2 Rings Issue
I hope somebody will have the answer about that. I try to figure out where I can change how much ring the dialer wait until it begin to start. Because actually he start to send messages after 2 rings but in my outdialque file it should ring during 60 seconds.... Any help would be greatly appreciated. Thank's
Dom
Inside the mdb
ID PhoneNumber ActivateTime DayTimeStart DayTimeStop DaysCallAllowed LineSelection Priority AnnounceMessage Script OnAnswerMachine RV AnswerTimeout CallRetriesLeft DelayBetweenRetries OnNotConnected EscalationCalls
29 667,0 412152316 0 2359 MoTuWeThFrSaSu ,, 1 AcceptAutoCall.wav C:\Program Files\VoiceGuide\Scripts\Answer and Record\alarm.vgs AcceptAutoCall.wav [CustomerID]{44563} 60 0 0 none
my log
231910.65 0 dial start any summary:|1:rdy=0|
231911.60 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
231911.60 1 ScriptEventCode 9013 iLineState=900
231911.66 1 dial [30,667,0,0,0,2359,MoTuWeThFrSaSu,,,,1,AcceptAutoCall.wav,C:\Program Files\VoiceGuide\Scripts\Answer and Record\alarm.vgs,AcceptAutoCall.wav,[CustomerID]{44563},60,0,0,,none]
231911.67 0 dial callque update id=30 next call time 0412152321
231911.68 0 dial callque DB update returned
231911.68 1 dial found entry: tel[667,0] ann[AcceptAutoCall.wav] vgs[C:\Program Files\VoiceGuide\Scripts\Answer and Record\alarm.vgs] am[AcceptAutoCall.wav]
231911.70 1 Dialing: 667,0
231911.70 1 MakeCall => 66495
231911.71 1 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE
231911.71 1 TapiCbTrigSet 66495 7002
231911.73 0 dial start any summary:|1:dial=0|
231911.73 1 tapi Reply (LineEvReply) ok 66495 0
231911.73 1 TapiCbTrigClear
231911.74 1 callstate DIALING 66393 0 0
231911.75 1 callstate PROCEEDING 66393 0 0
231918.67 1 callstate CONNECTED 66393 0 0
231918.67 1 callstate CONNECTED 66393,0,0
231918.69 1 WorkingModeTAPI@Connected=
231918.69 1 WorkingModeScript@Connected=
231918.70 1 rv add [CustomerID]{44563}
231918.70 1 rv add [OutDial_RetriesLeft]{0}
231918.70 1 rv add [$RV_STARTTIME]{15.12.2004 23:19:18}
231918.70 1 rv add [$RV_DEVICEID]{1}
231918.70 1 rv add [$RV_CIDNAME]{}
231918.71 1 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
231918.71 1 rv add [$RV_CALLEDNUMBER]{667,0}
231918.71 1 Dialing: Playing introduction message
231918.73 1 play set playid=728140
231919.48 1 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Answer and Record\AcceptAutoCall.wav]
231919.48 1 timer clear
231919.48 1 wa(6672,72814000)
231926.16 1 play end current play (playid=728140)
231926.18 1 ScriptEventCode 8001 iLineState=1150
231926.19 1 LsDialoutPlayAcceptAuto EV_PLAY_FINISHED
231926.20 1 Replay 1/10 (see VG.INI section [VGDialer] entry AnnReplay)
231926.22 1 play set playid=735631
231926.37 1 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Answer and Record\AcceptAutoCall.wav]
231926.38 1 timer clear
231926.40 1 wa(6672,73563100)
231930.65 0 btn Hangup on line 1
231930.66 1 ScriptEventCode 9001 iLineState=1150
231930.66 1 LsDialoutPlayAcceptAuto EV_TIMEOUT_HANGUP
231930.66 1 rv add [Hangup Time]{15.12.2004 23:19:30}
231930.67 1 Hanging up call...
231930.70 1 RecSoundStop ok
231933.09 1 PlaySoundStop err=0
231933.09 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
231933.10 1 Waiting for a call...
231933.11 1 fnHangupCall end
231933.21 1 callstate DISCONNECTED 66393 1 0
231933.21 1 ScriptEventCode 9250 iLineState=900
231933.21 1 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
231933.22 1 rv add [Hangup Time]{15.12.2004 23:19:33}
231933.22 1 Hanging up call...
231933.23 1 RecSoundStop ok
231933.23 1 PlaySoundStop err=0
231933.24 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
231933.24 1 Waiting for a call...
231933.25 1 fnHangupCall end
231933.25 1 callstate IDLE 66393 0 0
231933.25 1 WorkingMode@Idle=
231933.26 1 timer clear
231933.26 1 LineState(iLineId).iVgsIdx = 0
231933.27 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
231933.27 1 tapi Reply (LineEvReply) ok 66342 0
231933.28 1 tapi Reply (LineEvReply) ok 66359 0
231934.18 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
231934.18 1 ScriptEventCode 9008 iLineState=900
231934.18 1 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
231934.19 1 ReinitTelephony due to IDLE
231934.19 1 tapic lineDeallocateCall(MainCall:66393) 0
231934.28 1 lineOpen(1)=>
231934.28 1 Waiting for a call...
231934.29 1 LineHandle=66308
231934.29 1 timer set 10 EV_TIMEOUT_ATERIDLE_ALLOWOUT
231935.13 0 dial start any summary:|1:rdy=0|
231936.14 0 dial start any summary:|1:rdy=0|
231937.16 0 dial start any summary:|1:rdy=0|
231938.16 0 dial start any summary:|1:rdy=0|
231939.17 0 dial start any summary:|1:rdy=0|
231940.18 0 dial start any summary:|1:rdy=0|
231941.20 0 dial start any summary:|1:rdy=0|
231942.20 0 dial start any summary:|1:rdy=0|
231943.22 0 dial start any summary:|1:rdy=0|
231944.23 0 dial start any summary:|1:rdy=0|
231944.33 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
231944.33 1 ScriptEventCode 9013 iLineState=900
I think you must be using a voice modem, right?
from: http://www.voiceguide.com/vghelp/html/DialListInto.htm
Prompt message if a voice modem is used to dial
If a voice modem is used and this file is specified, then this sound file will be played in a loop after the phone number is dialed, and the recipient of the call will have to press a button before the main VoiceGuide script will be executed, or the main message played. If no prompt message is needed this entry can be left blank.
The default message supplied with VoiceGuide (AcceptAutoCall.wav) says: "This is an automated call, please press any number on your telephone keypad to accept this call."
Voice modems cannot tell when a call is answered - that is why they need tom play the AcceptAutoCall.wav in a loop to let the person answering the call to indicate to the voice modem that the call has been answered.
Correct it's a USB voice modem. My question in fact is that after 2 rings the software stop ringing even if there is no answer on the other side. Because of the that if the guy on the other side don't pick the phone before the second ring he miss the call. It's not very practicall to try to reach somebody with only 2 ring. Is there a way to increase the number of ring somewhere in this software? Thank's in advance.
Well I found an answer on my issue it was not a software settings but a deviation that was made on the targeted phone who made it deviated somewhere else after 2 rings :)
