Multiple Variables
Does anyone know if it is possible to use the f(x) to assign multiple result variables
within the same block?
something like
Expression to evaluate = whatever
and
assign result to the following result variable = $RV[whatever1], $RV[whatever2], $RV[whatever3]
any Ideas?
thanks
To set values of multiple Result Variables you're best to use a Run VB Script module.
You can then use either the COM functions RvSet or RvSet_RvList, or you could return multiple RVs as part of the Run_ResultREturn or Script_Return or Script_Goto or Script_Gosub functions.
Thanks for pointing me in the right direction, I would have been there for hours trying to use the F(x) mod.
Appreciate your time.
