VocieGuide (TAPI version), Announced Transfer
We are using VG with a KCE FX-416 PBX. Attached is the Event Trace of the problem in question. VG transfers calls to the requested ext just fine, unless the ext is busy. If it is busy the call is disconnected rather then taking the fail path ???
We were previously using a simpler version PBX, the KCE FX-207, that performed this same script with out a problem.
Dan Clements
101334.55 6 [Whos Up] Evaluate [$RV[upAgent]]
101334.55 6 rv replace start: [$RV[upAgent]]
101334.55 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Dan\PBX\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Dan\PBX}[$RV_STARTTIME]{1/3/2005 10:13:13 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Customer Welcome]{1}[set CS Reqst ID =1_Input]{1}[set CS Reqst ID =1]{1}[REQUESTER]{1}[Read Xcell Upaget_RowCount]{1}[Read Xcell Upaget_1_1]{2}[Read Up Agent_Input]{2}[Read Up Agent]{2}[upAgent]{2}[set Pass back 1_Input]{1}[set Pass back 1]{1}[New Data]{1}[set Annc Counter_Input]{0}[set Annc Counter]{0}[C]{0}[Chk Reqster_Input]{1}[Chk Reqster]{1}
101334.56 6 rv replace end: [2]
101334.56 6 .Eval(2)
101334.56 6 AddRVns [Whos Up_Input]{2}
101334.57 6 AddRVns [Whos Up]{2}
101334.57 6 Eval Expr result:[2]
101334.58 6 timer clear
101334.58 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
101334.98 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
101334.98 6 ScriptEventCode 9012 iLineState=1900
101334.99 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
101334.99 6 timer set 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
101334.99 6 [KAG Up] Announced Transfer to 201 (Generate)
101335.04 6 tapic lineGenerateDigits(66409,!,0) => 0
101335.75 6 generate LINEGENERATETERM_DONE
101335.75 6 timer set 1 EV_TAPI_GENERATE
101336.75 6 timer fired EV_TAPI_GENERATE
101336.75 6 ScriptEventCode 9602 iLineState=1900
101336.75 6 LsXferStart EV_TAPI_GENERATE
101336.76 6 timer set 1 EV_HOOKFLASHFINISHED
101337.80 6 timer fired EV_HOOKFLASHFINISHED
101337.80 6 ScriptEventCode 9200 iLineState=1905
101337.80 6 LsXferPlayVts EV_HOOKFLASHFINISHED
101337.82 6 tapic lineGenerateDigits(66409,201,0) => 0
101338.28 6 generate LINEGENERATETERM_DONE
101338.28 6 timer set 1 EV_TAPI_GENERATE
101338.38 6 callstate DISCONNECTED 66409 0 0 <==== here is the disconnect
101338.38 6 ScriptEventCode 9250 iLineState=1905
101338.39 6 LsXferPlayVts EV_REMOTEPARTY_DISCONNECT
101338.39 6 rv add [Hangup Time]{1/3/2005 10:13:38 AM}
101338.39 6 Hanging up call...
101338.39 6 RecSoundStop ok
101338.40 6 PlaySoundStop err=0
101338.40 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
101338.40 6 fnHangupCall end
101338.49 6 linedevstate 2048 0 0
101338.49 6 callstate IDLE 66409 0 0
101338.49 6 WorkingMode@Idle=
101338.50 6 timer clear
101338.50 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
101338.50 6 tapi Reply (LineEvReply) ok 66341 0
101339.42 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
101339.42 6 ScriptEventCode 9008 iLineState=900
101339.42 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
101339.42 6 ReinitTelephony due to IDLE
101339.44 6 tapic lineDeallocateCall(MainCall:66409) 0
101339.70 6 lineOpen(6)=>
101339.71 6 Waiting for a call...
Any chance someone has looked at this yet? After reading other post, it seams to be that the card, a D41/D, need to distinguish between a busy and the disconnect busy. I have used PBXpert but it appears that the busy and disconnect cadences are only 10 mls apart. My reorder test on PBXpert fails.
Dan
Ok, now I am beginning to feel unloved . . . I've seen many post answered since mine yet I am ignored??? I’m sure it’s an over sight. Is support not working? I have bought two versions of Voice Guide? I love the product . . . Just need some help here.
