Avaya G3r Inband Signaling Issue
We have recently installed VoiceGuide v. 5.2. I am looking for assistance with the Inband Signaling file for an Avaya G3R PBX. As I've noticed with other posts, I am attaching the contents of the event trace log. Any suggestions??
104605.35 12 linedevstate 2048 0 0
104605.35 12 callstate OFFERING 65815 0 4
104605.35 12 Answer the call at 8/18/2004 10:46:05 AM
104605.35 12 lineAnswer(65815) => 65970
104605.36 12 callinfo CALLEDID
104605.36 12 callinfo ORIGIN
104605.36 12 ring 0
104605.88 12 callstate CONNECTED 65815 1 0
104605.88 12 callstate CONNECTED 65815,1,0
104605.88 12 WorkingModeTAPI@Connected=
104605.89 12 WorkingModeScript@Connected=
104605.89 12 Inband detection not enabled
104605.90 12 StartLoadedVgs at 8/18/2004 10:46:05 AM
104605.90 12 AddRVns [scriptsPath]{C:\VoiceGuide\Scripts\DMI Scripts\}
104605.90 12 AddRVns [scriptPath]{C:\VoiceGuide\Scripts\DMI Scripts}
104605.90 12 rv add [$RV_STARTTIME]{8/18/2004 10:46:05 AM}
104605.90 12 rv add [$RV_DEVICEID]{12}
104605.90 12 rv add [$RV_CIDNAME]{}
104605.90 12 AddRVns [PathApp]{C:\VoiceGuide\}
104605.90 12 rv add [$RV_CIDNUMBER]{}
104605.91 12 tapi Reply (LineEvReply) ok 65970 0
104605.91 12 timer clear
104605.91 12 [CaptureANI] Number Input
104605.91 12 [CaptureANI] Playing ()
104605.92 12 ScriptEventCode 8001 iLineState=1300
104605.92 12 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
104605.92 12 timer set 5 EV_TIMEOUT_REPLAYMSG
104605.92 12 callinfo MONITORMODES
104606.64 12 dtmf 5 (65815,53,2)
104606.64 12 ScriptEventCode 53 iLineState=1301
104606.64 12 LsGetNbrsRxDigits 5
104606.65 12 [CaptureANI] Number Input 5
104606.65 12 path {5} not found
104606.65 12 timer set 6 EV_TIMEOUT_ENTERDATA
104606.83 12 dtmf 0 (65815,48,2)
104606.83 12 ScriptEventCode 48 iLineState=1301
104606.84 12 LsGetNbrsRxDigits 0
104606.84 12 [CaptureANI] Number Input 50
104606.84 12 path {50} not found
104606.84 12 timer set 6 EV_TIMEOUT_ENTERDATA
104606.00 12 dtmf 4 (65815,52,2)
104606.00 12 ScriptEventCode 52 iLineState=1301
104606.00 12 LsGetNbrsRxDigits 4
104607.01 12 [CaptureANI] Number Input 504
104607.01 12 path {504} not found
104607.01 12 timer set 6 EV_TIMEOUT_ENTERDATA
104607.19 12 dtmf 0 (65815,48,2)
104607.19 12 ScriptEventCode 48 iLineState=1301
104607.19 12 LsGetNbrsRxDigits 0
104607.20 12 [CaptureANI] Number Input 5040
104607.20 12 path {5040} not found
104607.20 12 timer set 6 EV_TIMEOUT_ENTERDATA
104607.65 12 dtmf # (65815,35,2)
104607.65 12 ScriptEventCode 35 iLineState=1301
104607.65 12 LsGetNbrsRxDigits #
104607.65 12 timer clear
104607.65 12 rv add [CaptureANI]{5040}
104607.66 12 path {5040} not found
104607.66 12 AddRVns [CaptureANI_PathTaken]{success}
104607.66 12 timer clear
104607.66 12 [Welcome] Playing
104607.66 12 [Welcome] Playing (C:\VoiceGuide\system\voice\DMIwelcome.wav)
104607.67 12 play set playid=435543
104607.71 12 PlaySoundStart ok [C:\VoiceGuide\system\voice\DMIwelcome.wav]
104607.74 12 timer clear
104607.74 12 RunModule PLAY end
104607.75 12 wa(2499,43554300)
104607.75 12 callinfo MONITORMODES
104610.31 12 play end current play (playid=435543)
104610.31 12 ScriptEventCode 8001 iLineState=1100
104610.31 12 LsPlayMsg EV_PLAY_FINISHED
