796 0 0
152231.50 7 callstate PROCEEDING 65796 0 0
152231.50 7 callinfo CALLEDID
152231.51 7 callinfo REASON
152231.51 7 Lev_CallerID [0000,,93036363119]
152231.51 7 rv add [DNIS]{93036363119}
152231.51 7 callinfo ORIGIN
152300.46 7 callstate DISCONNECTED 65796 16 0
152300.46 7 ScriptEventCode 9250 iLineState=5200
152300.46 7 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
152300.46 7 rv add [OutDial_RetriesLeft]{3}
152300.46 7 rv add [$RV_STARTTIME]{2/10/2005 3:23:00 PM}
152300.48 7 rv add [$RV_DEVICEID]{7}
152300.48 7 rv add [$RV_CIDNAME]{}
152300.48 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
152300.48 7 rv add [$RV_CALLEDNUMBER]{93036363119}
152300.48 0 dial callque delete id=161
152300.48 7 AddRVns [OutDial_Result]{Contacted_AM}
152300.50 7 AM - wait for end of welcome message...
152300.50 7 dial awaiting end of answering machine message (lvl:10 for 20)
152300.50 7 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_7.wav] ok
152300.50 7 timer set 120 EV_TIMEOUT_HANGUP
152318.48 7 ScriptEventCode 9300 iLineState=1152
152318.50 7 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
152318.56 7 RecSoundStop ok
152318.57 7 timer set 1 EV_REC_FINISHED
152318.59 7 ScriptEventCode 8003 iLineState=1152
152318.59 7 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
152318.61 7 rv replace start: [$RV[AmWelcMsg_RecLen100ms]]
152318.61 7 rv ns none[OutDial_RetriesLeft]{3}
152318.62 7 rv replace end: []
152318.64 7 am msglen=0, minrequired=20
152318.64 7 Run Answer Machine script [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs]
152318.65 2 tr NewVgsVgm_Goto \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs,,,,,0
152318.67 7 rv add [scriptEnd_Time]{2/10/2005 3:23:18 PM}
152318.67 7 rv add [scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs}
152318.68 7 rv add [scriptEnd_Goto_Module]{}
152318.70 7 rv add [scriptStart_Time]{2/10/2005 3:23:18 PM}
152318.70 7 rv add [scriptStart_CalledFrom_Module]{SetIncomingCall}
152318.73 0 Script Load \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs
152318.81 7 Loaded \\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs into:4
152318.81 7 AddRVns [scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}
152318.82 7 AddRVns [scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}
152318.84 7 cl NewVgsVgm_RunModule module not found:
152318.86 7 timer clear
152318.86 7 [setIncomingCall] Evaluate [0]
152318.87 7 .Eval(0)
152318.89 7 AddRVns [setIncomingCall_Input]{0}
152318.89 7 AddRVns [setIncomingCall]{0}
152318.90 7 AddRVns [isIncomingCall]{0}
152318.92 7 Eval Expr result:[0] stored in $RV[isIncomingCall]
152318.92 7 timer clear
152318.93 7 [GetPatientInfo] DB Query
152318.95 7 db Jet mode used (To use ODBC mode specify ODBC Connect string)
152319.18 7 rv replace start: [sELECT FirstName, LastName, HRN, LastCallNumber,PatientID FROM Patient WHERE PhoneNumber ='$RV_CALLEDNUMBER' AND IncorrectNumber = 0]
152319.18 7 rv ns none[OutDial_RetriesLeft]{3}[scriptEnd_Time]{2/10/2005 3:23:18 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:23:18 PM}[scriptStart_CalledFrom_Module]{SetIncomingCall}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}
152319.20 7 db About to execute a Retrieve type operation [sELECT FirstName, LastName, HRN, LastCallNumber,PatientID FROM Patient WHERE PhoneNumber ='93036363119' AND IncorrectNumber = 0]
152319.21 7 db [GetPatientInfo] row count=1
152319.23 7 rv add [GetPatientInfo_RowCount]{1}
152319.23 7 db get RecordsetGetRowsMax
152319.25 7 db get 999 records. (row count=1)
152319.26 7 db update RVs
152319.26 7 db about to close dbDbqDatabase
152319.29 7 db going down path [True]
152319.31 7 timer clear
152319.32 7 [iniate1] Playing
152319.32 7 [iniate1] Playing (\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach1.wav)
152319.36 7 play set playid=838828
152319.59 7 PlaySoundStart ok [\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Wavs\AnsweringMachine\ansmach1.wav]
152319.59 7 timer clear
152319.61 7 RunModule PLAY end
152319.62 7 wa(9246,83882800)
152328.90 7 play end current play (playid=838828)
152328.92 7 ScriptEventCode 8001 iLineState=1100
152328.92 7 LsPlayMsg EV_PLAY_FINISHED
