3-way Problems
Here is my log, i am in GENERATE mode not AT. If I don't chose to put the call on hold before the transfer it will send the dtmf tones to dial, but if I do but the call on hold before the transfer then it will not send the dtmf tones. Also if I bypass that and put my dial string to be
! ,,,, 1234567 ,,,, !
then I still receive the same effect it will not send the dtmf tones.
I am currently in the trial phase of this program and if I can get it to do a 3-way confrence initiated by the computer I plan on buying this for all my offices until then I patiently await an answer.
Thanks,
Chris
161928.72 0 callstate OFFERING 65624 0 4
161928.72 0 ring 1
161929.94 0 Lev_CallerID [8138330047,ABSTON CHARLES]
161934.72 0 ring 2
161934.72 0 Answer the call at 6/30/2004 4:19:34 PM
161934.72 0 lineAnswer(65624) => 65538
161934.72 0 callstate ACCEPTED 65624 0 0
161934.82 0 tapi Reply (LineEvReply) ok 65538 0
161934.82 0 callstate CONNECTED 65624,0,0
161934.82 0 WorkingModeTAPI@Connected=
161934.82 0 WorkingModeScript@Connected=
161934.82 0 Inband detection not enabled
161934.82 0 StartLoadedVgs at 6/30/2004 4:19:34 PM
161934.82 0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
161934.82 0 rv add [$RV_STARTTIME]{6/30/2004 4:19:34 PM}
161934.82 0 rv add [$RV_DEVICEID]{0}
161934.82 0 rv add [$RV_CIDNAME]{ABSTON CHARLES}
161934.82 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
161934.82 0 rv add [$RV_CIDNUMBER]{8138330047}
161934.82 0 TimeoutClear
161934.82 0 [Play 1] Playing
161934.82 0 tts generate start[Hello yuo have reached Chris and Malinda Abston we are not able to take your call please press 1 to leave a message or press 5 to be transfered to Chris's Cell phone.]
161934.82 0 tts generate wait
161934.82 0 RunModule PLAY end
161934.97 0 tts generate finish
161934.97 0 [Play 1] Playing (C:\Program Files\VoiceGuide\data\tts0.wav)
161935.05 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts0.wav]
161935.07 0 TimeoutClear
161935.07 0 wa(10195,78021800)
161945.25 0 Play End line[0] (id=780218)
161945.25 0 ScriptEventCode 8001 iLineState=1100
161945.25 0 LsPlayMsg EV_PLAY_FINISHED
161945.25 0 TimeoutSet 10 EV_TIMEOUT_REPLAYMSG
161946.13 0 dtmf 3 (65624,51,2)
161946.13 0 ScriptEventCode 51 iLineState=1101
161946.13 0 LsPlayMsgFinished 3
161946.13 0 rv add [Play 1]{3}
161946.13 0 TimeoutClear
161946.13 0 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
161946.57 0 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
161946.57 0 ScriptEventCode 9012 iLineState=1900
161946.57 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
161946.57 0 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
161946.57 0 [Dad (3)] Blind Conference to 9925905 (Generate)
161946.57 0 tapic lineGenerateDigits(65624,!,0) => 0
161947.08 0 generate LINEGENERATETERM_DONE
161947.08 0 TimeoutSet 1 EV_TAPI_GENERATE
161948.10 0 Timer fired EV_TAPI_GENERATE
161948.10 0 ScriptEventCode 9602 iLineState=1900
161948.10 0 LsXferStart EV_TAPI_GENERATE
161948.10 0 TimeoutSet 1 EV_HOOKFLASHFINISHED
161949.19 0 Timer fired EV_HOOKFLASHFINISHED
161949.19 0 ScriptEventCode 9200 iLineState=1905
161949.19 0 LsXferPlayVts EV_HOOKFLASHFINISHED
161949.19 0 tapic lineGenerateDigits(65624,9925905,0) => 0
161950.13 0 generate LINEGENERATETERM_DONE
161950.13 0 TimeoutSet 1 EV_TAPI_GENERATE
161951.16 0 Timer fired EV_TAPI_GENERATE
161951.16 0 ScriptEventCode 9602 iLineState=1905
161951.16 0 LsXferPlayVts EV_TAPI_GENERATE
161951.16 0 tapic lineGenerateDigits(65624,!,3,0) => 0
161951.91 0 generate LINEGENERATETERM_DONE
161951.91 0 TimeoutSet 1 EV_TAPI_GENERATE
161952.91 0 Timer fired EV_TAPI_GENERATE
161952.91 0 ScriptEventCode 9602 iLineState=1906
161952.91 0 LsXferPlayAnn EV_TAPI_GENERATE
161952.91 0 PlayFinishCause=
161952.91 0 Going down Success path (iXferType=2)
161952.91 0 TimeoutClear
161952.91 0 [Get Numbers 5] Number Input
161952.91 0 [Get Numbers 5] Playing ()
161952.91 0 ScriptEventCode 8001 iLineState=1300
161952.91 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
