D120 Jct Marking Board Dead.
I have installed a D120 JCT card in a system(With Windows 2000 server as OS and service pack 4). The card has been detected in DCM. But could not start.
While starting it gives:
"Failed to detect board(s)
Error Configuring the TDM Bus".
And in UDD it gives the following information.
System Download ....
ERROR from pCTBB_SetClientParm (bus type support level):
CTBB_ERROR_INVALID_CLIENT_TYPE: Client type (technology) invalid
D/120JCT-LS-Rev 2 (PCI ID 0) Download .. Firmware Version 0.00
1 Dialogic Board Successfully Installed
Download failure: Type: D/120JCT-LS-Rev 2, ID: 0x0.
Results buffer:
0x0000 0x0020 0x4413 0x0000 0x0000 0x0000 0x0000 0x0002
Marking board dead.
I tried to put the card in other pc with (Windows 2000 prof as OS). In that system it is working. I can run sample appli also.
In 2000 server initially an pci device and Dialogic card has also same IRQ value as "5". So I disable the pther pci device and assign IRQ value "5" to dialogic card.
Anybody could give any suggestion to solve this.
i have install the d120 JCT LS card in the win2000 os. but when in run the udd then i get the:
the System Download ....
Results buffer:
Marking board dead.
can u please suggest me what the proble but the card is work fine..
thanks
You should contact Intel/Dialogic technical support regarding issues/questions you have with Intel/Dialogic hardware.
(NB. UDD has been known in past to report a problem while cards at the same were actually working fine...)
