Another Transfer Call Problem
Have a problem with a new site installation with transferring of calls. The pabx seems to recognise the hookflash, you hear a couple of clicks (no ringing tones) but the actual phone rings twice but then stops ringing. Any ideas??
Below is the Log:
093622.92 8 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
093623.36 8 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
093623.36 8 ScriptEventCode 9012 iLineState=1900
093623.36 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
093623.36 8 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
093623.36 8 [Transfer Call GE] Blind Transfer to 36 (Generate)
093623.36 8 tapic lineGenerateDigits(65556,!,100) => 0
093624.52 8 generate LINEGENERATETERM_DONE
093624.52 8 TimeoutSet 1 EV_TAPI_GENERATE
093625.55 8 Timer fired EV_TAPI_GENERATE
093625.55 8 ScriptEventCode 9602 iLineState=1900
093625.55 8 LsXferStart EV_TAPI_GENERATE
093625.55 8 TimeoutSet 1 EV_HOOKFLASHFINISHED
093626.64 8 Timer fired EV_HOOKFLASHFINISHED
093626.64 8 ScriptEventCode 9200 iLineState=1905
093626.64 8 LsXferPlayVts EV_HOOKFLASHFINISHED
093626.64 8 tapic lineGenerateDigits(65556,36,100) => 0
093626.95 8 generate LINEGENERATETERM_DONE
093626.95 8 TimeoutSet 1 EV_TAPI_GENERATE
093627.95 8 Timer fired EV_TAPI_GENERATE
093627.95 8 ScriptEventCode 9602 iLineState=1905
093627.95 8 LsXferPlayVts EV_TAPI_GENERATE
093627.95 8 TimeoutSet 3 EV_TIMEOUT_HANGUP
093631.23 8 Timer fired EV_TIMEOUT_HANGUP
093631.23 8 ScriptEventCode 9001 iLineState=1905
093631.23 8 LsXferPlayVts EV_TIMEOUT_HANGUP
Looks like your PBX requires that person transferring the call hangs up only after the recipient of the transfer picks up the handset.
You will need to use the 'Announced Transfer' option.
When you do an Announced Transfer what does the initial caller hear all this time?
What does the caller hear when the other extension is ringing and then what doe they hear after the extension ahs stopped ringing?
Could you please post a copy of VoiceGuide's Debug Printout which captures this announced transfer, and if possible please add comments in the trace to indicate what the caller is hearing at what stages - this will allow us to see what is actually happening.
I have gone back to trying with blind transfer.
handset rings 3 times and stops.
caller hears a click and nothing else.
Here is the log:
162936.84 7 TimeoutClear
162936.84 7 [Play Please Hold] Playing
162936.84 7 [Play Please Hold] Playing (WAVS\transfer.wav)
162936.92 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\tender\WAVS\transfer.wav]
162936.94 7 TimeoutClear
162936.94 7 RunModule PLAY end
162936.95 7 wa(3485,29453100)
162936.97 7 callinfo MONITORMODES
162940.50 7 wb(29453100)
162940.52 7 Play End line[7] (id=294531)
162940.52 7 ScriptEventCode 8001 iLineState=1100
162940.53 7 LsPlayMsg EV_PLAY_FINISHED
162940.53 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
162940.53 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
162940.55 7 ScriptEventCode 9002 iLineState=1101
162940.55 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
162940.55 7 TimeoutClear
162940.55 7 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
162940.91 7 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
162940.91 7 ScriptEventCode 9012 iLineState=1900
162940.91 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
162940.91 7 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
162940.92 7 [Transfer Call GE] Blind Transfer to 36 (Generate)
162940.92 7 tapic lineGenerateDigits(66513,!,100) => 0
162941.59 7 generate LINEGENERATETERM_DONE
**** caller hears click
162941.59 7 TimeoutSet 1 EV_TAPI_GENERATE
162942.58 7 Timer fired EV_TAPI_GENERATE
162942.58 7 ScriptEventCode 9602 iLineState=1900
162942.58 7 LsXferStart EV_TAPI_GENERATE
162942.58 7 TimeoutSet 1 EV_HOOKFLASHFINISHED
162943.69 7 Timer fired EV_HOOKFLASHFINISHED
162943.69 7 ScriptEventCode 9200 iLineState=1905
162943.69 7 LsXferPlayVts EV_HOOKFLASHFINISHED
162943.70 7 tapic lineGenerateDigits(66513,36,100) => 0
162944.02 7 generate LINEGENERATETERM_DONE
162944.02 7 TimeoutSet 1 EV_TAPI_GENERATE
**** handset starts to ring
162945.02 7 Timer fired EV_TAPI_GENERATE
162945.02 7 ScriptEventCode 9602 iLineState=1905
162945.02 7 LsXferPlayVts EV_TAPI_GENERATE
162945.02 7 TimeoutSet 5 EV_TIMEOUT_HANGUP
162950.50 7 Timer fired EV_TIMEOUT_HANGUP
162950.50 7 ScriptEventCode 9001 iLineState=1905
162950.50 7 LsXferPlayVts EV_TIMEOUT_HANGUP
162950.50 7 rv add [Hangup Time]{15/07/2004 4:29:50 PM}
162950.52 7 Hanging up call...
