Problem With Announced Transfer
I got a problem with the announced transfer, as subject.
Transfer begins and target phone rings immediately, but...from the log I see that announce is played immediately, careless of state of the line (answered/not answered/busy). Thus, if the extension is busy (or even doesn't answer quickly) user doesn't notice.
P.s.: Busy detection work flawlessy for me in other parts of the same script (eg. the main menu, if user hangs software detects it in <5 sec.)
Regards,
Simone.
It should detect the busy tone - maybe the busy tone played by the PBX when the destination extension is busy is different to the disconnect tone which is played when the incoming external caller hangs up the phone?
That's the first thing i checked. They are the same.
The weird thing is that it doesn't wait for the answer too...dial begin and, immediately after, the announce start. That's really strange. I think it's a problem of dialogic drivers.
I've already created a .tsf file for my pbx with pbxpert and manually setted the values in tapi settings. That work for other calls but not for transfers.
Cheers,
Simone.
The announced transfer will begin to play the announce prompt immediately.
in an upcoming version of VG you will be able to select to only start playing the announce prompt after VG detects that the destination extension is picked up - but if you are using analog lines to transfer calls and do not have any CTI link with PBX to tell you when extension is picked up then it's probably better to have the prompt play in a loop (or just use a blind transfer) as detection of when extension is picked up when using just analog lines is not 100% reliable (more like 95+% reliable).
Ok, i've resolved by myself
Was my fault, i have setted tones in capi but disabilited tsffilesupport.
Now, software detects busy...but doesn't take the path indicate in "Fail" statement of transfer. Any ideas?
Simone.
Here's the debug log:
103933,62 6 linedevstate 2048 0 0
103933,63 6 callstate OFFERING 65706 0 4
103933,63 6 No old processes from last call (could not obtain handle) 620, 0
103933,63 6 Answer the call at 18/06/2004 10.39.33
103933,64 6 lineAnswer(65706) => 65689
103933,65 6 callinfo CALLEDID
103933,65 6 callinfo ORIGIN
103933,65 6 ring 0
103934,19 6 callstate CONNECTED 65706,1,0
103934,19 6 WorkingModeTAPI@Connected=
103934,19 6 WorkingModeScript@Connected=
103934,21 6 Inband detection not enabled
103934,21 6 StartLoadedVgs at 18/06/2004 10.39.34
103934,21 6 AddRVns [scriptsPath]{C:\Documents and Settings\Administrator\Desktop\}
103934,22 6 rv add [$RV_STARTTIME]{18/06/2004 10.39.34}
103934,22 6 rv add [$RV_DEVICEID]{6}
103934,23 6 rv add [$RV_CIDNAME]{}
103934,24 6 AddRVns [PathApp]{C:\Programmi\VoiceGuide\}
103934,24 6 rv add [$RV_CIDNUMBER]{}
103934,25 6 tapi Reply (LineEvReply) ok 65689 0
103934,26 6 TimeoutClear
103934,27 6 [menu] Number Input
103934,28 6 [menu] Playing (C:\Programmi\VoiceGuide\system\voice\beep1.wav)
103934,30 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\system\voice\beep1.wav]
103934,43 6 TimeoutClear
103934,44 6 wa(186,64891300)
103934,44 6 callinfo MONITORMODES
103934,45 6 callinfo MONITORMODES
103934,53 6 Play End line[6] (id=648913)
103934,55 6 ScriptEventCode 8001 iLineState=1300
103934,55 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
103934,56 6 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
103935,11 6 dtmf 2 (65706,50,2)
103935,11 6 ScriptEventCode 50 iLineState=1301
103935,13 6 LsGetNbrsRxDigits 2
103935,13 6 [menu] Number Input 2
103935,13 6 path {2} not found
103935,14 6 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
103935,24 6 dtmf 2 (65706,50,2)
103935,25 6 ScriptEventCode 50 iLineState=1301
103935,27 6 LsGetNbrsRxDigits 2
103935,27 6 [menu] Number Input 22
103935,27 6 path {22} not found
103935,29 6 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
103935,48 6 dtmf 2 (65706,50,2)
103935,49 6 ScriptEventCode 50 iLineState=1301
103935,49 6 LsGetNbrsRxDigits 2
103935,50 6 [menu] Number Input 222
103935,52 6 path {222} not found
103935,52 6 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
103935,70 6 dtmf 2 (65706,50,2)
103935,70 6 ScriptEventCode 50 iLineState=1301
103935,70 6 LsGetNbrsRxDigits 2
103935,71 6 [menu] Number Input 2222
103935,72 6 path {2222} not found
103935,73 6 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
103935,75 6 TimeoutClear
103935,75 6 rv add [menu]{2222}
103935,77 6 path {2222} not found
103935,77 6 AddRVns [menu_PathTaken]{success}
103935,80 6 TimeoutClear
103935,80 6 [db] DB Query
103935,82 6 db ODBC mode used
103935,88 6 RVreplace start: [sELECT chiama FROM test1 WHERE codice=$RV[menu];]
103935,91 6 RVns [PathSysVoice]{C:\Programmi\VoiceGuide\system\voice\}[PathApp]{C:\Programmi\VoiceGuide\}[PathDataVm]{C:\Programmi\VoiceGuide\data\}[PathVgSys]{C:\Programmi\VoiceGuide\system\}[scriptsPath]{C:\Documents and Settings\Administrator\Desktop\}[$RV_STARTTIME]{18/06/2004 10.39.34}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Programmi\VoiceGuide\}[$RV_CIDNUMBER]{}[menu]{2222}[menu_PathTaken]{success}
103935,91 6 RVreplace end: [sELECT chiama FROM test1 WHERE codice=2222;]
103935,93 6 db About to execute a Retrieve type operation [sELECT chiama FROM test1 WHERE codice=2222;]
103935,98 6 db [db] row count=1
103935,98 6 rv add [db_RowCount]{1}
103936,00 6 db get RecordsetGetRowsMax
103936,02 6 db get 999 records. (row count=1)
103936,02 6 db update RVs
103936,04 6 db about to close dbDbqDatabase
103936,05 6 db going down path [True]
103936,07 6 TimeoutClear
103936,09 6 [popup] Run Program
103936,09 6 RVreplace start: [net send simone chiamata in arrivo, trasferisco a $RV[db_1_1]]
103936,09 6 RVns [PathSysVoice]{C:\Programmi\VoiceGuide\system\voice\}[PathApp]{C:\Programmi\VoiceGuide\}[PathDataVm]{C:\Programmi\VoiceGuide\data\}[PathVgSys]{C:\Programmi\VoiceGuide\system\}[scriptsPath]{C:\Documents and Settings\Administrator\Desktop\}[$RV_STARTTIME]{18/06/2004 10.39.34}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Programmi\VoiceGuide\}[$RV_CIDNUMBER]{}[menu]{2222}[menu_PathTaken]{success}[db_RowCount]{1}[db_1_1
{105}
103936,11 6 RVreplace end: [net send simone chiamata in arrivo, trasferisco a 105]
103936,13 6 running:[net send simone chiamata in arrivo, trasferisco a 105] WindowMode:[NormalFocus]
103936,16 6 Run Program continuing...
