Sound File In Call Log Viewer
I can't play a sound file in the call log viewer. I choose File, Play Sound File, and nothing happens. I also tried Ctrl S. Do I need to turn this feature on or set it up before it will work?
Have you highlighted the entry in the log which you'd like to play?
Is the file SNDREC32.EXE in Windows' System32 directory?
The log viewer starts SNDREC32.EXE top play the sound file. You can change this to any other program by editing this section of VG.INI file:
[PlayRecordConfig]
RecEditor=SNDREC32.EXE
YES, I HIGHLIGHT THE SOUND FILE
YES, SNDREC32.EXE IS IN DIRECTORY. I USE SOUND RECORDER SUCCESSFULLY IN OTHER PARTS OF THE PROGRAM SUCH AS CREATING SCRIPTS.
NO, I DO NOT WANT TO CHANGE TO ANOTHER PROGRAM.
Which version of VoiceGuide do you have installed on the system?
What is the version number of the vglv.exe file in VoiceGuide's directory?
PLEASE DO NOT WRITE IN UPPER CASE IT MAKES IT HARDER TO READ WHAT YOU HAVE WRITTEN.
Voice Guide 5.2.3018
VGLV 5.2.0.1001
I recently upgraded voice guide. I also noticed that I have 2 separate sets of files in my computer since the upgrade. one folder is labeled IVG and the other folder is labeled voiceguide. They both have most of the same files. Mabie the new version is using some of the old files.
VGLV.EXE v5.2.0.1001 should work OK - that is what we are using on our test systems here..
Can you post a screenshot of what the log viewer entry that you are trying to play looks like.
Oh, and you can just uninstall IVG. IVG is an old version of VoiceGuide that was distributed for a while under a different name by another distributor.
how do I post a screen shot.
Also I don't know if this is related, but the call log does not always include all of the paths that were taken. For instance, a call came in and in the log it showed;
the caller as follows Welcom Menu/pressed 2/hang up in subscript. The caller did leave a message but voiceguide did not show "VmLvRec", as it does on some other calls. It does not seem to track the entire call every time.
To post a screenshot just use a graphics program to do a screen capture (eg: http://www.jasc.com/products/paintshoppro ) then post the .gif file here.
I'd be pretty surprised if the log did not include all of the entries relevant to the call...
Please post the extract from the Trace Log capturing the call as well as the .vgl log file for the script.
I do not have the capability to do a screenshot, I need another option.
What is the extract from the trace log and where do I find it.
What is the .vgl log file for the script.
.vgl file is created by VoiceGuide in the same directory as your script - it's the actual log file for the script...
I think this is what you want. I analized this and I notice that on one call, the .vgl file shows the call "Hang Up In Subscript" much earlier than in the Trace Log. The .vgl file agrees with the log in the call log viewer.
Look at the call that answered on 12/27/2004 9:09:19 AM and compare them. You will see what I am describing.
Voicemail_Server.vgl__
1227vgm.txt
I sent the 2 files in 2 separate replies. see previouse 2 replies, with attachments.
Then posted .vgl file has call records finishing on 23rd Dec...
Do you man compare the entries in the vgm trace log and the .vgl file?
vgm trace for call arriving at 09:09:19 shows that the caller was sent to a voicemail box and recorded a message there (14_1227091117_1_0_5182804784_.wav)
A voicemail message can be played from within the voicemail manager.
Is this what you are referring to or are you referring to something else?
I know how to listen to a message in the voicemail manager. As I stated in my first question in this forum, I can't play messages from the call log viewer. That is what we are trying to resolve. I sent you these files at your request. Please read the previous entries in the forum to refresh your memory. Note that the 2 files have different results for the same call. As I noted earlier, the call log viewer is not loging all of the entries. Could this be related to why I can't play the sound file from the call log viewer?
Do you think that your company will ever establish a live tech support line so that these issues can be resolved quicker?
Which calls are you comparing?
The vgm Debug Trace you posted captures 6 incoming calls on 27th December.
But the .vgl log file only shows calls up to the morning of 23rd December...
Please be more specific and indicate exactly what calls you are referring to and what data fields in the log file you are referring to.
As far as voicemail messages go - details of voicemail messages will not be saved in the script log file for the script that sends the call to a voicemail box - log files stores only the actions that happened within that script.
You can of course copy portions of the voicemail scripts into your own scripts - the voicemail scripts are saved in \system\vm\ subdirectory.
Phone support can be purchased - please see our WWW based order form.
