Bug After Register
After having to record the Pro version, while I do not use "Dialer VG", I
obtain the message:
COM interface not supported in this version.
115248,94 0 [Play 9] Playing
115248,94 0 [Play 9] Playing (PGA_Menu.wav)
115249,02 0 PlaySoundStart ok [PGA_Menu.wav]
115249,03 0 RunModule PLAY end
115257,11 0 dtmf 1 (65625,49,2)
115257,11 0 LsPlayMsg 1
115257,77 0 PlaySoundStop ok
115257,79 0 [Départs Pré-réservés] Running VB Script...
115257,79 0 RVreplace start (strlen>100)
115257,93 0 Run Script waiting... (shellid=3384, process=840)
115258,48 0 cl RvSet_RvList [aklistes1]{Prochains.wav, g6.wav,
Month06.wav, Place16.wav, Deja.wav,g5.wav, Month01.wav,
Place18.wav, Choix1.wav,g4.wav, Month01.wav, Place25.wav, Choix2.wav,
Reecoute.wav},[lsvp1]{381841738186093819303}
115258,48 0 COM interface not supported in this version.
115258,86 0 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
115258,86 0 task completed (shellid=3384, process=840)
115258,87 0 No information returned from program to VG (no
VGRUNRESULT_0.TXT or SHLRESLT.TXT)
I hope that this is only a bug and non an impossibility in this version
to oblige to buy the Enterprise version, for to no moment, this is not explained.
You are calling the COM function "RvSet_RvList" from your VBScript - and as the message in the trace correctly points out:
Please see: http://www.voiceguide.com/vgFeatures.htm
You will need to upgrade to Enterprise version to use COM interface functions.
