Time In Am/pm Hhnn
I am trying to use the Say Number module to say the current time in am/pm mode.
It is not working - it returns the time in the 24 hour format or the program hangs
I have tried using $RV_HH$RV_NN (With/without the colon) and $RV_Hour$RV_Minute (With/without the colon)
We have VoiceGuide 5.2.1011 Enterprise Edition.
Just tried it on out test system and it worked OK for both 24 hour time and 12 hour am/pm options. ( used $RV_HH$RV_NN )
You may want to try updating to v5.2.2 - that's what we use on the test machine here.
If you still have problems with v5.2.2 could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
I upgraded to version 5.2.2
I am still having a problem with time in the am/pm format - it is 12:30 in the after noon and it says 12:30 am
In the module I have Time in format HHNN or HH:NN $RV_HH$RV_NN
Say number as Time am/pm HHNN
Below is the Event Trace Log
123042.20 7 linedevstate 2048 0 0
123042.20 7 callstate OFFERING 65725 0 4
123042.20 7 Answer the call at 6/18/2004 12:30:42 PM
123042.21 7 lineAnswer(65725) => 65674
123042.21 7 Lev_CallerID [9018697787,]
123042.21 7 callinfo CALLEDID
123042.21 7 callinfo ORIGIN
123042.21 7 ring 0
123042.74 7 callstate CONNECTED 65725,1,0
123042.76 7 WorkingModeTAPI@Connected=
123042.76 7 WorkingModeScript@Connected=
123042.79 7 Inband detection not enabled
123042.79 7 StartLoadedVgs at 6/18/2004 12:30:42 PM
123042.79 7 AddRVns [scriptsPath]{U:\My Documents\VoiceGuide\}
123042.79 7 rv add [$RV_STARTTIME]{6/18/2004 12:30:42 PM}
123042.79 7 rv add [$RV_DEVICEID]{7}
123042.80 7 rv add [$RV_CIDNAME]{}
123042.80 7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
123042.80 7 rv add [$RV_CIDNUMBER]{9018697787}
123042.80 7 tapi Reply (LineEvReply) ok 65674 0
123042.80 7 callinfo MONITORMODES
123042.82 7 TimeoutClear
123042.82 7 [CallerID] Evaluate [$RV_CIDNumber]
123042.82 7 RVreplace start: [$RV_CIDNumber]
123042.82 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{U:\My Documents\VoiceGuide\}[$RV_STARTTIME]{6/18/2004 12:30:42 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}
123042.84 7 RVreplace end: [9018697787]
123042.84 7 .Eval(9018697787)
123042.84 7 rv add [CallerID_Input]{9018697787}
123042.85 7 rv add [CallerID]{9018697787}
123042.85 7 Eval Expr result:[9018697787]
123042.85 7 path {9018697787} not found
123042.87 7 TimeoutClear
123042.87 7 RVreplace start: [$RV_HH$RV_NN]
123042.87 7 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{U:\My Documents\VoiceGuide\}[$RV_STARTTIME]{6/18/2004 12:30:42 PM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{9018697787}[CallerID_Input]{9018697787}[CallerID]{9018697787}
123042.87 7 RVreplace end: [1230]
123042.88 7 [say] Say numbers: 1230 as Time am/pm - HHNN
123042.88 7 fn PlaySoundStartNumbers YouHaveClockedIn.wav, , 1230, Time am/pm - HHNN
123042.90 7 sVbsFunctionToUse=TimeHHNN
123042.93 7 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_7_SayNumber.vbs)
123042.96 7 cl Play_Start YouHaveClockedIn.wav,12.wav,30.wav,am.wav
123042.99 7 PlaySoundStart ok [YouHaveClockedIn.wav,C:\Program Files\VoiceGuide\system\voice\12.wav,C:\Program Files\VoiceGuide\system\voice\30.wav,C:\Program Files\VoiceGuide\system\voice\am.wav]
123043.01 7 TimeoutClear
123043.01 7 wa(4681,41362503)
123043.01 7 callinfo MONITORMODES
123047.70 7 wb(41362503)
123047.74 7 Play End line[7] (id=413625)
123047.74 7 ScriptEventCode 8001 iLineState=1600
123047.76 7 LsSayNbrPlay EV_PLAY_FINISHED
123047.76 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
123054.41 7 callstate DISCONNECTED 65725,0,0
123054.41 7 ScriptEventCode 9250 iLineState=1600
123054.41 7 LsSayNbrPlay EV_REMOTEPARTY_DISCONNECT
123054.43 7 rv add [Hangup Time]{6/18/2004 12:30:54 PM}
123054.43 7 Hanging up call...
123054.43 7 RecSoundStop ok
123054.45 7 PlaySoundStop err=0
123054.45 7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
123054.45 7 fnHangupCall end
123054.48 7 linedevstate 2048 0 0
123054.48 7 callstate IDLE 65725 0 0
123054.49 7 WorkingMode@Idle=
123054.49 7 TimeoutClear
123054.54 7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
123054.54 7 tapi Reply (LineEvReply) ok 65657 0
123055.55 7 Timer fired EV_TIMEOUT_TIMETOREINITLINE
123055.55 7 ScriptEventCode 9008 iLineState=900
123055.55 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123055.55 7 ReinitTelephony due to IDLE
123055.57 7 tapic lineDeallocateCall(MainCall:65725) 0
123055.71 7 lineOpen(7)=>
Please unzip attached file and place it in VoiceGuide's \system\vbs\ subdirectory, overwriting previous file.
Looks like there was bug in the AM/PM time speaking script, the new attached version fixes this problem.
lib_num2wav.zip