Sorry, I don't know why the atachment did't show the entire file, but here is the line from "voicmail Server.vgs" that I am comparing to. Note that in this file, it shows a hang up before leaving the script, yet the trace log shows the call continue on.
[$RV_STARTTIME]{12/27/2004 9:09:21 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{BASHAW,LINDA -}[$RV_CIDNUMBER]{5185554784}[Welcome]{2}[No answer_MJ]{9}[Welcome]{3}[No answer]{9}[Hangup in Subscript]{12/27/2004 9:11:49 AM}
I am not really concerned with this issue, but I am bringing it to your attention because it may be related to the problem in concern, which is that I am not able to play a sound file from the call log viewer, which is a new feature in the latest upgrade. As I noted in my first post.
The Voicemail_Server.vgl log file will show only the sound files which have been recorded inside that script.
Once you jump to a different script (as you do when you use voicemail) then the details of what happens in that other script will be saved in that other script's log file.
eg: for voicemail the recording takes place in vmLm.vgs script in VG's \system\vm\ subdirectory.
You can of course copy the vmLm.vgs for your own purposes and modify it to suit your own needs and then jump to that new version of the vmLm.vgs script - and then the details of the recorded sound files will be stored in that new script's log file... how you do it is up to you but when using multiple scripts in your system just remember to look in the right log file for the information you need.
No, it doesn't - trace shows that call finished at 9:11:49 AM, which is the time that the log file shows as well. Look at your trace again:
090854.97  0 callstate OFFERING 66460 0 4
090854.97  0 ring 1
090855.93  0 Lev_CallerID [5182804784,BASHAW,LINDA -,]
090855.95  0 Lev_CallerID [5182804784,BASHAW,LINDA -,]
090900.94  0 ring 2
090906.98  0 ring 3
090913.04  0 ring 4
090919.08  0 ring 5
090919.08  0 Answer the call at 12/27/2004 9:09:19 AM
090919.08  0 lineAnswer(66460) => 66409
090919.08  0 callstate ACCEPTED 66460 0 0
090921.20  0 tapi  Reply (LineEvReply) ok 66409 0
090921.21  0 callstate CONNECTED 66460 0 0
090921.21  0 callstate CONNECTED 66460,0,0
090921.21  0 WorkingModeTAPI@Connected=
090921.21  0 WorkingModeScript@Connected=
090921.21  0 Inband detection not enabled
090921.21  0 StartLoadedVgs at 12/27/2004 9:09:21 AM
090921.21  0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\}
090921.21  0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server}
090921.21  0 rv    add [$RV_STARTTIME]{12/27/2004 9:09:21 AM}
090921.21  0 rv    add [$RV_DEVICEID]{0}
090921.21  0 rv    add [$RV_CIDNAME]{BASHAW,LINDA -}
090921.21  0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
090921.21  0 rv    add [$RV_CIDNUMBER]{5182804784}
090921.21  0 timer clear
090921.21  0 [Welcome] Number Input
090921.21  0 [Welcome] Playing (C:\Program Files\ivg\Scripts\Apartments\Main.wav)
090921.21  0 play set playid=742806
090921.29  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Apartments\Main.wav]
090921.29  0 timer clear
090921.29  0 wa(17765,74280600)
090931.83  0 dtmf 2   (66460,50,2)
090931.83  0 ScriptEventCode 50 iLineState=1300
090931.83  0 LsGetNbrsPlayWelcMsg 2
090934.41  0 PlaySoundStop err=0
090934.41  0 [Welcome] Number Input 2
090934.41  0 rv    add [Welcome]{2}
090934.43  0 timer clear
090934.43  0 [operator_MJ] Run Program
090934.43  0 eng run=sndrec32 /play /close C:\Program Files\ivg\Scripts\General\RING MJ.wav, window=NormalFocus, wait=0
090934.70  0 Run Program continuing...
090934.70  0 Going down Success path.
