Announced Transfer Problem With V5.2.3018
Hi
I can't get announced transfer to work on version 5.2.3018. It worked fine on 4.8.45.
Please help. Here's the log
103749.75 5 linedevstate 2048 0 0
103749.75 5 callstate OFFERING 65673 0 4
103749.75 5 Answer the call at 10/26/2004 10:37:49 AM
103749.75 5 lineAnswer(65673) => 65724
103749.75 5 callinfo CALLEDID
103749.75 5 callinfo ORIGIN
103749.75 5 ring 0
103750.28 5 callstate CONNECTED 65673 1 0
103750.28 5 callstate CONNECTED 65673,1,0
103750.28 5 WorkingModeTAPI@Connected=
103750.28 5 WorkingModeScript@Connected=
103750.30 5 Inband detection not enabled
103750.30 5 StartLoadedVgs at 10/26/2004 10:37:50 AM
103750.30 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}
103750.30 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}
103750.30 5 rv add [$RV_STARTTIME]{10/26/2004 10:37:50 AM}
103750.30 5 rv add [$RV_DEVICEID]{5}
103750.30 5 rv add [$RV_CIDNAME]{}
103750.30 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
103750.30 5 rv add [$RV_CIDNUMBER]{}
103750.30 5 tapi Reply (LineEvReply) ok 65724 0
103750.30 5 callinfo MONITORMODES
103750.30 5 timer clear
103750.30 5 [Determine work hours] Evaluate [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))]
103750.30 5 rv replace start: [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 17))]
103750.30 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/26/2004 10:37:50 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
103750.30 5 rv replace end: [(2 < 6) and ((10 >= 9) and (10 < 17))]
103750.30 5 .Eval((2 < 6) and ((10 >= 9) and (10 < 17)))
103750.31 5 AddRVns [Determine work hours_Input]{(2 < 6) and ((10 >= 9) and (10 < 17))}
103750.31 5 AddRVns [Determine work hours]{True}
103750.31 5 AddRVns [time]{True}
103750.31 5 Eval Expr result:[True] stored in $RV[time]
103750.31 5 timer clear
103750.31 5 [Welcome Office Hours] Playing
103750.31 5 [Welcome Office Hours] Playing (Office hours.wav)
103750.31 5 play set playid=963906
103750.33 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\Office hours.wav]
103750.33 5 timer clear
103750.33 5 RunModule PLAY end
103750.33 5 wa(13538,96390600)
103750.34 5 callinfo MONITORMODES
103758.23 5 dtmf 3 (65673,51,2)
103758.23 5 ScriptEventCode 51 iLineState=1100
103758.23 5 LsPlayMsg 3
103758.28 5 PlaySoundStop err=0
103758.28 5 rv add [Welcome Office Hours]{3}
103758.30 5 timer clear
103758.30 5 [DB QueryMenu] DB Query
103758.30 5 db Jet mode used (To use ODBC mode specify ODBC Connect string)
103758.30 5 rv replace start: [sELECT IsInOffice, Ext FROM IsInOffice WHERE MainMenu = $RV[Welcome Office Hours]]
103758.30 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/26/2004 10:37:50 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(2 < 6) and ((10 >= 9) and (10 < 17))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{3}
103758.30 5 rv replace end: [sELECT IsInOffice, Ext FROM IsInOffice WHERE MainMenu = 3]
103758.30 5 db About to execute a Retrieve type operation [sELECT IsInOffice, Ext FROM IsInOffice WHERE MainMenu = 3]
103758.30 5 db [DB QueryMenu] row count=1
103758.30 5 rv add [DB QueryMenu_RowCount]{1}
103758.30 5 db get RecordsetGetRowsMax
103758.31 5 db get 999 records. (row count=1)
103758.31 5 db update RVs
103758.31 5 db about to close dbDbqDatabase
103758.31 5 db going down path [True]
103758.31 5 timer clear
103758.31 5 [Evaluate In or Out Menu] Evaluate [$RV[DB QueryMenu_1_1] = 1]
103758.31 5 rv replace start: [$RV[DB QueryMenu_1_1] = 1]
103758.31 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/26/2004 10:37:50 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(2 < 6) and ((10 >= 9) and (10 < 17))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{3}[DB QueryMenu_RowCount]{1}[DB QueryMenu_1_1]{1}[DB QueryMenu_2_1]{1643}
103758.31 5 rv replace end: [1 = 1]
103758.31 5 .Eval(1 = 1)
103758.31 5 AddRVns [Evaluate In or Out Menu_Input]{1 = 1}
103758.31 5 AddRVns [Evaluate In or Out Menu]{True}
103758.31 5 Eval Expr result:[True]
103758.33 5 [Play Tnf to Extension Menu] Playing
103758.33 5 [Play Tnf to Extension Menu] Playing (TransferCall.wav)
103758.33 5 play set playid=971921
103758.33 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\TransferCall.wav]
