Callerid With Phone Extensions
We are using our VoiceGuide System as a Timeclock.
Some employees clock in/out from the home office and some clock in/out from outside the office. We need to be able to use caller_id. From outside the office everything is working fine. From inside the office – we dial the extension for the time clock computer – timeclock answers – $RV_CIDNUMBER is Null and the Voiceguide program goes to the next step. This is when the phone system is sending the extension – in this case 213 and the voiceguide program is looking for a Social Security Number. This gives a long pause to the employee that is clocking in/out.
I want to be able to detect no callerid and not allow them to clock in/out.
This is the log when the VoiceGuide system is called form inside the office using the phone extension.
091932.69 16 linedevstate 2048 0 0
091932.70 16 callstate OFFERING 66863 0 4
091932.70 16 No old processes from last call (could not obtain handle) 2564, 0
091932.72 16 Answer the call at 07/29/2004 9:19:32 AM
091932.72 16 lineAnswer(66863) => 66974
091932.73 16 callinfo CALLEDID
091932.75 16 callinfo ORIGIN
091932.75 16 ring 0
091933.28 16 callstate CONNECTED 66863,1,0
091933.28 16 WorkingModeTAPI@Connected=
091933.30 16 WorkingModeScript@Connected=
091933.30 16 Inband detection not enabled
091933.30 16 StartLoadedVgs at 07/29/2004 9:19:33 AM
091933.31 16 AddRVns [scriptsPath]{C:\VoiceGuide_Timeclock\}
091933.33 16 rv add [$RV_STARTTIME]{07/29/2004 9:19:33 AM}
091933.33 16 rv add [$RV_DEVICEID]{16}
091933.34 16 rv add [$RV_CIDNAME]{}
091933.34 16 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
091933.34 16 rv add [$RV_CIDNUMBER]{}
091933.36 16 tapi Reply (LineEvReply) ok 66974 0
091933.38 16 callinfo MONITORMODES
091933.38 16 TimeoutClear
091933.38 16 [CallerID] Evaluate [$RV_CIDNumber]
091933.39 16 RVreplace start: [$RV_CIDNumber]
091933.39 16 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\VoiceGuide_Timeclock\}[$RV_STARTTIME]{07/29/2004 9:19:33 AM}[$RV_DEVICEID]{16}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
091933.41 16 RVreplace end: []
091933.41 16 .Eval()
091933.41 16 rv add [CallerID_Input]{}
091933.42 16 rv add [CallerID]{}
091933.42 16 Eval Expr result:[]
091933.44 16 path {} not found
091933.44 16 dtmf * (66863,42,2)
091933.45 16 ScriptEventCode 42 iLineState=5900
091933.45 16 TimeoutClear
091933.45 16 [CallerIDWasSentRequestSSN] Number Input
091933.47 16 [CallerIDWasSentRequestSSN] Playing (EnterSocialSecurityNumber.wav)
091933.56 16 PlaySoundStart ok [C:\VoiceGuide_Timeclock\EnterSocialSecurityNumber.wav]
091933.58 16 TimeoutClear
091933.59 16 wa(3302,53723400)
091933.59 16 callinfo MONITORMODES
091933.73 16 dtmf 2 (66863,50,2)
091933.75 16 ScriptEventCode 50 iLineState=1300
091933.75 16 LsGetNbrsPlayWelcMsg 2
091933.83 16 PlaySoundStop err=0
091933.83 16 [CallerIDWasSentRequestSSN] Number Input 2
091933.84 16 path {2} not found
091933.84 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091934.02 16 dtmf 1 (66863,49,2)
091934.02 16 ScriptEventCode 49 iLineState=1301
091934.03 16 LsGetNbrsRxDigits 1
091934.03 16 [CallerIDWasSentRequestSSN] Number Input 21
091934.03 16 path {21} not found
091934.05 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091934.31 16 dtmf 3 (66863,51,2)
091934.33 16 ScriptEventCode 51 iLineState=1301
091934.34 16 LsGetNbrsRxDigits 3
091934.38 16 [CallerIDWasSentRequestSSN] Number Input 213
091934.39 16 path {213} not found
091934.39 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091940.86 16 Timer fired EV_TIMEOUT_ENTERDATA
091940.86 16 ScriptEventCode 9006 iLineState=1301
091940.86 16 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
091940.88 16 TimeoutClear
091940.88 16 rv add [CallerIDWasSentRequestSSN]{213}
