Problem With Blind Transfering!
I am responsible of full test of VoiceGuide before buying it for my company.
I have tested it but there is a problem with blind transferring.
We have a PBX that works like this:
1- ringing
2- pick up,if you want to transfer this call ,immediately dial (Pulse Dialing) the extension (without flashhook),The originator will here a melody
3- you have to wait until the destination pick up the phone(if you don't do that,the call will come back to you again!)
4-when the destination picked up,hang up and the call will transfer.
I have used an external voice modem to test it.
When VG transfers me,I don't hear a melody and I hear a TONE dialing and after that VG hangs up the call but the call is in an undefined situation!!!
Here is the log file:
010914.09  0 callstate OFFERING 66344 0 4
010914.09  0 ring 1
010914.11  0 Answer the call at 2004/07/13 01:09:14 ق.ظ
010914.11  0 lineAnswer(66344) => 66173
010914.11  0 callstate ACCEPTED 66344 0 0
010914.27  0 tapi  Reply (LineEvReply) ok 66173 0
010914.28  0 callstate CONNECTED 66344,0,0
010914.28  0 WorkingModeTAPI@Connected=
010914.30  0 WorkingModeScript@Connected=
010914.30  0 Inband detection not enabled
010914.31  0 StartLoadedVgs at 2004/07/13 01:09:14 ق.ظ
010914.31  0 AddRVns [ScriptsPath]{D:\Akbari\My Doc\call center\voiceguide\dpco\}
010914.33  0 rv    add [$RV_STARTTIME]{2004/07/13 01:09:14 ق.ظ}
010914.33  0 rv    add [$RV_DEVICEID]{0}
010914.34  0 rv    add [$RV_CIDNAME]{}
010914.34  0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
010914.36  0 rv    add [$RV_CIDNUMBER]{}
010914.38  0 TimeoutClear
010914.38  0 [Welcome] Playing
010914.39  0 [Welcome] Playing (D:\Akbari\My Doc\call center\voiceguide\wav files\welcome.wav)
010914.47  0 PlaySoundStart ok [D:\Akbari\My Doc\call center\voiceguide\wav files\welcome.wav]
010914.48  0 TimeoutClear
010914.50  0 RunModule PLAY end
010914.52  0 wa(7996,27898400)
010922.47  0 Play End line[0] (id=278984)
010922.48  0 ScriptEventCode 8001 iLineState=1100
010922.50  0 LsPlayMsg EV_PLAY_FINISHED
010922.52  0 TimeoutSet 10 EV_TIMEOUT_HANGUP
010922.53  0 TimeoutSet 10 EV_TIMEOUT_HANGUP
010922.83  0 dtmf 0   (66344,48,2)
010922.84  0 ScriptEventCode 48 iLineState=1101
010922.86  0 LsPlayMsgFinished 0
010922.88  0 rv    add [Welcome]{0}
010922.89  0 TimeoutClear
010922.91  0 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
010923.33  0 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
010923.34  0 ScriptEventCode 9012 iLineState=1900
010923.34  0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
010923.36  0 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
010923.38  0 [Reception] Blind Transfer to 65 (Generate)
010923.39  0 tapic lineGenerateDigits(66344,!,0) => 0
010924.23  0 generate LINEGENERATETERM_DONE
010924.25  0 TimeoutSet 1 EV_TAPI_GENERATE
010924.33  0 dtmf 2   (66344,50,2)
010924.34  0 ScriptEventCode 50 iLineState=1900
010924.36  0 LsXferStart 2
010925.27  0 Timer fired EV_TAPI_GENERATE
010925.27  0 ScriptEventCode 9602 iLineState=1900
010925.28  0 LsXferStart EV_TAPI_GENERATE
010925.30  0 TimeoutSet 1 EV_HOOKFLASHFINISHED
010926.41  0 Timer fired EV_HOOKFLASHFINISHED
010926.41  0 ScriptEventCode 9200 iLineState=1905
010926.42  0 LsXferPlayVts EV_HOOKFLASHFINISHED
010926.44  0 tapic lineGenerateDigits(66344,65,0) => 0
010926.70  0 generate LINEGENERATETERM_DONE
010926.72  0 TimeoutSet 1 EV_TAPI_GENERATE
010927.78  0 Timer fired EV_TAPI_GENERATE
010927.78  0 ScriptEventCode 9602 iLineState=1905
010927.80  0 LsXferPlayVts EV_TAPI_GENERATE
010927.81  0 TimeoutSet 3 EV_TIMEOUT_HANGUP
010931.11  0 Timer fired EV_TIMEOUT_HANGUP
010931.11  0 ScriptEventCode 9001 iLineState=1905
010931.13  0 LsXferPlayVts EV_TIMEOUT_HANGUP
010931.14  0 rv    add [Hangup Time]{2004/07/13 01:09:31 ق.ظ}
010931.16  0 Hanging up call...
010931.17  0 RecSoundStop ok
010931.19  0 PlaySoundStop err=0
010931.20  0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
010931.22  0 fnHangupCall end
010931.30  0 callstate DISCONNECTED 66344,1,0
010931.30  0 ScriptEventCode 9250 iLineState=900
010931.31  0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
010931.33  0 rv    add [Hangup Time]{2004/07/13 01:09:31 ق.ظ}
010931.33  0 Hanging up call...
010931.34  0 RecSoundStop ok
010931.36  0 PlaySoundStop err=0
010931.38  0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
010931.39  0 fnHangupCall end
010931.39  0 callstate IDLE 66344 0 0
010931.41  0 WorkingMode@Idle=
010931.42  0 TimeoutClear
010931.44  0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
010931.45  0 tapi  Reply (LineEvReply) ok 65660 0
010931.45  0 tapi  Reply (LineEvReply) ok 65677 0
010932.45  0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
010932.47  0 ScriptEventCode 9008 iLineState=900
010932.47  0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
010932.48  0 ReinitTelephony due to IDLE
010932.50  0 tapic lineDeallocateCall(MainCall:66344) 0
010932.73  0 lineOpen(0)=>
010932.75  0 Waiting for a call...
010932.77  0 LineHandle=66088
010932.78  0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
010936.06  0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
010936.06  0 ScriptEventCode 9013 iLineState=900
How can I solve this problem?
Does VG need Special line for connectivity with PBX?
Does VG work with this PBX?
To set up the modem's TAPI drivers send pulse dialing instead of tone dialing you will need to edit the modems TAPI driver .inf file - questions on how to do this should be directed to the modem's manufacturer - they would know what needs to be changed in the modem's driver to make the modem dial pulse instead of tone.
I think the Dialogic card can be set up to use pulse quite easily - but again this is something we have not had to try before - pretty much all systems we worked with can just accept tone dialing.
