Transfer Problem
Hi
I can't get announce transfer to work with D/4PCI on Win XP Pro. The caller hears nothing then the line drops. The extension does not ring.
Here's the log:
180833.85 0 dial start any summary:|5:rdy=0|
180834.88 0 dial start any summary:|5:rdy=0|
180835.18 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
180835.19 5 ScriptEventCode 9013 iLineState=900
180910.70 5 linedevstate 2048 0 0
180910.70 5 callstate OFFERING 65877 0 4
180910.70 5 Answer the call at 10/6/2004 6:09:10 PM
180910.71 5 lineAnswer(65877) => 65860
180910.73 5 callinfo CALLEDID
180910.73 5 callinfo ORIGIN
180910.74 5 ring 0
180911.30 5 callstate CONNECTED 65877 1 0
180911.30 5 callstate CONNECTED 65877,1,0
180911.30 5 WorkingModeTAPI@Connected=
180911.30 5 WorkingModeScript@Connected=
180911.32 5 Inband detection not enabled
180911.32 5 StartLoadedVgs at 10/6/2004 6:09:11 PM
180911.32 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}
180911.32 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}
180911.34 5 rv add [$RV_STARTTIME]{10/6/2004 6:09:11 PM}
180911.34 5 rv add [$RV_DEVICEID]{5}
180911.34 5 rv add [$RV_CIDNAME]{}
180911.34 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
180911.36 5 rv add [$RV_CIDNUMBER]{}
180911.36 5 tapi Reply (LineEvReply) ok 65860 0
180911.38 5 callinfo MONITORMODES
180911.39 5 timer clear
180911.39 5 [Determine work hours] Evaluate [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 20))]
180911.39 5 rv replace start: [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 20))]
180911.41 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:09:11 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
180911.41 5 rv replace end: [(3 < 6) and ((18 >= 9) and (18 < 20))]
180911.43 5 .Eval((3 < 6) and ((18 >= 9) and (18 < 20)))
180911.44 5 AddRVns [Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}
180911.44 5 AddRVns [Determine work hours]{True}
180911.45 5 AddRVns [time]{True}
180911.46 5 Eval Expr result:[True] stored in $RV[time]
180911.46 5 timer clear
180911.48 5 [Welcome Office Hours] Playing
180911.48 5 [Welcome Office Hours] Playing (Office hours.wav)
180911.48 5 play set playid=515741
180911.61 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\Office hours.wav]
180911.62 5 timer clear
180911.63 5 RunModule PLAY end
180911.64 5 wa(13538,51574100)
180911.66 5 callinfo MONITORMODES
180912.93 5 dtmf 1 (65877,49,2)
180912.94 5 ScriptEventCode 49 iLineState=1100
180912.95 5 LsPlayMsg 1
180913.03 5 PlaySoundStop err=0
180913.04 5 rv add [Welcome Office Hours]{1}
180913.09 5 timer clear
180913.10 5 [Get Extension] Number Input
180913.10 5 [Get Extension] Playing (ExtensionNum.wav)
180913.11 5 play set playid=517363
180913.22 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\ExtensionNum.wav]
180913.23 5 timer clear
180913.25 5 wa(2558,51736300)
180913.26 5 callinfo MONITORMODES
180914.61 5 dtmf 1 (65877,49,2)
180914.61 5 ScriptEventCode 49 iLineState=1300
180914.62 5 LsGetNbrsPlayWelcMsg 1
180914.71 5 PlaySoundStop err=0
180914.72 5 [Get Extension] Number Input 1
180914.73 5 path {1} not found
180914.74 5 timer set 5 EV_TIMEOUT_GOTOMODULE
180914.84 5 dtmf 6 (65877,54,2)
180914.86 5 ScriptEventCode 54 iLineState=1301
