Changing Settings
When Vg is auto dialing and delivering message, how can I change the dialing parameters without stopping the system? For example, I have the system in operation having already dialed 1000 calls with 2000 left to go. I have the start time set to 9:01 and the stop time set to 7:59. But I want to change the parameters so the the last 2000 calls start at 10:01 and stop at 8:59, but I don't want to upset the continued dialing order and I don't want to start from beginning.
Hal Netkin
halnet@pacbell.net
To do this you would need to change the entries in the Database OutDialQue.mdb directly.
You would need to open the database yourself and make the changes yourself or write a program/VBScript to do it for you.