162950.53 7 RecSoundStop ok
162950.53 7 PlaySoundStop err=0
162950.55 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
162950.58 7 fnHangupCall end
162950.61 7 linedevstate 2048 0 0
162950.63 7 callstate IDLE 66513 0 0
162950.63 7 WorkingMode@Idle=
162950.63 7 TimeoutClear
162950.64 7 After Hangup script:[C:\Program Files\VoiceGuide\Scripts\tender\hangup.vgs]
162950.64 0 Script Load C:\Program Files\VoiceGuide\Scripts\tender\hangup.vgs
162950.66 7 Loaded VbsAtHangup into:2
162950.66 7 tapi Reply (LineEvReply) ok 66376 0
162950.66 7 TimeoutClear
162950.67 7 [Close Call In Use] DB Query
162950.67 7 db ODBC mode used
162950.69 7 RVreplace start: [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = $RV_LINEID]
162950.69 7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{15/07/2004 4:29:28 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check Updating_RowCount]{4}[Check Updating_1_1]{F}[Check Updating_1_2]{F}[Check Updating_1_3]{F}[Check Updating_1_4]{F}[Check Updating?_Input]{F}[Check Updating?]{F}[update Call in Use_RowCount]{1}[DbQuery StoreName_RowCount]{1}[DbQuery StoreName_1_1]{Hamilton North Tender Center}[DbQuery New Store_RowCount]{1}[DbQuery New Store_1_1]{5}[Evaluate New Store_Input]{5 < 2}[Evaluate New Store]{False}[initial Menu]{*}[DbQuery Open_RowCount]{1}[DbQuery Open_1_1]{False}[Evaluate Which week_Input]{False}[Evaluate Which week]{False}[Hangup Time]{15/07/2004 4:29:50 PM}
162950.69 7 RVreplace end: [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = 7]
162950.69 7 db About to execute a Modify type operation [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = 7]
162950.70 7 db Modify operation returned OK
162950.70 7 rv add [Close Call In Use_RowCount]{1}
162950.72 7 rv add [Hangup Time]{15/07/2004 4:29:50 PM}
162950.72 7 Hanging up call... [srlib 282]
162950.72 7 HangupCall_Common Mode=AfterHangupRun
162950.72 7 ReinitTelephony due to IDLE
162950.73 7 tapic lineDeallocateCall(MainCall:66513) 0
162950.86 7 lineOpen(7)=>
162950.86 7 Waiting for a call...
162950.88 7 LineHandle=65779
162950.88 7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
*** handset stops ringing
162954.05 7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
162954.05 7 ScriptEventCode 9013 iLineState=900
162955.23 0 sys cleanup Start
162955.23 0 sys cleanup End
It sounds like the destination handset on this PBX will stop ringing if the part which does the transferring of the call hangs up before the handset has been picked up...
What happens when you try Announced Transfer?
With Announced Transfer, does the person receiving the transferred call hear the "Press 1 to accept this call..." if the pick up the ringing handset?
Exactly the same.
No. if they pick up the hansdet before the end of the 3 rings there is no call there. They here the tone as if they were going to dial.
Has me very perplexed. If you do a transfer manually then the hookflash starts the onb hold music. The hookflash from the dialogic does not.
Very confused and I have until 1pm tomorrow before I fly back home.
So the handset is ringing but when it's picked up then there is a dial tone on the line? If something (VG) was dialing the handset then picking up the handset should answer the call...
What does the original caller hear all this time?
Please post a trace of an announced transfer indicating at different points of the trace what each party is doing/hearing.