180914.86 5 LsGetNbrsRxDigits 6
180914.88 5 [Get Extension] Number Input 16
180914.88 5 path {16} not found
180914.89 5 timer set 5 EV_TIMEOUT_GOTOMODULE
180915.13 5 dtmf 4 (65877,52,2)
180915.13 5 ScriptEventCode 52 iLineState=1301
180915.14 5 LsGetNbrsRxDigits 4
180915.15 5 [Get Extension] Number Input 164
180915.16 5 path {164} not found
180915.16 5 timer set 5 EV_TIMEOUT_GOTOMODULE
180915.32 5 dtmf 3 (65877,51,2)
180915.32 5 ScriptEventCode 51 iLineState=1301
180915.34 5 LsGetNbrsRxDigits 3
180915.34 5 [Get Extension] Number Input 1643
180915.36 5 path {1643} not found
180915.36 5 timer set 5 EV_TIMEOUT_GOTOMODULE
180915.38 5 timer clear
180915.39 5 rv add [Get Extension]{1643}
180915.39 5 path {1643} not found
180915.41 5 AddRVns [Get Extension_PathTaken]{success}
180915.41 5 timer clear
180915.43 5 [DB Query] DB Query
180915.43 5 db Jet mode used (To use ODBC mode specify ODBC Connect string)
180915.50 5 rv replace start: [sELECT IsInOffice FROM IsInOffice WHERE Ext = $RV[Get Extension]]
180915.50 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:09:11 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1643}[Get Extension_PathTaken]{success}
180915.52 5 rv replace end: [sELECT IsInOffice FROM IsInOffice WHERE Ext = 1643]
180915.52 5 db About to execute a Retrieve type operation [sELECT IsInOffice FROM IsInOffice WHERE Ext = 1643]
180915.54 5 db [DB Query] row count=1
180915.55 5 rv add [DB Query_RowCount]{1}
180915.55 5 db get RecordsetGetRowsMax
180915.57 5 db get 999 records. (row count=1)
180915.57 5 db update RVs
180915.59 5 db about to close dbDbqDatabase
180915.61 5 db going down path [True]
180915.61 5 timer clear
180915.63 5 [Evaluate In or Out] Evaluate [$RV[DB Query_1_1] = 1]
180915.64 5 rv replace start: [$RV[DB Query_1_1] = 1]
180915.64 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:09:11 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1643}[Get Extension_PathTaken]{success}[DB Query_RowCount]{1}[DB Query_1_1]{1}
180915.66 5 rv replace end: [1 = 1]
180915.66 5 .Eval(1 = 1)
180915.68 5 AddRVns [Evaluate In or Out_Input]{1 = 1}
180915.68 5 AddRVns [Evaluate In or Out]{True}
180915.70 5 Eval Expr result:[True]
180915.70 5 timer clear
180915.71 5 [Play Tnf to Extension] Playing
180915.73 5 [Play Tnf to Extension] Playing (TransferCall.wav)
180915.73 5 play set playid=519987
180915.85 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\TransferCall.wav]
180915.86 5 timer clear
180915.87 5 RunModule PLAY end
180915.89 5 wa(2031,51998700)
180915.91 5 callinfo MONITORMODES
180917.99 5 wb(51998700)
180918.02 5 play end current play (playid=519987)
180918.03 5 ScriptEventCode 8001 iLineState=1100
180918.04 5 LsPlayMsg EV_PLAY_FINISHED
180918.05 5 timer set 10 EV_TIMEOUT_HANGUP
180918.06 5 timer set 0 EV_TIMEOUT_GOTOMODULE
180918.07 5 ScriptEventCode 9002 iLineState=1101
180918.08 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
180918.09 5 timer clear
180918.10 5 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
180918.49 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
180918.50 5 ScriptEventCode 9012 iLineState=1900
180918.51 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
180918.52 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