After the prior post, I have tried to set the Disc Tones to 0. The result is an immediate hang up, after script answer. I have then changed the Disc tones to 1000 with like a 5 min on off cadence time. The script runs as before, when transferred to busy extension voice guide hangs up. Event trace show remote party disconnects. I’ve called in manually form both a cell phone and a land line, to simulate the actions of voice guide. All that is heard is the busy tone played on the line.
Are you using a Dialogic card?
We have a patch for this problem for you to try out if you are using a Dialogic card.
Please send email to support@voiceguide.com and "VoiceGuide for Dialogic" will be forwarded to you.
Thanks for sending the patch. I see from the read me file that I need Dialogic's SR 5.1.1 and global call installed. My card is a D41/d. Dialogic has stopped supporting this card. The documentation with the SR 5.1.1 said it is the last release to support ISA cards .. . the question is will SR5.1.1 still work on the D41/d? Supported hardware in the documentation shows only the d41/H. I am hesitant to try, as I have a Simi-functioning system now.
Dan Clements
Ok,
I found the time to do the SR 5.1.1sps install. And followed the instructions provided with the patch. I did not download a new version of VG, Instead I am using my current version that I purchased. 6.0.1005 Professional Version.
It looks like the SR installed with out a hitch, and the board starts the first time! All of the files were placed in the correct directories per the instructions. Now when I fire up VG it show no line status, when I click config wizard, it says I need to edit Config.xml. I am using a D41/d , 4 port analog. When I edit config.xml it shows the line names correctly. I don't know what to change.
What to do next?
Dan
Please enable logging by editing the VG.INI's [Log] section as per below:
[Log]
;Automated "log-to-file" logging.
;To turn OFF logging for a particular application set it's entry to 0
;To turn ON all logging for a particular application set it's entry to 10
;all log files are saved in VoiceGuide's \log\ subdirectory
;log files are names as following:
;VoiceGuide: MMDDvgm.txt
;NumberLoader: MMDDtnl.txt
;EmailSender: MMSSes.txt
;TapiWrapOcx: MMDDtw.txt
;SapiWrapOcx: MMDDsw.txt
VoiceGuide=10
NumberLoader=10
VoicemailManager=10
EmailSender=10
TapiWrapOcx=10
SapiWrapOcx=10
Then start VG and post the MMDDvgm.txt and MMDDtw.txt log files here. They will tell us what is the system status and what is going on.
If you edited the Config.xml file then please post it as well.
Wonderful!
Installed the new patch, and the line status worked!
Attached are the log files as requested. I now have an issue with the sound files. The scripts appear to be working, however no sound files play when calling into the system. I noticed on the VG for Dialogic installation guide that all sound files used with this system should be in PCM 8khz 8bit mono. My scripts are all created with MuLaw 8khz 8bit mono as the Dialogic D41/d only supports this format.
Is this the issue? If so is there a workaround for the D41/d ?
Dan
0130vgm.txt
The traces posted do not capture any incoming calls...
Correct. All sound files should be in this format. This includes your card.
The MuLaw files had to be used for that card with the old 'TAPI' based version of VG. The 'Dialogic' version of VG uses PCM 8khz 8bit mono.
Also looks like for some reason you do not have the ConfigLine.xml file in VG's \data\ subdirectory... please place the attached file there.
ConfigLine.zip
Thanks for the reply! I added the file.
Now a new issue. I was working with ProPromts to convert my system files to the correct format as I never downloaded the current version of VG before installing the patch. I was hoping to avoid the lag time with getting a new registration. A few days ago all the line stats were fine. Today I get a Init Error: dlgc Dx_open(Dxxb1) error 2 (enoent|No such file or directory; invalid device name; file or path not found.) When I click ok, I get a pop up " registration not valid for this computer please check the registration details"
Register V6.0.1020 shows a Unique ID as M9C7C.
Please help. Do I need to download the new version first, and then install the patch in order to get the 11k,8bit, mono system files? Is their a way to just replace the system voice files and keep this Unique ID to avoid the lag time?
Dan Clements
This suggests your Config.xml file is not set up right...
Please post your Config.xml file from VG's \data\ subdirectory.
Passed on the registration code info to sales@voiceguide.com
Thanks for the help on this! My error, the reason for the issue was becasue I had failed to start the card with DCM! I am still having some other issues but will start a new post as it seam to non-related to this issue.
-Dan
