"paths" Condition On Run Module
I am encountering some problems exiting from a "RUN" module.
The module correctly calls the external visual basic program, that writes down a result file "VGRUNRESULT_<line_number>.TXT" file.
In this "RUN" module, the "Paths" I have written in are:
on {timeout 60} goto [riagganciare]
on {fail} goto [problemi]
on {success} goto [risuverifica]
And in the following "[risuverifica]" module there is the evaluation of the variable written in the file.
The problem is that the procedure never goes to the "[risuverifica]" module, it always exits choosing "[problemi]", like if an error occurs during the execution of the external program.
I really don't know what to try next, please help me.
Thank you
Enrico
Voiceguide version: 5.2.3010
The problem - sorry - was with a wrong file name. In the event log I found that VG was never reading the result variable written in the text file, so I copied the file name that my program was writing - trying to find it out in the log file. And Notepad never found it ... because of a supplementary <space> character I wrote in the file name.
After the correction, the VG procedure is now working.
Thank you for your time, problem solved.
Enrico