180918.53 5 rv replace start: [$RV[Get Extension]]
180918.54 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:09:11 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1643}[Get Extension_PathTaken]{success}[DB Query_RowCount]{1}[DB Query_1_1]{1}[Evaluate In or Out_Input]{1 = 1}[Evaluate In or Out]{True}
180918.55 5 rv replace end: [1643]
180918.56 5 [Tnf to Extension] Announced Transfer to 1643 (TAPI)
180918.57 5 lineSetupTransfer(65877,0) in LsXferStart => 65843
180920.60 5 tapi Reply (LineEvReply) ok 65843 0
180920.62 5 linedevstate 2048 0 0
180920.63 5 callstate DIALTONE 65809 2 0
180920.65 5 callstate ONHOLDPENDTRANSFER 65877 0 0
180948.65 5 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
180948.66 5 ScriptEventCode 9021 iLineState=1900
180948.67 5 LsXferStart EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
180948.68 5 Transfer timed out
180948.69 5 lineDrop(65809) in DropConsultingCall_Fail => 65792
180948.70 5 TapiCbTrigSet 65792 7004
180949.36 5 linedevstate 2048 0 0
180949.38 5 callstate IDLE 65809 0 0
180949.39 5 WorkingMode@Idle=DroppingConsultCall
180949.40 5 ignoring this IDLE
180949.44 5 callstate CONNECTED 65877 1 0
180949.45 5 callstate CONNECTED 65877,1,0
180949.46 5 WorkingModeTAPI@Connected=DroppingConsultCall
180949.47 5 WorkingModeScript@Connected=
180949.48 5 original call re-connected
180949.50 5 tapi Reply (LineEvReply) ok 65792 0
180949.51 5 lineDeallocateCall(65809) => 0
180949.52 5 timer clear
180949.53 5 [Play Goodbye] Playing
180949.54 5 [Play Goodbye] Playing (goodbye.wav)
180949.55 5 play set playid=553776
180949.71 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\goodbye.wav]
180949.72 5 timer clear
180949.73 5 RunModule PLAY end
180949.74 5 TapiCbTrigClear
180949.76 5 wa(3711,55377600)
180949.77 5 callinfo MONITORMODES
180953.52 5 wb(55377600)
180953.56 5 play end current play (playid=553776)
180953.57 5 ScriptEventCode 8001 iLineState=1100
180953.58 5 LsPlayMsg EV_PLAY_FINISHED
180953.59 5 timer set 10 EV_TIMEOUT_HANGUP
180953.60 5 timer set 1 EV_TIMEOUT_GOTOMODULE
180954.51 5 timer fired EV_TIMEOUT_GOTOMODULE
180954.51 5 ScriptEventCode 9002 iLineState=1101
180954.52 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
180954.54 5 timer clear
180954.55 5 rv add [Hangup Time]{10/6/2004 6:09:54 PM}
180954.56 5 Hanging up call... [Hangup Module]
180954.58 5 RecSoundStop ok
180954.61 5 PlaySoundStop err=0
180954.62 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
180954.68 5 fnHangupCall end
180954.72 5 linedevstate 2048 0 0
180954.74 5 callstate IDLE 65877 0 0
180954.75 5 WorkingMode@Idle=
180954.76 5 timer clear
180954.78 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
180954.80 5 tapi Reply (LineEvReply) ok 65791 0
180955.71 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
180955.73 5 ScriptEventCode 9008 iLineState=900
180955.73 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
180955.75 5 ReinitTelephony due to IDLE
180955.75 5 tapic lineDeallocateCall(hConsultCall_OriginalCallHandleBeforeTransferAttempted:65877) 0
180955.77 5 tapic lineDeallocateCall(MainCall:65877) LINEERR_INVALCALLHANDLE [80000018]
180956.04 5 lineOpen(5)=>
180956.05 5 Waiting for a call...