103758.33 5 timer clear
103758.33 5 RunModule PLAY end
103758.33 5 wa(2031,97192100)
103758.33 5 callinfo MONITORMODES
103800.44 5 play end current play (playid=971921)
103800.44 5 ScriptEventCode 8001 iLineState=1100
103800.44 5 LsPlayMsg EV_PLAY_FINISHED
103800.44 5 timer set 10 EV_TIMEOUT_HANGUP
103800.44 5 timer set 0 EV_TIMEOUT_GOTOMODULE
103800.44 5 ScriptEventCode 9002 iLineState=1101
103800.44 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
103800.44 5 timer clear
103800.44 5 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
103800.81 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
103800.81 5 ScriptEventCode 9012 iLineState=1900
103800.81 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
103800.81 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103800.81 5 rv replace start: [$RV[DB QueryMenu_2_1]]
103800.81 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/26/2004 10:37:50 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(2 < 6) and ((10 >= 9) and (10 < 17))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{3}[DB QueryMenu_RowCount]{1}[DB QueryMenu_1_1]{1}[DB QueryMenu_2_1]{1643}[Evaluate In or Out Menu_Input]{1 = 1}[Evaluate In or Out Menu]{True}
103800.81 5 rv replace end: [1643]
103800.81 5 [Tnf to Extension Menu] Announced Transfer to 1643 (TAPI)
103800.81 5 lineSetupTransfer(65673,0) in LsXferStart => 65707
103802.81 5 tapi Reply (LineEvReply) ok 65707 0
103802.81 5 callstate ONHOLDPENDTRANSFER 65673 0 0
103802.83 5 linedevstate 2048 0 0
103802.83 5 callstate DIALTONE 65758 2 0
103822.80 0 sys cleanup Start
103822.80 0 sys cleanup End
103833.63 5 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103833.63 5 ScriptEventCode 9021 iLineState=1900
103833.63 5 LsXferStart EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103833.63 5 Transfer timed out
103833.63 5 lineDrop(65758) in DropConsultingCall_Fail => 65588
103833.63 5 TapiCbTrigSet 65588 7004
103833.88 5 linedevstate 2048 0 0
103833.88 5 callstate IDLE 65758 0 0
103833.88 5 WorkingMode@Idle=DroppingConsultCall
103833.88 5 ignoring this IDLE
103833.89 5 callstate CONNECTED 65673 1 0
103833.89 5 callstate CONNECTED 65673,1,0
103833.89 5 WorkingModeTAPI@Connected=DroppingConsultCall
103833.89 5 WorkingModeScript@Connected=
103833.89 5 original call re-connected
103833.89 5 tapi Reply (LineEvReply) ok 65588 0
103833.89 5 lineDeallocateCall(65758) => 0
103833.89 5 timer clear
103833.89 5 [Play Goodbye] Playing
103833.89 5 [Play Goodbye] Playing (goodbye.wav)
103833.89 5 play set playid=7484
103833.91 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\goodbye.wav]
103833.91 5 timer clear
103833.91 5 RunModule PLAY end
103833.91 5 TapiCbTrigClear
103833.91 5 wa(3711,748400)
103833.91 5 callinfo MONITORMODES
103837.63 5 wb(748400)
103837.69 5 play end current play (playid=7484)
103837.69 5 ScriptEventCode 8001 iLineState=1100
103837.69 5 LsPlayMsg EV_PLAY_FINISHED
103837.69 5 timer set 10 EV_TIMEOUT_HANGUP
103837.69 5 timer set 1 EV_TIMEOUT_GOTOMODULE
103838.67 5 timer fired EV_TIMEOUT_GOTOMODULE
103838.67 5 ScriptEventCode 9002 iLineState=1101
103838.67 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
103838.67 5 timer clear
103838.67 5 rv add [Hangup Time]{10/26/2004 10:38:38 AM}
103838.67 5 Hanging up call... [Hangup Module]
103838.67 5 RecSoundStop ok
103838.67 5 PlaySoundStop err=0
103838.67 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103838.67 5 fnHangupCall end
103838.70 5 linedevstate 2048 0 0
103838.72 5 callstate IDLE 65673 0 0
103838.72 5 WorkingMode@Idle=
103838.72 5 timer clear
103838.72 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
103838.72 5 tapi Reply (LineEvReply) ok 65571 0
103839.77 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
103839.77 5 ScriptEventCode 9008 iLineState=900
103839.77 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
103839.77 5 ReinitTelephony due to IDLE
103839.77 5 tapic lineDeallocateCall(hConsultCall_OriginalCallHandleBeforeTransferAttempted:65673) 0
103839.77 5 tapic lineDeallocateCall(MainCall:65673) LINEERR_INVALCALLHANDLE [80000018]
103839.80 5 lineOpen(5)=>
103839.80 5 Waiting for a call...