090934.71  0 timer clear
090934.71  0 [Play On Hold_MJ] Playing
090934.71  0 [Play On Hold_MJ] Playing (C:\Program Files\ivg\Scripts\General\Please Hold cHRISTMAS.wav)
090934.71  0 play set playid=756305
090934.80  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\General\Please Hold cHRISTMAS.wav]
090934.80  0 timer clear
090934.80  0 RunModule PLAY end
090934.80  0 wa(25496,75630500)
090958.73  0 dtmf 2   (66460,50,2)
090958.74  0 ScriptEventCode 50 iLineState=1100
090958.74  0 LsPlayMsg 2
090958.74  0 path {2} not found
091000.30  0 wb(75630500)
091000.30  0 play  end current play (playid=756305)
091000.30  0 ScriptEventCode 8001 iLineState=1100
091000.30  0 LsPlayMsg EV_PLAY_FINISHED
091000.30  0 timer set 10  EV_TIMEOUT_HANGUP
091000.30  0 timer set 2  EV_TIMEOUT_GOTOMODULE
091002.25  0 timer fired EV_TIMEOUT_GOTOMODULE
091002.25  0 ScriptEventCode 9002 iLineState=1101
091002.25  0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
091002.25  0 timer clear
091002.25  0 [No answer_MJ] Playing
091002.25  0 [No answer_MJ] Playing (C:\Program Files\ivg\Scripts\General\no answer.wav)
091002.27  0 play set playid=783855
091002.32  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\General\no answer.wav]
091002.32  0 timer clear
091002.32  0 RunModule PLAY end
091002.32  0 wa(6316,78385500)
091008.65  0 play  end current play (playid=783855)
091008.65  0 ScriptEventCode 8001 iLineState=1100
091008.65  0 LsPlayMsg EV_PLAY_FINISHED
091008.65  0 timer set 3  EV_TIMEOUT_REPLAYMSG
091010.62  0 dtmf 9   (66460,57,2)
091010.62  0 ScriptEventCode 57 iLineState=1101
091010.62  0 LsPlayMsgFinished 9
091010.62  0 rv    add [No answer_MJ]{9}
091010.63  0 timer clear
091010.63  0 [Welcome] Number Input
091010.63  0 [Welcome] Playing (C:\Program Files\ivg\Scripts\Apartments\Main.wav)
091010.63  0 play set playid=792217
091010.70  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Apartments\Main.wav]
091010.70  0 timer clear
091010.70  0 wa(17765,79221700)
091020.79  0 dtmf 3   (66460,51,2)
091020.79  0 ScriptEventCode 51 iLineState=1300
091020.80  0 LsGetNbrsPlayWelcMsg 3
091023.82  0 PlaySoundStop err=0
091023.82  0 [Welcome] Number Input 3
091023.82  0 rv    add [Welcome]{3}
091023.82  0 timer clear
091023.82  0 [operator] Run Program
091023.84  0 eng run=sndrec32 /play /close C:\Program Files\ivg\Scripts\General\RING ELLIE.wav, window=NormalFocus, wait=0
091024.07  0 Run Program continuing...
091024.07  0 Going down Success path.
091024.07  0 timer clear
091024.07  0 [Play On Hold] Playing
091024.07  0 [Play On Hold] Playing (C:\Program Files\ivg\Scripts\General\Please Hold cHRISTMAS.wav)
091024.09  0 play set playid=805676
091024.16  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\General\Please Hold cHRISTMAS.wav]
091024.16  0 timer clear
091024.16  0 RunModule PLAY end
091024.16  0 wa(25496,80567600)
091049.66  0 play  end current play (playid=805676)
091049.66  0 ScriptEventCode 8001 iLineState=1100
091049.66  0 LsPlayMsg EV_PLAY_FINISHED
091049.66  0 timer set 10  EV_TIMEOUT_HANGUP
091049.66  0 timer set 2  EV_TIMEOUT_GOTOMODULE
091050.54  0 dtmf 3   (66460,51,2)
091050.54  0 ScriptEventCode 51 iLineState=1101
091050.54  0 LsPlayMsgFinished 3
091050.54  0 path {3} not found
091051.62  0 timer fired EV_TIMEOUT_GOTOMODULE
091051.62  0 ScriptEventCode 9002 iLineState=1101
091051.62  0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
091051.62  0 timer clear
091051.62  0 [No answer] Playing
091051.62  0 [No answer] Playing (C:\Program Files\ivg\Scripts\General\no answer.wav)
091051.62  0 play set playid=833206
091051.68  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\General\no answer.wav]
091051.69  0 timer clear
091051.69  0 RunModule PLAY end
091051.69  0 wa(6316,83320600)
091057.43  0 dtmf 9   (66460,57,2)
091057.43  0 ScriptEventCode 57 iLineState=1100
091057.43  0 LsPlayMsg 9
091058.00  0 PlaySoundStop err=0
091058.00  0 rv    add [No answer]{9}
091058.02  0 timer clear
091058.02  0 [Welcome] Number Input
091058.02  0 [Welcome] Playing (C:\Program Files\ivg\Scripts\Apartments\Main.wav)
091058.02  0 play set playid=839615
091058.09  0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Apartments\Main.wav]