180956.05 5 LineHandle=65774
180956.07 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
180956.37 0 dial start any summary:|5:rdy=0|
180957.38 0 dial start any summary:|5:rdy=0|
180958.38 0 dial start any summary:|5:rdy=0|
180959.11 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
180959.11 5 ScriptEventCode 9013 iLineState=900
*** It also does not work with blind transfer, all the caller hears is the extension dial tone then the call drops.
Here's the log:
181501.43 5 linedevstate 2048 0 0
181501.45 5 callstate OFFERING 65672 0 4
181501.45 5 Answer the call at 10/6/2004 6:15:01 PM
181501.46 5 lineAnswer(65672) => 65655
181501.47 5 callinfo CALLEDID
181501.47 5 callinfo ORIGIN
181501.48 5 ring 0
181502.02 5 callstate CONNECTED 65672 1 0
181502.03 5 callstate CONNECTED 65672,1,0
181502.03 5 WorkingModeTAPI@Connected=
181502.05 5 WorkingModeScript@Connected=
181502.05 5 Inband detection not enabled
181502.05 5 StartLoadedVgs at 10/6/2004 6:15:02 PM
181502.05 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}
181502.05 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}
181502.06 5 rv add [$RV_STARTTIME]{10/6/2004 6:15:02 PM}
181502.09 5 rv add [$RV_DEVICEID]{5}
181502.09 5 rv add [$RV_CIDNAME]{}
181502.09 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
181502.10 5 rv add [$RV_CIDNUMBER]{}
181502.11 5 tapi Reply (LineEvReply) ok 65655 0
181502.13 5 callinfo MONITORMODES
181502.13 5 timer clear
181502.13 5 [Determine work hours] Evaluate [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 20))]
181502.14 5 rv replace start: [($RV_DAY < 6) and (($RV_HOUR >= 9) and ($RV_HOUR < 20))]
181502.16 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:15:02 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
181502.16 5 rv replace end: [(3 < 6) and ((18 >= 9) and (18 < 20))]
181502.17 5 .Eval((3 < 6) and ((18 >= 9) and (18 < 20)))
181502.17 5 AddRVns [Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}
181502.18 5 AddRVns [Determine work hours]{True}
181502.20 5 AddRVns [time]{True}
181502.20 5 Eval Expr result:[True] stored in $RV[time]
181502.21 5 timer clear
181502.21 5 [Welcome Office Hours] Playing
181502.23 5 [Welcome Office Hours] Playing (Office hours.wav)
181502.23 5 play set playid=866145
181502.35 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\Office hours.wav]
181502.36 5 timer clear
181502.38 5 RunModule PLAY end
181502.38 5 wa(13538,86614500)
181502.39 5 callinfo MONITORMODES
181503.80 5 dtmf 1 (65672,49,2)
181503.82 5 ScriptEventCode 49 iLineState=1100
181503.83 5 LsPlayMsg 1
181503.91 5 PlaySoundStop err=0
181503.91 5 rv add [Welcome Office Hours]{1}
181503.97 5 timer clear
181503.98 5 [Get Extension] Number Input
181503.98 5 [Get Extension] Playing (ExtensionNum.wav)
181503.98 5 play set playid=867897
181504.11 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\ExtensionNum.wav]
181504.12 5 timer clear
181504.14 5 wa(2558,86789700)
181504.15 5 callinfo MONITORMODES
181506.21 5 dtmf 1 (65672,49,2)
181506.21 5 ScriptEventCode 49 iLineState=1300
181506.22 5 LsGetNbrsPlayWelcMsg 1
181506.31 5 PlaySoundStop err=0
181506.32 5 [Get Extension] Number Input 1
181506.33 5 path {1} not found
181506.33 5 timer set 5 EV_TIMEOUT_GOTOMODULE
181506.58 5 dtmf 6 (65672,54,2)
181506.58 5 ScriptEventCode 54 iLineState=1301
181506.59 5 LsGetNbrsRxDigits 6
181506.60 5 [Get Extension] Number Input 16
181506.61 5 path {16} not found
181506.63 5 timer set 5 EV_TIMEOUT_GOTOMODULE
181506.83 5 dtmf 5 (65672,53,2)
181506.84 5 ScriptEventCode 53 iLineState=1301
181506.85 5 LsGetNbrsRxDigits 5
181506.85 5 [Get Extension] Number Input 165
181506.86 5 path {165} not found
181506.88 5 timer set 5 EV_TIMEOUT_GOTOMODULE
181507.04 5 dtmf 9 (65672,57,2)
181507.05 5 ScriptEventCode 57 iLineState=1301
181507.06 5 LsGetNbrsRxDigits 9
181507.07 5 [Get Extension] Number Input 1659
181507.08 5 path {1659} not found
181507.09 5 timer set 5 EV_TIMEOUT_GOTOMODULE
181507.10 5 timer clear
181507.11 5 rv add [Get Extension]{1659}
181507.13 5 path {1659} not found
181507.13 5 AddRVns [Get Extension_PathTaken]{success}
181507.14 5 timer clear
181507.16 5 [DB Query] DB Query
