Bridge Two Different Lines
Hello,
Is it possible to bridge two different lines ? For example, dial in Line A and prompt to enter another outgoing number, then using Line B to dial out this number and talk with the other party.
I'm using Dialogic D/4PCIU and VG 5.2.2
Regards
AB
You cannot bridge two calls with a D/4PCIU. You need D41JCT or better.
See the Bridge_Connect COM command.
Perhaps you have another way to connet call on one line to another ?
Regards
Anton
Do I need only D/41JCT-LS (or better) for Call Bridge ? or need other pheriperal to support my scenrio above?
Rgrds
AB