Yes
Nothing
With Announced TRansfer the handset rings once as in the following trace:
094629.05 7 [Play Please Hold] Playing
094629.05 7 [Play Please Hold] Playing (WAVS\transfer.wav)
094629.14 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\tender\WAVS\transfer.wav]
094629.14 7 TimeoutClear
094629.14 7 RunModule PLAY end
094629.16 7 wa(3485,99071800)
094629.17 7 callinfo MONITORMODES
094632.67 7 wb(99071800)
094632.78 7 Play End line[7] (id=990718)
094632.78 7 ScriptEventCode 8001 iLineState=1100
094632.80 7 LsPlayMsg EV_PLAY_FINISHED
094632.80 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
094632.80 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
094632.81 7 ScriptEventCode 9002 iLineState=1101
094632.81 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
094632.81 7 TimeoutClear
094632.81 7 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
094633.25 7 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
094633.25 7 ScriptEventCode 9012 iLineState=1900
094633.25 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
094633.25 7 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
094633.27 7 [Transfer Call GE] Announced Transfer to 36 (Generate)
094633.27 7 tapic lineGenerateDigits(66407,!,100) => 0
*** caller hears click then nothing else
094633.92 7 generate LINEGENERATETERM_DONE
094633.94 7 TimeoutSet 1 EV_TAPI_GENERATE
094634.92 7 Timer fired EV_TAPI_GENERATE
094634.92 7 ScriptEventCode 9602 iLineState=1900
094634.92 7 LsXferStart EV_TAPI_GENERATE
094634.92 7 TimeoutSet 1 EV_HOOKFLASHFINISHED
094636.03 7 Timer fired EV_HOOKFLASHFINISHED
094636.03 7 ScriptEventCode 9200 iLineState=1905
094636.03 7 LsXferPlayVts EV_HOOKFLASHFINISHED
094636.05 7 tapic lineGenerateDigits(66407,36,100) => 0
094636.36 7 generate LINEGENERATETERM_DONE
094636.36 7 TimeoutSet 1 EV_TAPI_GENERATE
*** handset rings
094637.36 7 Timer fired EV_TAPI_GENERATE
094637.36 7 ScriptEventCode 9602 iLineState=1905
094637.36 7 LsXferPlayVts EV_TAPI_GENERATE
094637.38 7 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
094637.38 7 svb script:[C:\Program Files\VoiceGuide\Scripts\tender\hangup.vgs]
094637.67 0 Script Load C:\Program Files\VoiceGuide\Scripts\tender\hangup.vgs
094637.69 7 Loaded VbsAtHangup into:2
094637.69 7 tapi Reply (LineEvReply) ok 66339 0
094637.69 7 TimeoutClear
094637.70 7 [Close Call In Use] DB Query
094637.70 7 db ODBC mode used
094637.72 7 RVreplace start: [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = $RV_LINEID]
094637.72 7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{16/07/2004 9:46:20 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Check Updating_RowCount]{4}[Check Updating_1_1]{F}[Check Updating_1_2]{F}[Check Updating_1_3]{F}[Check Updating_1_4]{F}[Check Updating?_Input]{F}[Check Updating?]{F}[update Call in Use_RowCount]{1}[DbQuery StoreName_RowCount]{1}[DbQuery StoreName_1_1]{Hamilton North Tender Center}[DbQuery New Store_RowCount]{1}[DbQuery New Store_1_1]{5}[Evaluate New Store_Input]{5 < 2}[Evaluate New Store]{False}[initial Menu]{*}[DbQuery Open_RowCount]{1}[DbQuery Open_1_1]{False}[Evaluate Which week_Input]{False}[Evaluate Which week]{False}[Hangup Time]{16/07/2004 9:46:37 AM}
094637.72 7 RVreplace end: [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = 7]
094637.73 7 db About to execute a Modify type operation [uPDATE CALLV SET CALLINUSE = 'F' WHERE LINENO = 7]
094637.75 7 db Modify operation returned OK
094637.75 7 rv add [Close Call In Use_RowCount]{1}
094637.75 7 rv add [Hangup Time]{16/07/2004 9:46:37 AM}
094637.77 7 Hanging up call... [srlib 282]
094637.77 7 HangupCall_Common Mode=AfterHangupRun
094637.77 7 ReinitTelephony due to IDLE
094637.77 7 tapic lineDeallocateCall(MainCall:66407) 0
094637.92 7 lineOpen(7)=>
094637.94 7 Waiting for a call...
094637.94 7 LineHandle=66356
094637.95 7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
*** handset stops ringing after one ring
094641.13 7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094641.13 7 ScriptEventCode 9013 iLineState=900
Now we can see why the announced transfer is failing on this system.
After the transfer is made VoiceGuide tries to play the sound file:
C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav
but for some reason the playing of this sound file fails:
094637.48 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady]
And then VoiceGuide just hangs up, resulting in both the destination extension stopping ringing and the original caller being disconnected.
Was the TsfrCallFrom.wav file re-recorded at all?
Are you using a Dialogic card or a voice modem on this system?
OK an update!
using dialogic d/4pci-u
yes there was a problem with TsfrCallFrom.wav. Now fixed but original problem still exists.
what the caller hears is actually 2 clicks (double click) when the hookflash is registered.
When a transfer is done manually the hookflash starts the on hold music.
So is the caller put on hold, or does the caller hear the destination extension number being dialed?
neither, they hear the click and thats is all. silence until after a time (1-2 mins) they hear the busy signal.
