Dialing Script Options
I'm looking into usinng VoiceGuide to develop an application to test another CTI server. To that end, I need it to repeatedly go through a database of dtmf tones and dial & transmit them over a four-line dialogic card (using line simulators).
So effectively, it'll be dialing '1' on any of the four lines to get a connection to the other server. Then querying a database to select the dtmfs to send -then hangup.
So a few questions...
With the dialing to get a connection... Could I set the dialer application to loop through the list of phone numbers (which would be just one entry of '1')? Or would i need to set up a huge excel file with all rows set as '1'?
I propose having an internal counter which gets incremented on each outbound call. However, I'm assuming that each of the four dialogic lines will need a script assigned to it and this counter will need to be global to all of them. So my question is whether the "Make RV Global" checkbox under an evaluation is:
1: Global across multiple lines running the same script
2: Maintained across multiple calls on the phones lines
Eg: If I'm using 4 lines and trying to call 12 phone-numbers, incrementing this global counter within the script before a call will maintain the count from 1 to 12?
No. You'll need to load an entry for each call that is to be attempted.
"Global RV" is global for entire system - any other script on any other line can access it (and set it to new value).
Thanks,
Could you tell me the maximum number of numbers to dial? Eg. If I set up the dialer to get the numbers from a file, what would be the largest XXXXXX... type number I could use?
We tested loading up to a few million of numbers. There really is no limit though.
