Access Db Interaction
Help is needed with the following:
Why doesn't the database open?
Is there a setting missing in the configuration?
screen configuration shots and transcript follow:
131453.92 7 linedevstate 2048 0 0
131453.92 7 callstate OFFERING 66458 0 4
131453.92 7 Answer the call at 9/2/2004 1:14:53 PM
131453.92 7 lineAnswer(66458) => 66407
131453.94 7 callinfo CALLEDID
131453.94 7 callinfo ORIGIN
131453.94 7 ring 0
131454.47 7 callstate CONNECTED 66458 1 0
131454.47 7 callstate CONNECTED 66458,1,0
131454.47 7 WorkingModeTAPI@Connected=
131454.47 7 WorkingModeScript@Connected=
131454.48 7 Inband detection not enabled
131454.48 7 StartLoadedVgs at 9/2/2004 1:14:54 PM
131454.48 7 AddRVns [scriptsPath]{F:\DiaLogic IVR\VoiceGuide5.2.3\Scripts\tests\}
131454.48 7 AddRVns [scriptPath]{F:\DiaLogic IVR\VoiceGuide5.2.3\Scripts\tests}
131454.48 7 rv add [$RV_STARTTIME]{9/2/2004 1:14:54 PM}
131454.48 7 rv add [$RV_DEVICEID]{7}
131454.48 7 rv add [$RV_CIDNAME]{}
131454.48 7 AddRVns [PathApp]{F:\DiaLogic IVR\VoiceGuide5.2.3\}
131454.48 7 rv add [$RV_CIDNUMBER]{}
131454.48 7 tapi Reply (LineEvReply) ok 66407 0
131454.48 7 callinfo MONITORMODES
131454.48 7 timer clear
131454.48 7 [PinQuery] DB Query
131454.48 7 db ODBC mode used
131454.50 7 ERROR 5.2.3018 OpenDatabase [3146:ODBC--call failed.]
131454.50 7 path {0} not found
131454.50 7 path {} not found
If you want to connect via ODBC interface then you need to specify the Datasource name - not the filename.
With Access databases it is easiest to just specify the filename and leave the 'Connect String' blank.
Thank you for replying but I don't understand the nomenclature.
the data source name was set to "KRS IVG"
the database file is "krs.mdb" in "F:\KRS"
the database has 2 table one of which is called ""Subscribers"
What is a "data source name"?