152328.93 7 timer set 10 EV_TIMEOUT_HANGUP
152328.95 7 timer set 0 EV_TIMEOUT_GOTOMODULE
152328.95 7 ScriptEventCode 9002 iLineState=1101
152328.96 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
152328.98 7 timer clear
152328.98 7 [sayPatientName] Playing
152328.00 7 rv replace start: [$RV[GetPatientInfo_1_1] $RV[GetPatientInfo_2_1]]
152329.01 7 rv ns none[OutDial_RetriesLeft]{3}[scriptEnd_Time]{2/10/2005 3:23:18 PM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\TestAnsweringMachine.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2/10/2005 3:23:18 PM}[scriptStart_CalledFrom_Module]{SetIncomingCall}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts\}[scriptPath]{\\Rmregfile004\Research\IVR\VoiceGuide\PreDiabetes\Scripts}[setIncomingCall_Input]{0}[setIncomingCall]{0}[isIncomingCall]{0}[G
152329.03 7 rv replace end: [steve Bensen]
152329.03 7 tts generate start[steve Bensen]
152329.04 7 tts generate wait
152329.06 7 RunModule PLAY end
152329.11 7 tts generate finish. lineCallState=DISCONNECTED
152329.11 7 tts play abort as linestate not connected
152408.28 0 btn Hangup on line 7
152408.28 7 ScriptEventCode 9001 iLineState=1100
152408.29 7 LsPlayMsg EV_TIMEOUT_HANGUP
152408.31 7 rv add [Hangup Time]{2/10/2005 3:24:08 PM}
152408.31 7 Hanging up call...
152408.32 7 RecSoundStop ok
152408.34 7 PlaySoundStop err=0
152408.34 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
152408.39 7 fnHangupCall end
152408.50 7 linedevstate 2048 0 0
152408.51 7 callstate IDLE 65796 0 0
152408.51 7 WorkingMode@Idle=
152408.53 7 timer clear
152408.67 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
152408.68 7 tapi Reply (LineEvReply) ok 65915 0
152409.68 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
152409.68 7 ScriptEventCode 9008 iLineState=900
152409.70 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
152409.71 7 ReinitTelephony due to IDLE
152409.86 7 tapic lineDeallocateCall(MainCall:65796) 0
152409.92 7 lineOpen(7)=>
152409.92 7 Waiting for a call...
152409.93 7 LineHandle=65813
152409.95 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
152410.92 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
152411.00 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
152413.07 0 dial start any summary:|7:rdy=0|8:idx=0|9:idx=0|10:idx=0|
152413.28 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
152413.28 7 ScriptEventCode 9013 iLineState=900
We can see what is happening here - but this should not be happening in the latest version of VoiceGuide.
Which version of VoiceGuide are you using? If not the latest (v5.2.3b) then please update to that version and try again...
I currently have version 5.2.3018. I downloaded the 5.2.3b version, but when I went to install the upgrade it asked if I want to delete the program and all it's components.
What is the correct proceedure for installation. Will I have to re-install my modem, and re-create my other settings?
Before installing the new version the previous version must be deleted.
This removes the entire VoiceGuide directory, so if you have anything you ant to save from within there you should make a backup copy of it first.
I'm fairly sure installing 5.2.3b the problem you see will go away.
If it does not the update the v5.2.3b with the attached .exe and try again. Attached .exe has more debugging in it in the relevant area.
VgMulti_5.2.3067.zip
I was able to update to 5.2.3b, but the attached patch would not install. After I extracted the patch and ran it, it stated that VoiceGuide was not configured, then gave a message that it couldn't find the configuration manager and closed the window, with not update to the program. VG currently reads version 5.2.3063 instead of 5.2.3067. Need advice on how to install the patch? Steve
Steve, you are just supposed to unzip the new executable into your Voiceguide folder overwriting the existing version.
I tried to upzip this into the folder, but it asked for a password, what is the password? Steve
It asks you for a password? Can you post a screenshot of that?
The .ZIP is not password protected.
I just downloaded VgMulti_5.2.3067.zip from the forum and unzipped it and it did not ask me for any passwords...