104610.32 12 timer set 10 EV_TIMEOUT_HANGUP
104610.32 12 timer set 0 EV_TIMEOUT_GOTOMODULE
104610.32 12 ScriptEventCode 9002 iLineState=1101
104610.32 12 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
104610.34 12 timer clear
104610.34 12 [Enter Loan Number] Number Input
104610.34 12 [Enter Loan Number] Playing (C:\VoiceGuide\system\voice\DMIenterloan.wav)
104610.34 12 play set playid=438207
104610.36 12 PlaySoundStart ok [C:\VoiceGuide\system\voice\DMIenterloan.wav]
104610.43 12 timer clear
104610.43 12 wa(2128,43820700)
104610.43 12 callinfo MONITORMODES
104612.57 12 play end current play (playid=438207)
104612.57 12 ScriptEventCode 8001 iLineState=1300
104612.58 12 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
104612.58 12 timer set 10 EV_TIMEOUT_HANGUP
104612.58 12 timer set 6 EV_TIMEOUT_ENTERDATA
104616.71 12 callstate DISCONNECTED 65815 0 0
104616.72 12 ScriptEventCode 9250 iLineState=1301
104616.72 12 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT
104616.72 12 rv add [Enter Loan Number]{}
104616.72 12 rv add [Hangup Time]{8/18/2004 10:46:16 AM}
104616.73 12 Hanging up call...
104616.73 12 RecSoundStop ok
104616.73 12 PlaySoundStop err=0
104616.73 12 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104616.76 12 fnHangupCall end
104616.82 12 linedevstate 2048 0 0
104616.82 12 callstate IDLE 65815 0 0
104616.82 12 WorkingMode@Idle=
104616.82 12 timer clear
104616.86 12 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104616.87 12 tapi Reply (LineEvReply) ok 66450 0
104617.82 12 timer fired EV_TIMEOUT_TIMETOREINITLINE
104617.82 12 ScriptEventCode 9008 iLineState=900
104617.82 12 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104617.82 12 ReinitTelephony due to IDLE
104617.86 12 tapic lineDeallocateCall(MainCall:65815) 0
104618.04 12 lineOpen(12)=>
104618.04 12 Waiting for a call...
104618.04 12 LineHandle=65592
104618.05 12 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104618.23 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|9:idx=0|10:idx=0|11:idx=0|12:rdy=0|
104619.29 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|9:idx=0|10:idx=0|11:idx=0|12:rdy=0|
104620.34 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0|9:idx=0|10:idx=0|11:idx=0|12:rdy=0|
104621.07 12 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104621.07 12 ScriptEventCode 9013 iLineState=900
Looks like as the first module in your script you have set up a 'Get Numbers' module (named "CaptureANI") and you are using it to capture the DTMF tones sent by the PBX immediately after call is answered.
We can also see in trace that the PBX is sending these DTMF tones:
5040#
which are read in by the CaptureANI module - so for this call the Result Variable
$RV[CaptureANI]
would have a value of:
5040
So you can just use the $RV[CaptureANI] in the remainder of your script...
You can of course also set up the Inband Signaling Config file - which will just essentially place the same info in another RV - as defined in Inband Signaling Config file.
Based on the trace the contents of your Inband Signaling Config file should be:
;4 digits followed by #
Pattern=?????
RV=Inband_ANI,1,4
and then the 4 digits sent by PBX would be accessible using:
$RV[inband_ANI]