091940.89 16 [CallerIDWasSentRequestSSN] Playing (EnterSocialSecurityNumber.wav)
091940.98 16 PlaySoundStart ok [C:\VoiceGuide_Timeclock\EnterSocialSecurityNumber.wav]
091941.00 16 TimeoutClear
091941.02 16 wa(3302,54465600)
091941.03 16 callinfo MONITORMODES
091943.64 16 dtmf 1 (66863,49,2)
091943.64 16 ScriptEventCode 49 iLineState=1300
091943.66 16 LsGetNbrsPlayWelcMsg 1
091943.73 16 PlaySoundStop err=0
091943.75 16 [CallerIDWasSentRequestSSN] Number Input 1
091943.75 16 path {1} not found
091943.75 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091943.91 16 dtmf 1 (66863,49,2)
091943.91 16 ScriptEventCode 49 iLineState=1301
091943.91 16 LsGetNbrsRxDigits 1
091943.92 16 [CallerIDWasSentRequestSSN] Number Input 11
091943.92 16 path {11} not found
091943.94 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091944.20 16 dtmf 1 (66863,49,2)
091944.22 16 ScriptEventCode 49 iLineState=1301
091944.22 16 LsGetNbrsRxDigits 1
091944.23 16 [CallerIDWasSentRequestSSN] Number Input 111
091944.23 16 path {111} not found
091944.23 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091944.52 16 dtmf 1 (66863,49,2)
091944.52 16 ScriptEventCode 49 iLineState=1301
091944.52 16 LsGetNbrsRxDigits 1
091944.53 16 [CallerIDWasSentRequestSSN] Number Input 1111
091944.53 16 path {1111} not found
091944.55 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091944.81 16 dtmf 1 (66863,49,2)
091944.81 16 ScriptEventCode 49 iLineState=1301
091944.83 16 LsGetNbrsRxDigits 1
091944.83 16 [CallerIDWasSentRequestSSN] Number Input 11111
091944.83 16 path {11111} not found
091944.84 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091945.11 16 dtmf 1 (66863,49,2)
091945.11 16 ScriptEventCode 49 iLineState=1301
091945.13 16 LsGetNbrsRxDigits 1
091945.13 16 [CallerIDWasSentRequestSSN] Number Input 111111
091945.14 16 path {111111} not found
091945.14 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091949.61 16 dtmf 1 (66863,49,2)
091949.61 16 ScriptEventCode 49 iLineState=1301
091949.63 16 LsGetNbrsRxDigits 1
091949.63 16 [CallerIDWasSentRequestSSN] Number Input 1111111
091949.64 16 path {1111111} not found
091949.64 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091949.91 16 dtmf 1 (66863,49,2)
091949.92 16 ScriptEventCode 49 iLineState=1301
091949.92 16 LsGetNbrsRxDigits 1
091949.92 16 [CallerIDWasSentRequestSSN] Number Input 11111111
091949.94 16 path {11111111} not found
091949.94 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091950.20 16 dtmf 1 (66863,49,2)
091950.20 16 ScriptEventCode 49 iLineState=1301
091950.20 16 LsGetNbrsRxDigits 1
091950.22 16 [CallerIDWasSentRequestSSN] Number Input 111111111
091950.22 16 path {111111111} not found
091950.23 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091950.23 16 TimeoutClear
091950.23 16 rv add [CallerIDWasSentRequestSSN]{111111111}
091950.25 16 path {111111111} not found
091950.25 16 AddRVns [CallerIDWasSentRequestSSN_PathTaken]{success}
091950.25 16 TimeoutClear
091950.27 16 [CheckForValidSSN] DB Query
091950.27 16 db Jet mode used (To use ODBC mode specify ODBC Connect string)
091950.28 16 RVreplace start: [select * from employeestatus where SocialSecurityNumber = '$RV[CallerIDWasSentRequestSSN]']
091950.28 16 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\VoiceGuide_Timeclock\}[$RV_STARTTIME]{07/29/2004 9:19:33 AM}[$RV_DEVICEID]{16}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[CallerID_Input]{}[CallerID]{}[CallerIDWasSentRequestSSN]{21
}[CallerIDWasSentRequestSSN]{111111111}[CallerIDWasSentRequestSSN_PathTaken]{suc
ess}
091950.30 16 RVreplace end: [select * from employeestatus where SocialSecurityNumber = '111111111']
091950.31 16 db About to execute a Retrieve type operation [select * from employeestatus where SocialSecurityNumber = '111111111']
091950.31 16 db [CheckForValidSSN] no records found.
