Upgrade
Windows 2000 Pro
VG 5.0.200
Dialogic d4PCI
Enterprise, VG Dialer, 4 line
Question:
Anything special I need to be aware of before upgrading to new ver. of VG?
Where do I get the upgrade?
Make sure you back up everything you need from VoiceGuide's directory, as it will be deleted when you uninstall.
Then uninstall v5.0.
You may want to confirm that TAPIWRAP.OCX and SAPIWRAP.OCX get deleted from Windows' System32 directory - some people had problems as these files did not delete for some reason..
Then install v5.2 (Just download the v5.2.3 from our WWW)
I upgraded as per instructions but I've obviously messed something up!
Now when I run a trace without a call in progress, I get...
142847.20 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142848.26 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142849.30 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142850.34 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142851.37 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142852.40 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142853.43 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142854.47 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142855.50 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142856.55 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142857.59 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142858.62 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142859.65 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142900.68 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142901.71 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
142902.75 0 dial start any summary:|4:dok=0|5:idx=0|6:idx=0|7:idx=0|
And so on…..
Any ideas?
The "4:dok=0" in the trace indicates that dialing out is disabled on the 'line 4' - in your case the 1st line on the system.
If dialing out is disabled on any lines this appears in the log on regular basis just to indicate that no calls will be searched for for that line.
