Change Tsfraskaccept
I need to change TsfrAskAccept this wav file which play when transfer call.
Also I need to handle their response when press 1 or other digit?
You can change the sound file by just re-recording it.
The transfer accept digit cannot be changed.
I want to the voiceguide do not hang-up if the enter digit is not one?
When one accepts call but when other I wants to handle because I want to forward the call to mailbox, Please help?
I think that just specifying that path in the call transfer module will work. eg: you may be able to use:
on {5} goto [Voicemail Box 0001]
