Vbs Script
hi.. i developped this script in the trial demo, and worked fine :
Dim xlApp, xlBook, xlSht
Dim filename, value1, value2, value3, value4
filename = "c:\test.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
value1 = xlSht.Cells(3, 1)
valuen = xlSht.Cells(3, 2)
xlBook.Close False
xlApp.Quit
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
on error resume next
xlApp.DisplayAlerts = False
value1=value1-1
If value1 <= 0 Then
value1=valuen
voie="gagne"
Else
voie="perdu"
End If
vg.Run_ResultReturn $RV_DEVICEID, "ok"
'write data into the spreadsheet
xlSht.Cells(3, 1) = value1
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
'always deallocate after use...
set xlSht = Nothing
Set xlApp = Nothing
vg.RvSet $RV_LINEID, "counter01", value1
vg.Run_ResultReturn $RV_DEVICEID, voie
set vg = Nothing
so i buy the pro version; at 99 $, and the line hang up when the script is running ? why ?
the trace is :
202828,07 6 linedevstate 2048 0 0
202828,07 6 callstate OFFERING 66051 0 4
202828,07 6 Answer the call at 30/11/2004 20:28:28
202828,09 6 lineAnswer(66051) => 66000
202828,09 6 callinfo CALLEDID
202828,10 6 callinfo ORIGIN
202828,10 6 ring 0
202828,63 6 callstate CONNECTED 66051 1 0
202828,63 6 callstate CONNECTED 66051,1,0
202828,63 6 WorkingModeTAPI@Connected=
202828,63 6 WorkingModeScript@Connected=
202828,67 6 Inband detection not enabled
202828,67 6 StartLoadedVgs at 30/11/2004 20:28:28
202828,67 6 AddRVns [scriptsPath]{C:\Documents and Settings\dave\Bureau\LE COMPTE A REBOUR\}
202828,67 6 AddRVns [scriptPath]{C:\Documents and Settings\dave\Bureau\LE COMPTE A REBOUR}
202828,67 6 rv add [$RV_STARTTIME]{30/11/2004 20:28:28}
202828,69 6 rv add [$RV_DEVICEID]{6}
202828,69 6 rv add [$RV_CIDNAME]{}
202828,69 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
202828,70 6 rv add [$RV_CIDNUMBER]{}
202828,70 6 tapi Reply (LineEvReply) ok 66000 0
202828,70 6 callinfo MONITORMODES
202828,70 6 timer clear
202828,70 6 [Play 1] Playing
202828,72 6 [Play 1] Playing (\\X-H9TAKYG8WW5PW\SharedDocs\final\intro.wav)
202828,73 6 play set playid=164494
202828,76 6 PlaySoundStart ok [\\X-H9TAKYG8WW5PW\SharedDocs\final\intro.wav]
202828,77 6 timer clear
202828,77 6 RunModule PLAY end
202828,77 6 wa(10311,16449400)
202828,77 6 callinfo MONITORMODES
202838,27 6 dtmf 2 (66051,50,2)
202838,27 6 ScriptEventCode 50 iLineState=1100
202838,27 6 LsPlayMsg 2
202838,33 6 PlaySoundStop err=0
202838,33 6 rv add [Play 1]{2}
202838,34 6 timer clear
202838,34 6 [Play 4] Playing
202838,34 6 [Play 4] Playing (\\X-H9TAKYG8WW5PW\SharedDocs\choix2.wav)
202838,35 6 play set playid=174118
202838,37 6 PlaySoundStart ok [\\X-H9TAKYG8WW5PW\SharedDocs\choix2.wav]
202838,37 6 timer clear
202838,38 6 RunModule PLAY end
202838,38 6 wa(30887,17411800)
202838,39 6 callinfo MONITORMODES
202841,15 6 dtmf 2 (66051,50,2)
202841,16 6 ScriptEventCode 50 iLineState=1100
202841,16 6 LsPlayMsg 2
202841,23 6 PlaySoundStop err=0
202841,23 6 rv add [Play 4]{2}
202841,23 6 timer clear
202841,23 6 [Run VB Script 19] Running VB Script...
202841,23 6 rv replace start (strlen>500)
202841,24 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Documents and Settings\dave\Bureau\LE COMPTE A REBOUR\}[scriptPath]{C:\Documents and Settings\dave\Bureau\LE COMPTE A REBOUR}[$RV_STARTTIME]{30/11/2004 20:28:28}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Play 1]{2}[Play 4]{2}
202841,24 6 eng copy of script ran: vbs_6_1.vbs
202841,28 6 Run Script waiting... (shellid=1388, process=1464)
202841,28 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
202842,13 6 cl RvSet counter01, 47
202842,13 6 ERROR: COM interface not supported in this version.
202842,16 6 cl Run_ResultReturn >>perdu<<
202842,16 6 ERROR: COM interface not supported in this version.
202842,20 6 timer fired EV_TIMEOUT_CHECKONSTATE
202842,20 6 ScriptEventCode 9007 iLineState=1501
202842,20 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
202842,20 6 task completed (shellid=1388, process=1464) vgm=11, iRunWait=1, iRunWait_ExeResult_NextVgm=0
202842,21 6 No information returned from program to VG (no VGRUNRESULT_6.TXT or SHLRESLT.TXT)
202842,21 6 rv add [Hangup Time]{30/11/2004 20:28:42}
202842,21 6 Hanging up call... [WaitTillFinished - next module not specified]
202842,23 6 RecSoundStop ok
202842,23 6 PlaySoundStop err=0
202842,23 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
202842,23 6 fnHangupCall end
202842,28 6 linedevstate 2048 0 0
202842,28 6 callstate IDLE 66051 0 0
202842,30 6 WorkingMode@Idle=
202842,30 6 timer clear
202842,30 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
202842,30 6 tapi Reply (LineEvReply) ok 66255 0
202843,24 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
202843,24 6 ScriptEventCode 9008 iLineState=900
202843,26 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
202843,26 6 ReinitTelephony due to IDLE
202843,27 6 tapic lineDeallocateCall(MainCall:66051) 0
202843,43 6 lineOpen(6)=>
202843,43 6 Waiting for a call...
202843,43 6 LineHandle=66290
202843,44 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
202844,26 0 dial start any summary:|6:rdy=0|
202845,27 0 dial start any summary:|6:rdy=0|
202846,28 0 dial start any summary:|6:rdy=0|
202846,44 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
202846,44 6 ScriptEventCode 9013 iLineState=900
i've bought it yesterday. Can i cancel it, and take the Enterprise version ????
Upgrades to different version within the first month are for the difference in price.
(this is mentioned on our WWW order for as well)
