Announced Transfer Busy
HI, We have VG working with a 4 port dialogic card. When we do an announced transfer and the extn is busy it does not retrieve the call and send to voicemail.
Any ideas....event log included below
Thanks Dave Y
120021.78 8 linedevstate 2048 0 0
120021.79 8 callstate OFFERING 66392 0 4
120021.79 8 No old processes from last call (could not obtain handle) 1276, 1588
120021.79 8 Answer the call at 14/09/2004 12:00:21 PM
120021.79 8 lineAnswer(66392) => 65606
120021.80 8 callinfo CALLEDID
120021.80 8 callinfo ORIGIN
120021.80 8 ring 0
120022.33 8 callstate CONNECTED 66392 1 0
120022.34 8 callstate CONNECTED 66392,1,0
120022.34 8 WorkingModeTAPI@Connected=
120022.34 8 WorkingModeScript@Connected=
120022.35 8 Inband detection not enabled
120022.35 8 StartLoadedVgs at 14/09/2004 12:00:22 PM
120022.35 8 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Prowess\}
120022.36 8 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Prowess}
120022.36 8 rv add [$RV_STARTTIME]{14/09/2004 12:00:22 PM}
120022.36 8 rv add [$RV_DEVICEID]{8}
120022.36 8 rv add [$RV_CIDNAME]{}
120022.37 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
120022.37 8 rv add [$RV_CIDNUMBER]{}
120022.37 8 tapi Reply (LineEvReply) ok 65606 0
120022.39 8 callinfo MONITORMODES
120022.43 8 timer clear
120022.43 8 [Welcome] Number Input
120022.43 8 [Welcome] Playing (Kaz Recordings\Welcome.wav)
120022.44 8 play set playid=469604
120022.46 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\Welcome.wav]
120022.46 8 timer clear
120022.47 8 wa(17454,46960400)
120022.47 8 callinfo MONITORMODES
120025.86 8 dtmf 2 (66392,50,2)
120025.86 8 ScriptEventCode 50 iLineState=1300
120025.87 8 LsGetNbrsPlayWelcMsg 2
120025.92 8 PlaySoundStop err=0
120025.92 8 [Welcome] Number Input 2
120025.93 8 rv add [Welcome]{2}
120025.93 8 timer clear
120025.94 8 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
120026.33 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
120026.33 8 ScriptEventCode 9012 iLineState=1900
120026.33 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
120026.34 8 timer set 15 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
120026.34 8 [PP Support] Announced Transfer to 210 (Generate)
120026.35 8 tapic lineGenerateDigits(66392,!,0) => 0
120026.61 8 generate LINEGENERATETERM_DONE
120026.61 8 timer set 1 EV_TAPI_GENERATE
120027.55 8 timer fired EV_TAPI_GENERATE
120027.55 8 ScriptEventCode 9602 iLineState=1900
120027.55 8 LsXferStart EV_TAPI_GENERATE
120027.56 8 timer set 1 EV_HOOKFLASHFINISHED
120028.56 8 timer fired EV_HOOKFLASHFINISHED
120028.56 8 ScriptEventCode 9200 iLineState=1905
120028.56 8 LsXferPlayVts EV_HOOKFLASHFINISHED
120028.57 8 tapic lineGenerateDigits(66392,210,0) => 0
120028.98 8 generate LINEGENERATETERM_DONE
120028.98 8 timer set 1 EV_TAPI_GENERATE
120029.89 8 timer fired EV_TAPI_GENERATE
120029.89 8 ScriptEventCode 9602 iLineState=1905
120029.89 8 LsXferPlayVts EV_TAPI_GENERATE
120029.89 8 [PP Support] Playing (Kaz Recordings\PropPro Announce.wav)
120029.90 8 play set playid=477065
120029.91 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\PropPro Announce.wav]
120029.91 8 timer clear
120029.93 8 wa(7127,47706500)
120029.93 8 callinfo MONITORMODES
120037.07 8 wb(47706500)
120037.11 8 play end current play (playid=477065)
120037.13 8 ScriptEventCode 8001 iLineState=1906
120037.13 8 LsXferPlayAnn EV_PLAY_FINISHED
120037.13 8 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
120037.14 8 [PP Support] Playing (Kaz Recordings\PropPro Announce.wav)
120037.14 8 play set playid=484295
120037.14 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Prowess\Kaz Recordings\PropPro Announce.wav]
120037.16 8 timer clear
120037.16 8 wa(7127,48429500)
120037.16 8 callinfo MONITORMODES
120040.27 8 callstate DISCONNECTED 66392 0 0
120040.28 8 ScriptEventCode 9250 iLineState=1906
120040.28 8 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT
120040.28 8 timer set 1 EV_PLAY_FINISHED
120040.34 8 PlaySoundStop err=0
120041.27 8 timer fired EV_PLAY_FINISHED
120041.27 8 ScriptEventCode 8001 iLineState=1906
120041.27 8 LsXferPlayAnn EV_PLAY_FINISHED
120041.28 8 tapic lineGenerateDigits(66392,!,0) => LINEERR_INVALCALLSTATE [8000001C]
120041.28 8 rv add [Hangup Time]{14/09/2004 12:00:41 PM}
120041.28 8 Hanging up call... [lineGenerateDigits ret=-2147483620]
120041.29 8 RecSoundStop ok
120041.29 8 PlaySoundStop err=0
120041.30 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
120041.30 8 fnHangupCall end
120041.34 8 linedevstate 2048 0 0
120041.35 8 callstate IDLE 66392 0 0
120041.35 8 WorkingMode@Idle=
120041.35 8 timer clear
120041.36 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
120041.36 8 tapi Reply (LineEvReply) ok 66460 0
120042.31 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
120042.31 8 ScriptEventCode 9008 iLineState=900
120042.31 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
120042.32 8 ReinitTelephony due to IDLE
120042.33 8 tapic lineDeallocateCall(MainCall:66392) 0
120042.39 8 lineOpen(8)=>
120042.40 8 Waiting for a call...
120042.40 8 LineHandle=66477
120042.40 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
120043.32 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0|
120044.37 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0|
120045.41 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0|
120045.42 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
120045.42 8 ScriptEventCode 9013 iLineState=900
We are using a Panasonic KX816 PABX with a flash time of 10ms on the dialogic board. All other functions seem to work fine.
