Changing To Voiceguide
Hello
We have already running a IVR system (ISDN-voice). Now is my question, if it is possible to run Voiceguide at the same time. Our hardware is a HST 30 channel SAPHIR V Primary PCI adapter. One IVR system uses 14 channels and it would be cool if VoiceGuide could make use of the remaining 16 channels.
Is this technically possible?
Thanks & regards
Peter
Well, I installed voiceguide demo with latest COMISDN and it worked fine with a hst SAPHIR III PCI.
>it does not work with HST cards.
OK, I did not realize that you were using the ComISDN drivers and that the HST card was being used in 'CAPI' mode.
I guess that it would be possible for VoiceGuide to just use the 16 channels that you'd choose - after all VoiceGuide does allow you to select what channels to use on a channel-by-channel basis., and I understand that ComISDN can share CAPI devices with other applications...