161952.93 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
161958.39 0 Timer fired EV_TIMEOUT_REPLAYMSG
161958.39 0 ScriptEventCode 9005 iLineState=1301
161958.39 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
161958.39 0 [Get Numbers 5] Playing ()
161958.39 0 ScriptEventCode 8001 iLineState=1300
161958.39 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
161958.39 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
161959.61 0 dtmf 9 (65624,57,2)
161959.61 0 ScriptEventCode 57 iLineState=1301
161959.61 0 LsGetNbrsRxDigits 9
161959.61 0 [Get Numbers 5] Number Input 9
161959.61 0 path {9} not found
161959.61 0 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
162000.02 0 dtmf 9 (65624,57,2)
162000.02 0 ScriptEventCode 57 iLineState=1301
162000.02 0 LsGetNbrsRxDigits 9
162000.02 0 [Get Numbers 5] Number Input 99
162000.02 0 rv add [Get Numbers 5]{99}
162000.02 0 AddRVns [Get Numbers 5_PathTaken]{matched}
162000.02 0 TimeoutClear
162000.02 0 rv add [Hangup Time]{6/30/2004 4:20:00 PM}
162000.02 0 Hanging up call... [Hangup Module]
162000.02 0 RecSoundStop ok
162000.02 0 PlaySoundStop err=0
162000.04 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
162000.04 0 fnHangupCall end
162000.11 0 callstate DISCONNECTED 65624,1,0
162000.11 0 ScriptEventCode 9250 iLineState=900
162000.11 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
162000.11 0 rv add [Hangup Time]{6/30/2004 4:20:00 PM}
162000.13 0 Hanging up call...
162000.13 0 RecSoundStop ok
162000.13 0 PlaySoundStop err=0
162000.13 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
162000.13 0 fnHangupCall end
162000.13 0 callstate IDLE 65624 0 0
162000.13 0 WorkingMode@Idle=
162000.13 0 TimeoutClear
162000.13 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
162000.13 0 tapi Reply (LineEvReply) ok 66461 0
162000.14 0 tapi Reply (LineEvReply) ok 66001 0
162001.13 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
162001.13 0 ScriptEventCode 9008 iLineState=900
162001.13 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
162001.13 0 ReinitTelephony due to IDLE
162001.13 0 tapic lineDeallocateCall(MainCall:65624) 0
162001.22 0 lineOpen(0)=>
162001.22 0 Waiting for a call...
162001.22 0 LineHandle=66254
162001.22 0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
162004.50 0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
162004.50 0 ScriptEventCode 9013 iLineState=900
Are you trying to do a transfer or a conference?
What PBX are you using and how do you usually perform transfers (or conferences) with this PBX manually?
Are you using a voice modem or a Dialogic card?
What does the original caller hear when the system attempts to do the 3 way conference?
Does the destination extension start ringing at all when you try to do the 3 way conference?
Trying to accomplish a 3-way confrence call.
no pbx. Single line system. Hoping to use it for dead end voicemails. Also for the occasional need to actually have the call transferred to someone.
Voice modem with TAPI 3.1.
The modem flashes and then nothing then flashes back. I have intercepted the line after a flashhook but no DTMF tones are sent
Is the original caller put on hold after the first flash and then yanked back from being on hold after the second flash?
What does the caller hear at these times? Does the caller hear any on-hold music?
Does your phone company support 3-way conference calls? how do you invoke the 3-way conference call if you do it yourself using a telephone handset?
The caller hears the first flash and then silence and then 3 or 4 seconds later the second flash. I haven't set up on-hold music to be heard to just silence.
Yes, we have 3-way. When I do a 3-way manually once the first leg is connected whether I called out or I was called into then I hit the flash on my phone dial the other number and then flash back.
When doing 3 way conf calls manually do you 'flash back' at any time after dialing the other number or do you need to wait until the 3rd party answers the call?