Maybe the hookflash is set too long...
What value is it currently set to in the Dialogic TSP?
The value is set to 10 ie. 100ms
I have tried with a shorter time/s but no change. BUT that is one thing that I am not sure of, if the actual time is changing. I stop and restart the dialogic card each time I change the TSP settings. ??????
Just experiment with different hookflash settings (restarting the Dialogic service from the DCM between each change).
Changing the hookflash timing is not making any difference.
Is there a possibility we have a faulty record?
going back through the log history it looks like the hookflash time is always the same: 0.66 secs
094111.28 7 tapic lineGenerateDigits(65740,!,100) => 0
094111.94 7 generate LINEGENERATETERM_DONE
090328.94 6 tapic lineGenerateDigits(66236,!,50) => 0
090329.59 6 generate LINEGENERATETERM_DONE
BTW cannot use the announced transfer option as the systems handsets do not have intyernal tones.!!
using the TAPI settings ie. vg.ini -> TransferControl_TelBoards=TAPI
hookflash length in tsp of 3 (30ms) :
103958.28 9 [Transfer Call GE] Blind Transfer to 36 (TAPI)
103958.30 9 lineBlindTransfer(65962,36,0) in LsXferStart => 65928
104001.31 9 callstate ONHOLDPENDTRANSFER 65962 0 0
104001.61 9 linedevstate 2048 0 0
104001.61 9 callstate IDLE 65962 0 0
is my hookflash length 3.01secs or 0.3secs ??
BUT when i change to hookflash length of 5 (50ms) I get the same result (yes restarting the card after change)
104441.66 8 [Transfer Call GE] Blind Transfer to 36 (TAPI)
104441.66 8 lineBlindTransfer(65689,36,0) in LsXferStart => 65655
104444.67 8 callstate ONHOLDPENDTRANSFER 65689 0 0
104444.97 8 linedevstate 2048 0 0
104444.98 8 callstate IDLE 65689 0 0
OK this problem is back to haunt me.
It is a new site installation but with the same pbx system as before (commander).
Again using a Dialogic D4PCI-U card.
Last time I solved the problem by installing an older dialogic card (D4PCI).
Last time you(support) sent me an email saying that I could have been a problem with the installation of the software.
I know that you first have to install and setup card before installing the Feature Pack.
At my wits end as I unintsalled and reinstalled lots of times and still get the same result. (PBX ring twice and then call is lost)
One thing that happenend that may have an influence is that in the first copule of installtions of this card, windows automatically installed the driver for the D41JCT and very reinstalltion automatically defaults back to this and the only way that I can reinstall the correct driver is to got to device manager and "update driver".
Could this be causing my problem and if so how do I stop windows defaulting back to the original instaqlled driver?
What is ringing twice? The destination extension to which the transfer is made or is that the ringing heard by the caller before the VG answers the call and does the transfer?
Does the PBX allow blind transfers at all? Or does the recipient of the transfer need to pick up the handset before the party making the transfer can hang up?
the extension, the caller hears the "music on hold" which I assume means that the hookflash is registering.
Yes it does. I have bilnd transfers working on exactly the same pbx system at another site.
OK, so we're halfway there with the transfer.
So I take it that after hearing the "music on hold" for a while the caller then suddenly just hears the disconnected/busy tone?
Can you do blind transfers on this PBX manually? (this particular PBX - not some other one at another site - they may be configured differently after all...)
Maybe this PBX is set up to require that the destination extension starts ringing before the party making the transfer (VoiceGuide) can hang up?
Try adding a comma (or two) after the extension number in the Call Transfer box to make sure that the PBX starts ringing the destination extension before VG hangs up.
maybe you have misunderstood me, the extension does actually ring out loud twice.
the caller does not hear the busy/disconnect tone, just silence.
I have tried the comma (but not 2 commas) before the extension numbers and no change.
Manual blind transfers, work fine. When I was onsite, I had the telco guy there with me to make sure of things like this.
I am back onsite in a couple of days...
I've just noticed "Voiceguide for Dialogic" on the site (havent been around for awhile). Will this help me?
Try adding a comma (or two) after the extension number.
So after dialing the destination ext. number you can hang up before the destination extension is answered and the destination extension will keep on ringing... If yes then sounds like PBX is accepting blind transfers fine. Try adding comma after the ext number as per instructions above.
Won’t make any difference probably in this case - you have the destination extension ringing upon transfer - it just sounds like the transfer is being aborted by the PBX after a while... the only thing that we can think of now is that VG is hanging up too soon after dialing the transfer destination number and that is confusing the PBX somehow...
ok thanks!
I am onsite in 2 days so will try the commas AFTER ;-) the extension then.
I will keep you informed.