091950.33 16 TimeoutClear
091950.34 16 [invalidSSN] Playing
091950.34 16 [invalidSSN] Playing (re-enterSocialSecurityNumber.wav)
091950.44 16 PlaySoundStart ok [C:\VoiceGuide_Timeclock\re-enterSocialSecurityNumber.wav]
091950.44 16 TimeoutClear
091950.44 16 RunModule PLAY end
091950.45 16 wa(4022,55410900)
091950.47 16 callinfo MONITORMODES
091954.64 16 wb(55410900)
091954.67 16 Play End line[16] (id=554109)
091954.67 16 ScriptEventCode 8001 iLineState=1100
091954.69 16 LsPlayMsg EV_PLAY_FINISHED
091954.69 16 TimeoutSet 10 EV_TIMEOUT_HANGUP
091954.69 16 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
091954.70 16 ScriptEventCode 9002 iLineState=1101
091954.70 16 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
091954.72 16 TimeoutClear
091954.72 16 [CallerIDWasSentRequestSSN] Number Input
091954.73 16 [CallerIDWasSentRequestSSN] Playing (EnterSocialSecurityNumber.wav)
091954.83 16 PlaySoundStart ok [C:\VoiceGuide_Timeclock\EnterSocialSecurityNumber.wav]
091954.84 16 TimeoutClear
091954.86 16 wa(3302,55850000)
091954.88 16 callinfo MONITORMODES
091958.25 16 wb(55850000)
091958.28 16 Play End line[16] (id=558500)
091958.28 16 ScriptEventCode 8001 iLineState=1300
091958.28 16 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
091958.30 16 TimeoutSet 10 EV_TIMEOUT_HANGUP
091958.30 16 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
091958.92 16 dtmf C (66863,67,2)
091958.94 16 ScriptEventCode 67 iLineState=1301
091958.94 16 LsGetNbrsRxDigits C
091959.22 16 dtmf C (66863,67,2)
091959.23 16 ScriptEventCode 67 iLineState=1301
091959.23 16 LsGetNbrsRxDigits C
091959.53 16 dtmf C (66863,67,2)
091959.53 16 ScriptEventCode 67 iLineState=1301
091959.53 16 LsGetNbrsRxDigits C
092000.23 16 callstate DISCONNECTED 66863,0,0
092000.23 16 ScriptEventCode 9250 iLineState=1301
092000.25 16 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT
092000.25 16 rv add [CallerIDWasSentRequestSSN]{}
092000.27 16 rv add [Hangup Time]{07/29/2004 9:20:00 AM}
092000.28 16 Hanging up call...
092000.30 16 RecSoundStop ok
092000.31 16 PlaySoundStop err=0
092000.33 16 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
092000.36 16 fnHangupCall end
092000.41 16 linedevstate 2048 0 0
092000.41 16 callstate IDLE 66863 0 0
092000.42 16 WorkingMode@Idle=
092000.42 16 TimeoutClear
092000.45 16 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
092000.45 16 tapi Reply (LineEvReply) ok 66617 0
092001.47 16 Timer fired EV_TIMEOUT_TIMETOREINITLINE
092001.47 16 ScriptEventCode 9008 iLineState=900
092001.47 16 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
092001.48 16 ReinitTelephony due to IDLE
092001.48 16 tapic lineDeallocateCall(MainCall:66863) 0
092001.73 16 lineOpen(16)=>
092001.73 16 Waiting for a call...
092001.75 16 LineHandle=66811
092001.75 16 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
092005.05 16 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
092005.05 16 ScriptEventCode 9013 iLineState=900
Below is the log when the Voice Guide System is called from outside the office.
