Call Transfer - Redirect To Third Number
Can I custom the Dial and Conference option in the Call Transfer module to use a (another) script (.vgs or .vbs) for the second call, instead of just a simple call with a sound file played. What I want to do is to enable the second part to be able to redirect the call to a third number.
Sounds like you just set up your own custom script to do a Dial and Conference. This is quite easily done – just use the Bridge_Connect COM function to connect two calls when needed.
