Connecting To Mssql Server
I've downloaded VoiceGuide trial software and encountered the following
problem:
I 'm using DataBase Query Module to connect our MSSQL database but fail to
do so.
I've created SQL ODBC source. Can i use the ODBC source(I can only choose
.xls or .mdb format) as module parameter or should i create a connection
string to do so?
If using connection string , what is the format of it?
Please post the VoiceGuide script you have set up.
Could you please also post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