103839.80 5 LineHandle=65622
103839.80 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103839.81 0 btn Hangup on line 5
103839.81 5 rv add [Hangup Time]{10/26/2004 10:38:39 AM}
103839.81 5 Hanging up call...
103839.81 5 eng exit HangupCall_Common as LineCallState=IDLE already
103840.39 0 dial start any summary:|5:rdy=0|
103841.39 0 dial start any summary:|5:rdy=0|
103842.39 0 dial start any summary:|5:rdy=0|
103843.08 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103843.08 5 ScriptEventCode 9013 iLineState=900
103843.47 5 linedevstate 2048 0 0
103843.47 5 callstate OFFERING 65656 0 4
103843.47 5 Answer the call at 10/26/2004 10:38:43 AM
103843.47 5 lineAnswer(65656) => 66493
103843.47 5 callinfo CALLEDID
103843.47 5 callinfo ORIGIN
103843.47 5 ring 0
103844.02 5 callstate CONNECTED 65656 1 0
103844.02 5 callstate CONNECTED 65656,1,0
103844.02 5 WorkingModeTAPI@Connected=
103844.02 5 WorkingModeScript@Connected=
103844.02 5 Inband detection not enabled
103844.02 5 StartLoadedVgs at 10/26/2004 10:38:44 AM
103844.02 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}
103844.02 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}
103844.02 5 rv add [$RV_STARTTIME]{10/26/2004 10:38:44 AM}
103844.02 5 rv add [$RV_DEVICEID]{5}
103844.03 5 rv add [$RV_CIDNAME]{}
103844.03 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
103844.03 5 rv add [$RV_CIDNUMBER]{}
103844.03 5 tapi Reply (LineEvReply) ok 66493 0
103844.03 5 callinfo MONITORMODES
103844.03 5 ERROR RunModule called while iHangupCalledForThisLine>0 (strWorkingModeScript=)
103844.89 0 btn Hangup on line 5
103844.89 5 ScriptEventCode 9001 iLineState=5900
103844.89 5 rv add [Hangup Time]{10/26/2004 10:38:44 AM}
103844.89 5 Hanging up call... [LsModuleTransition]
103844.89 5 RecSoundStop ok
103844.89 5 PlaySoundStop err=0
103844.89 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103844.91 5 fnHangupCall end
103846.05 5 linedevstate 2048 0 0
103846.05 5 callstate IDLE 65656 0 0
103846.05 5 WorkingMode@Idle=
103846.05 5 timer clear
103846.05 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
103846.05 5 tapi Reply (LineEvReply) ok 66476 0
103847.13 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
103847.13 5 ScriptEventCode 9008 iLineState=900
103847.13 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
103847.13 5 ReinitTelephony due to IDLE
103847.13 5 tapic lineDeallocateCall(MainCall:65656) 0
103847.16 5 lineOpen(5)=>
103847.16 5 Waiting for a call...
103847.16 5 LineHandle=66459
103847.16 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103847.39 0 dial start any summary:|5:rdy=0|
103848.39 0 dial start any summary:|5:rdy=0|
103849.39 0 dial start any summary:|5:rdy=0|
103850.39 0 dial start any summary:|5:rdy=0|
103850.44 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103850.44 5 ScriptEventCode 9013 iLineState=900
Please try setting in VG.INI file, in section [PBX] both of the entries below to be "Generate".
TransferControl_Modem
TransferControl_TelBoards
Then restart VoiceGuide and try the transfer again.