091058.09  0 timer clear
091058.09  0 wa(17765,83961500)
091110.45  0 dtmf 4   (66460,52,2)
091110.45  0 ScriptEventCode 52 iLineState=1300
091110.45  0 LsGetNbrsPlayWelcMsg 4
091112.85  0 PlaySoundStop err=0
091112.86  0 [Welcome] Number Input 4
091112.86  0 voicemail used: builtin (vgp)
091112.86  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgp at idx=2
091112.86  0 stack idx=1
091112.86  0 rv    add [scriptStart_Time]{12/27/2004 9:11:12 AM}
091112.86  0 rv    add [scriptStart_CalledFrom_Script]{C:\Program Files\VoiceGuide\Scripts\Voicemail Server\Voicemail Server.vgs}
091112.86  0 rv    add [scriptStart_CalledFrom_Module]{Welcome}
091112.86  0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\system\vm\}
091112.86  0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\system\vm}
091112.86  0 rv    add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
091112.86  0 rv    add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
091112.87  0 rv    add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
091112.87  0 rv    add [vmbId]{14}
091112.87  0 rv    add [VmLmStart]{4}
091112.88  0 timer clear
091112.88  0 [VmLmStart] Running vb script:[VmLmHangup.vgs]
091149.03  0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLmHangup.vgs at idx=3
091149.03  0 tapi  Reply (LineEvReply) ok 66426 0
091149.03  0 timer clear
091149.03  0 [VmLmHangup_ForwardLastMsg] Running VB Script...
091149.06  0 eng   copy of script ran: vbs_0_3.vbs
091149.08  0 Run Script waiting... (shellid=2396, process=912)
091149.09  0 timer set 1  EV_TIMEOUT_CHECKONSTATE
091149.19  0 cl    Vm_VmbConfig_Get 14, MsgLenMin
091149.19  0 vm    RecLen100ms=311, MinLength for VMB14=1
091149.19  0 cl    Vm_Event 0, FORWARD, 14, C:\Program Files\VoiceGuide\data\VmSave\14_1227091117_1_0_5182804784_.wav, ,
091149.19  0 vm    frwrd vmb 14
091149.20  0 rv    add [VoicemailMessage14]{C:\Program Files\VoiceGuide\data\VmSave\14_1227091117_1_0_5182804784_.wav}
091149.20  0 AddRVns [VoicemailMessage]{C:\Program Files\VoiceGuide\data\VmSave\14_1227091117_1_0_5182804784_.wav}
091149.20  0 Run (global):C:\WINDOWS\Media\CHIMES
091149.20  0 vm    frwrd vmb 14 end
091149.20  0 cl    Vm_Event 0, MSG_NEW, 14, , ,
091149.20  0 vm    MsgLamp control sVgIniPbx_MsgLampOnTrigger not set bu user. Assuming DISABLE.
091149.20  0 cl    Run_ResultReturn >>success<<
091149.21  0 rv    add [VmLmHangup_ForwardLastMsg_ResultReturn]{success}
091149.21  0 path {success} not found
091149.21  0 cl    module's runwait=1, WavPlayHasNowFinished=0
091149.21  0 rv    add [Hangup Time]{12/27/2004 9:11:49 AM}
091149.21  0 Hanging up call... [Run_ResultReturn - no path match (same vgm)]
091149.21  0 HangupCall_Common Mode=AfterHangupRun
091149.21  0 ReinitTelephony due to IDLE
091149.21  0 tapic lineDeallocateCall(MainCall:66460) 0
091149.98  0 lineOpen(0)=>
091149.99  0 Waiting for a call...
Let's get back to the problem in concern. the only reason that I sent you those files is because you asked for them. this was supposed to help you determine the problem that I originally wanted to resolve, which is;
Please read the previous post's to refresh your memory so that we don't keep going over the same things.
Which log file are you viewing?
The log file which you posted does not include any entries of any recorded filenames.
I suspect that you are doing the recording in a different script...
As mentioned in last post:
You can't play a voicemail message from the log file of a script from which you just transfer the call to a voicemail box... If you want to play the voicemail message locally then use the Voicemail Manager or look at the log file vmLm.vgl in VoiceGuide's \system\vm\ subdirectory.
Thank You that worked.
Next Question.
Can I save a voicemail message in the computer, yet delete it from the voicemail manager and if so, how.
Voicemail manager will show all the voicemail message files in directory \data\VmSave\
If the sound files is moved out of that directory it will no longer show up in the voicemail manager.
You can just modify the voicemail scripts to save the file in another directory, or move the files after they were saved.
