What Is Wrong With This Sample Vb Code
im using this sample code from the help file:
iLen = Len("$RV_ENTEREDNUMBER")
If iLen<1 or iLen>2 Then
sResult = "verify_failed"
Else
sResult = "verify_passed"
end If
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
i want to check it the entered number is 1 or 2
but the script always send verify_passed for any enterd nmber.
Is this the 'verify' script used in a Get Numbers module?
