Program Crash
Hi, I am having a problem with a script. the computer answers the phone and
miday thru the first wav recording it crashes.
Below are the steps the program listed.
it crashes to a blue screen that says something about VXD
Jim Benson
150540.26 0 callstate OFFERING 4342232 0 4
150540.26 0 ring 1
150544.16 0 ring 2
150544.21 0 Answer the call at 7/31/2004 3:05:44 PM
150544.21 0 lineAnswer(4342232) => 1
150544.21 0 tapi Reply (LineEvReply) ok 1 0
150544.21 0 callstate ACCEPTED 4342232 0 0
150545.48 0 callstate CONNECTED 4342232,0,0
150545.48 0 WorkingModeTAPI@Connected=
150545.48 0 WorkingModeScript@Connected=
150545.48 0 Inband detection not enabled
150545.48 0 StartLoadedVgs at 7/31/2004 3:05:45 PM
150545.48 0 [hello intro] Playing
150545.48 0 [hello intro] Playing (hello_intro_bi.wav)
150545.64 0 PlaySoundStart ok [C:\Roomtalk\voiceguide\Scripts\roomtalk
script\hello_intro_bi.wav]
150545.64 0 RunModule PLAY end
150608.54 0 wb(12001400)
150608.82 0 Play End line[0] (id=120014)
150608.82 0 LsPlayMsg EV_PLAY_FINISHED
150630.73 0 LsPlayMsgFinished EV_TIMEOUT_HANGUP
150630.73 0 Hanging up call...
150630.79 0 RecSoundStop ok
150630.79 0 PlaySoundStop ok
150630.79 0 fnHangupCall end
150630.84 0 callstate IDLE 4342232 0 0
150630.84 0 WorkingMode@Idle=
150630.95 0 tapi Reply (LineEvReply) ok 2 0
150632.82 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
150632.82 0 ReinitTelephony due to IDLE start
150632.82 0 tapic lineDeallocateCall(MainCall:4342232) 0
150633.64 0 lineOpen(0) => 0
150633.64 0 Waiting for a call...
150633.64 0 lineOpen(0)LineHandle=4342040
150648.53 0 sys cleanup Start
150648.58 0 sys cleanup End
A 'Blue Screen' type error is not something which can be caused these days at an application software level (like VoiceGuide) - it is an error on the 'kernel' level of Windows or it's hardware drivers.
These days it is most often caused by faulty memory or faulty hardwre drivers - in your case as the error message says someting about a VXD then I'd suspect a hardware driver.
Dialogic SR5.1.1 drivers do not have any reported 'blue screen' issues.
(are you using SR5.1.1 or some older drivers?)
Sometimes reformatting the computer changes the area of memory where the kernel and the various hardware drivers are loaded in memory which can stop the blue screen from happening
Next time you see the blue screen I'd recommend having a good look at what it says and what hardwre driver has caused the error.
You can read some other peoples experiences when they encountered problems on their systems and how they were resolved here:
http://voiceguide.com/forums/index.php?showtopic=1054
http://voiceguide.com/forums/index.php?showtopic=1266
Which version of Windows are you using?