093015.72 12 linedevstate 2048 0 0
093015.72 12 callstate OFFERING 67189 0 4
093015.72 12 No old processes from last call (could not obtain handle) 2564, 0
093015.72 12 Answer the call at 07/29/2004 9:30:15 AM
093015.73 12 lineAnswer(67189) => 66867
093015.73 12 Lev_CallerID [9018697787,]
093015.73 12 callinfo CALLEDID
093015.73 12 callinfo ORIGIN
093015.75 12 ring 0
093016.27 12 callstate CONNECTED 67189,1,0
093016.28 12 WorkingModeTAPI@Connected=
093016.28 12 WorkingModeScript@Connected=
093016.31 12 Inband detection not enabled
093016.31 12 StartLoadedVgs at 07/29/2004 9:30:16 AM
093016.31 12 AddRVns [scriptsPath]{C:\VoiceGuide_Timeclock\}
093016.31 12 rv add [$RV_STARTTIME]{07/29/2004 9:30:16 AM}
093016.33 12 rv add [$RV_DEVICEID]{12}
093016.33 12 rv add [$RV_CIDNAME]{}
093016.33 12 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
093016.33 12 rv add [$RV_CIDNUMBER]{9018697787}
093016.33 12 tapi Reply (LineEvReply) ok 66867 0
093016.34 12 callinfo MONITORMODES
093016.34 12 TimeoutClear
093016.34 12 [CallerID] Evaluate [$RV_CIDNumber]
093016.36 12 RVreplace start: [$RV_CIDNumber]
093016.36 12 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\VoiceGuide_Timeclock\}[$RV_STARTTIME]{07/29/2004 9:30:16 AM}[$RV_DEVICEID]{12}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}
093016.36 12 RVreplace end: [9018697787]
093016.38 12 .Eval(9018697787)
093016.38 12 rv add [CallerID_Input]{9018697787}
093016.38 12 rv add [CallerID]{9018697787}
093016.38 12 Eval Expr result:[9018697787]
093016.39 12 path {9018697787} not found
093016.39 12 TimeoutClear
093016.39 12 [CallerIDWasSentRequestSSN] Number Input
093016.41 12 [CallerIDWasSentRequestSSN] Playing (EnterSocialSecurityNumber.wav)
093016.42 12 PlaySoundStart ok [C:\VoiceGuide_Timeclock\EnterSocialSecurityNumber.wav]
093016.42 12 TimeoutClear
093016.42 12 wa(3302,18017100)
093016.42 12 callinfo MONITORMODES
093019.81 12 Play End line[12] (id=180171)
093019.81 12 ScriptEventCode 8001 iLineState=1300
093019.81 12 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
093019.81 12 TimeoutSet 10 EV_TIMEOUT_HANGUP
093019.83 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093020.70 12 dtmf 1 (67189,49,2)
093020.70 12 ScriptEventCode 49 iLineState=1301
093020.72 12 LsGetNbrsRxDigits 1
093020.72 12 [CallerIDWasSentRequestSSN] Number Input 1
093020.72 12 path {1} not found
093020.73 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093020.91 12 dtmf 1 (67189,49,2)
093020.92 12 ScriptEventCode 49 iLineState=1301
093020.92 12 LsGetNbrsRxDigits 1
093020.92 12 [CallerIDWasSentRequestSSN] Number Input 11
093020.92 12 path {11} not found
093020.94 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093021.31 12 dtmf 1 (67189,49,2)
093021.31 12 ScriptEventCode 49 iLineState=1301
093021.31 12 LsGetNbrsRxDigits 1
093021.31 12 [CallerIDWasSentRequestSSN] Number Input 111
093021.33 12 path {111} not found
093021.33 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093021.61 12 dtmf 1 (67189,49,2)
093021.61 12 ScriptEventCode 49 iLineState=1301
093021.61 12 LsGetNbrsRxDigits 1
093021.63 12 [CallerIDWasSentRequestSSN] Number Input 1111
093021.63 12 path {1111} not found
093021.63 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093021.81 12 dtmf 1 (67189,49,2)
093021.81 12 ScriptEventCode 49 iLineState=1301
093021.81 12 LsGetNbrsRxDigits 1
093021.83 12 [CallerIDWasSentRequestSSN] Number Input 11111
093021.83 12 path {11111} not found
093021.83 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093022.20 12 dtmf 1 (67189,49,2)
093022.20 12 ScriptEventCode 49 iLineState=1301
093022.22 12 LsGetNbrsRxDigits 1
093022.22 12 [CallerIDWasSentRequestSSN] Number Input 111111
093022.22 12 path {111111} not found
093022.23 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093025.81 12 dtmf 1 (67189,49,2)
093025.81 12 ScriptEventCode 49 iLineState=1301
093025.81 12 LsGetNbrsRxDigits 1
093025.81 12 [CallerIDWasSentRequestSSN] Number Input 1111111
