Can't Get Dialer To Work
I have downloaded the demo version of the software - and as I understand it, the dialer should work for 10 numbers and for an hour.
I want to make sure it'll do what I need before paying for the license but I cannot get the dialer to work.
I've installed a Dialogic analog 4PICU and I've confirmed that they'll receive incoming calls with the supplied sample scripts.
However, with the dialer, notthing happens. I've set up a simple script that just plays a wav file. The dialer is referenced in the "real person answers" field - and I've put the number in the phone number box. But when i hit dial, the program just appears to end. The log file reports:
172855.11 0 init saving dialer settings
172855.50 0 db database opened
172855.52 0 info Do Not Call List Loading...
172855.53 0 dnc Do No Call List file not specified
172855.55 0 info Do Not Call List Load Finished 0
172855.55 0 load text box numbers start
172855.61 0 info Text Box Numbers Loading...
172856.05 0 load text box numbers end
172856.05 0 db database closed
172856.05 0 info Finished queued:1 rejected:0
172857.47 0 info file : 0 explicittly listed loaded OK
172857.48 0 info file : 0 explicittly listed rejected (Do Not Call List)
172857.50 0 info file : 0 explicittly listed rejected (Other)
172857.50 0 info file : 0 expanded from template loaded OK
172857.50 0 info file : 0 expanded from template rejected (Do Not Call List)
172857.52 0 info file : 0 expanded from template rejected (Other)
172857.52 0 info text : 0 explicittly listed loaded OK
172857.52 0 info text : 0 explicittly listed rejected (Do Not Call List)
172857.53 0 info text : 0 explicittly listed rejected (Other)
172857.53 0 info text : 1 expanded from template loaded OK
172857.55 0 info text : 0 expanded from template rejected (Do Not Call List)
172857.55 0 info text : 0 expanded from template rejected (Other)
172857.56 0 info TOTAL : 1 loaded OK
172857.56 0 info TOTAL : 0 rejected
But that's all.
I've tried deleting the OutDial*.* files in the data directory, and restarted the app. But still no joy.
Any thoughts?
Found it - I had been using the 'line selection' option but I needed it to be 5,6,7 or 8 and not 1 to 4 as they were H232 lines - even though they were not selected under the VG config.