181507.16 5 db Jet mode used (To use ODBC mode specify ODBC Connect string)
181507.18 5 rv replace start: [sELECT IsInOffice FROM IsInOffice WHERE Ext = $RV[Get Extension]]
181507.20 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:15:02 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1659}[Get Extension_PathTaken]{success}
181507.20 5 rv replace end: [sELECT IsInOffice FROM IsInOffice WHERE Ext = 1659]
181507.21 5 db About to execute a Retrieve type operation [sELECT IsInOffice FROM IsInOffice WHERE Ext = 1659]
181507.23 5 db [DB Query] row count=1
181507.23 5 rv add [DB Query_RowCount]{1}
181507.24 5 db get RecordsetGetRowsMax
181507.25 5 db get 999 records. (row count=1)
181507.27 5 db update RVs
181507.27 5 db about to close dbDbqDatabase
181507.30 5 db going down path [True]
181507.30 5 timer clear
181507.31 5 [Evaluate In or Out] Evaluate [$RV[DB Query_1_1] = 1]
181507.32 5 rv replace start: [$RV[DB Query_1_1] = 1]
181507.34 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:15:02 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1659}[Get Extension_PathTaken]{success}[DB Query_RowCount]{1}[DB Query_1_1]{1}
181507.34 5 rv replace end: [1 = 1]
181507.35 5 .Eval(1 = 1)
181507.36 5 AddRVns [Evaluate In or Out_Input]{1 = 1}
181507.38 5 AddRVns [Evaluate In or Out]{True}
181507.38 5 Eval Expr result:[True]
181507.39 5 timer clear
181507.41 5 [Play Tnf to Extension] Playing
181507.41 5 [Play Tnf to Extension] Playing (TransferCall.wav)
181507.42 5 play set playid=871332
181507.55 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\TransferCall.wav]
181507.55 5 timer clear
181507.56 5 RunModule PLAY end
181507.59 5 wa(2031,87133200)
181507.59 5 callinfo MONITORMODES
181509.70 5 play end current play (playid=871332)
181509.70 5 ScriptEventCode 8001 iLineState=1100
181509.72 5 LsPlayMsg EV_PLAY_FINISHED
181509.73 5 timer set 10 EV_TIMEOUT_HANGUP
181509.73 5 timer set 0 EV_TIMEOUT_GOTOMODULE
181509.75 5 ScriptEventCode 9002 iLineState=1101
181509.76 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
181509.77 5 timer clear
181509.77 5 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
181510.17 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
181510.17 5 ScriptEventCode 9012 iLineState=1900
181510.18 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
181510.20 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
181510.21 5 rv replace start: [$RV[Get Extension]]
181510.22 5 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Setcom Switchboard Server}[$RV_STARTTIME]{10/6/2004 6:15:02 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Determine work hours_Input]{(3 < 6) and ((18 >= 9) and (18 < 20))}[Determine work hours]{True}[time]{True}[Welcome Office Hours]{1}[Get Extension]{1659}[Get Extension_PathTaken]{success}[DB Query_RowCount]{1}[DB Query_1_1]{1}[Evaluate In or Out_Input]{1 = 1}[Evaluate In or Out]{True}
181510.23 5 rv replace end: [1659]
181510.23 5 [Tnf to Extension] Blind Transfer to 1659 (TAPI)
181510.27 5 lineBlindTransfer(65672,1659,0) in LsXferStart => 65638
181512.80 5 callstate ONHOLDPENDTRANSFER 65672 0 0
181513.41 5 linedevstate 2048 0 0
181513.42 5 callstate IDLE 65672 0 0
181513.44 5 WorkingMode@Idle=BlindTransfer
181513.45 5 timer clear
181513.52 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181513.55 5 tapi Reply (LineEvReply) ok 65638 0
181514.45 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
181514.47 5 ScriptEventCode 9008 iLineState=1900
181514.48 5 LsXferStart EV_TIMEOUT_TIMETOREINITLINE
181514.48 5 ReinitTelephony due to IDLE
181514.49 5 tapic lineDeallocateCall(MainCall:65672) 0
181514.79 5 lineOpen(5)=>
181514.80 5 Waiting for a call...
181514.81 5 LineHandle=65621
181514.83 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181515.29 0 dial start any summary:|5:rdy=0|
181516.30 0 dial start any summary:|5:rdy=0|
181517.31 0 dial start any summary:|5:rdy=0|
181517.84 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181517.85 5 ScriptEventCode 9013 iLineState=1900
Thanks for any help.
I think your hookflash length is set too high...
What length hookflash does your PBX expect?