093025.83 12 path {1111111} not found
093025.83 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093026.02 12 dtmf 1 (67189,49,2)
093026.02 12 ScriptEventCode 49 iLineState=1301
093026.03 12 LsGetNbrsRxDigits 1
093026.05 12 [CallerIDWasSentRequestSSN] Number Input 11111111
093026.05 12 path {11111111} not found
093026.05 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093026.22 12 dtmf 1 (67189,49,2)
093026.22 12 ScriptEventCode 49 iLineState=1301
093026.22 12 LsGetNbrsRxDigits 1
093026.23 12 [CallerIDWasSentRequestSSN] Number Input 111111111
093026.23 12 path {111111111} not found
093026.23 12 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
093026.23 12 TimeoutClear
093026.25 12 rv add [CallerIDWasSentRequestSSN]{111111111}
093026.25 12 path {111111111} not found
093026.25 12 AddRVns [CallerIDWasSentRequestSSN_PathTaken]{success}
093026.27 12 TimeoutClear
093026.27 12 [CheckForValidSSN] DB Query
093026.28 12 db Jet mode used (To use ODBC mode specify ODBC Connect string)
093026.28 12 RVreplace start: [select * from employeestatus where SocialSecurityNumber = '$RV[CallerIDWasSentRequestSSN]']
093026.28 12 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\VoiceGuide_Timeclock\}[$RV_STARTTIME]{07/29/2004 9:30:16 AM}[$RV_DEVICEID]{12}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}[CallerID_Input]{9018697787}[CallerID]{9018697787}
CallerIDWasSentRequestSSN]{111111111}[CallerIDWasSentRequestSSN_PathTaken]{succe
s}
093026.30 12 RVreplace end: [select * from employeestatus where SocialSecurityNumber = '111111111']
093026.30 12 db About to execute a Retrieve type operation [select * from employeestatus where SocialSecurityNumber = '111111111']
093026.31 12 db [CheckForValidSSN] no records found.
093026.31 12 TimeoutClear
093026.31 12 [invalidSSN] Playing
093026.33 12 [invalidSSN] Playing (re-enterSocialSecurityNumber.wav)
093026.33 12 PlaySoundStart ok [C:\VoiceGuide_Timeclock\re-enterSocialSecurityNumber.wav]
093026.34 12 TimeoutClear
093026.34 12 RunModule PLAY end
093026.34 12 wa(4022,19009300)
093026.34 12 callinfo MONITORMODES
093030.44 12 Play End line[12] (id=190093)
093030.45 12 ScriptEventCode 8001 iLineState=1100
093030.47 12 LsPlayMsg EV_PLAY_FINISHED
093030.47 12 TimeoutSet 10 EV_TIMEOUT_HANGUP
093030.47 12 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
093030.47 12 ScriptEventCode 9002 iLineState=1101
093030.48 12 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
093030.48 12 TimeoutClear
093030.48 12 [CallerIDWasSentRequestSSN] Number Input
093030.50 12 [CallerIDWasSentRequestSSN] Playing (EnterSocialSecurityNumber.wav)
093030.50 12 PlaySoundStart ok [C:\VoiceGuide_Timeclock\EnterSocialSecurityNumber.wav]
093030.50 12 TimeoutClear
093030.50 12 wa(3302,19426500)
093030.52 12 callinfo MONITORMODES
093032.44 12 callstate DISCONNECTED 67189,0,0
093032.44 12 ScriptEventCode 9250 iLineState=1300
093032.45 12 LsGetNbrsPlayWelcMsg EV_REMOTEPARTY_DISCONNECT
093032.45 12 rv add [Hangup Time]{07/29/2004 9:30:32 AM}
093032.45 12 Hanging up call...
093032.47 12 RecSoundStop ok
093032.53 12 PlaySoundStop err=0
093032.55 12 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
093032.55 12 fnHangupCall end
093032.59 12 linedevstate 2048 0 0
093032.61 12 callstate IDLE 67189 0 0
093032.64 12 WorkingMode@Idle=
093032.64 12 TimeoutClear
093032.67 12 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
093032.67 12 tapi Reply (LineEvReply) ok 65738 0
093033.66 12 Timer fired EV_TIMEOUT_TIMETOREINITLINE
093033.66 12 ScriptEventCode 9008 iLineState=900
093033.66 12 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
093033.67 12 ReinitTelephony due to IDLE
093033.67 12 tapic lineDeallocateCall(MainCall:67189) 0
093033.83 12 lineOpen(12)=>
093033.83 12 Waiting for a call...
093033.83 12 LineHandle=65939
093033.84 12 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
Please post the script which you are using and indicate in which part of the script you have the delay that you'd like to avoid.
