Auto Dialer
Hello!
I have Voiceguide Enterprise running on a E1 connection.
My problem with auto dialer is:
The numbers I have to make calls to are all in the following format:
(02161) 644992
(033745) 70913
(03371) 641353
(02241) 342798
(07621) 87841
(036334) 53391
(039452) 8391
(04131) 188934
(04362) 8489
(0211) 306402
(06781) 260721
(07131) 255144
(06292) 1603
(0911) 639467
(030) 29005334
(0471) 65286
(033731) 17040
(0211) 499293
(07062) 63638
(03944) 64159
(09704) 7398
(0221) 353486
(0371) 71616
(04181) 33458
(05522) 506620
(07131) 972615
(035955) 74455
(03475) 682507
(0431) 204212
(05035) 1453
(05585) 1226
(030) 51098177
(03377) 302094
So as you can see each number comes with the area code in brackets. If I import the numers into autodialer as they are, autodialer won't call them because of the brackets. So I always have to get rid of the brackets by manually taking them away. This is verry annoying over time. Can you suggest me what to do? Is there a software that can do the job, or maybee Excell?
Any help is much appreciated!
Best regards
Alex
I feed numbers to the dialer using XML and I have brackets and dashes in my numbers and VG dials them fine. i.e. (xxx) xxx-xxxx
How are you feeding in the numbers and where are you getting them from?
I copy and paste them directly into the phone numbers box In the Telephone Numbers Loader.
What do you mean with:I feed numbers to the dialer using XML
Can you please explane how to do that.
Best regards
Alex