103936,16 6 Going down Success path.
103936,18 6 dtmf 2 (65706,50,2)
103936,18 6 ScriptEventCode 50 iLineState=5900
103936,20 6 TimeoutClear
103936,21 6 TimeoutSet 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER
103936,62 6 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
103937,07 6 ScriptEventCode 9012 iLineState=1900
103937,07 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
103937,09 6 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
103937,10 6 RVreplace start: [$RV[db_1_1]]
103937,10 6 RVns [PathSysVoice]{C:\Programmi\VoiceGuide\system\voice\}[PathApp]{C:\Programmi\VoiceGuide\}[PathDataVm]{C:\Programmi\VoiceGuide\data\}[PathVgSys]{C:\Programmi\VoiceGuide\system\}[scriptsPath]{C:\Documents and Settings\Administrator\Desktop\}[$RV_STARTTIME]{18/06/2004 10.39.34}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Programmi\VoiceGuide\}[$RV_CIDNUMBER]{}[menu]{2222}[menu_PathTaken]{success}[db_RowCount]{1}[db_1_1
{105}
103937,11 6 RVreplace end: [105]
103937,12 6 [trasferisci] Announced Transfer to 105 (Generate)
103937,20 6 tapic lineGenerateDigits(65706,!,0) => 0
103937,38 6 generate LINEGENERATETERM_DONE
103937,39 6 TimeoutSet 1 EV_TAPI_GENERATE
103938,30 6 Timer fired EV_TAPI_GENERATE
103938,30 6 ScriptEventCode 9602 iLineState=1900
103938,31 6 LsXferStart EV_TAPI_GENERATE
103938,32 6 TimeoutSet 1 EV_HOOKFLASHFINISHED
103939,33 6 Timer fired EV_HOOKFLASHFINISHED
103939,34 6 ScriptEventCode 9200 iLineState=1905
103939,35 6 LsXferPlayVts EV_HOOKFLASHFINISHED
103939,42 6 tapic lineGenerateDigits(65706,105,0) => 0
103939,86 6 generate LINEGENERATETERM_DONE
103939,87 6 TimeoutSet 1 EV_TAPI_GENERATE
103940,80 6 Timer fired EV_TAPI_GENERATE
103940,80 6 ScriptEventCode 9602 iLineState=1905
103940,81 6 LsXferPlayVts EV_TAPI_GENERATE
103940,82 6 [trasferisci] Playing (C:\Programmi\VoiceGuide\system\voice\AcceptAutoCall.wav)
103940,85 6 PlaySoundStart ok [C:\Programmi\VoiceGuide\system\voice\AcceptAutoCall.wav]
103940,97 6 TimeoutClear
103940,98 6 wa(6685,65546200)
103940,99 6 callinfo MONITORMODES
103944,03 6 callstate DISCONNECTED 65706,0,0
103944,04 6 ScriptEventCode 9250 iLineState=1906
103944,05 6 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT
103944,05 6 TimeoutSet 1 EV_PLAY_FINISHED
103944,12 6 PlaySoundStop err=0
103945,10 6 Timer fired EV_PLAY_FINISHED
103945,10 6 ScriptEventCode 8001 iLineState=1906
103945,11 6 LsXferPlayAnn EV_PLAY_FINISHED
103945,12 6 tapic lineGenerateDigits(65706,!,0) => LINEERR_INVALCALLSTATE [8000001C]
103945,13 6 rv add [Hangup Time]{18/06/2004 10.39.45}
103945,14 6 Hanging up call... [lineGenerateDigits ret=-2147483620]
103945,15 6 RecSoundStop ok
103945,15 6 PlaySoundStop err=0
103945,16 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103945,20 6 fnHangupCall end
103945,32 6 linedevstate 2048 0 0
103945,32 6 callstate IDLE 65706 0 0
103945,33 6 WorkingMode@Idle=
103945,34 6 TimeoutClear
103945,35 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
103945,36 6 tapi Reply (LineEvReply) ok 65621 0
103946,31 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
103946,32 6 ScriptEventCode 9008 iLineState=900
103946,32 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
103946,33 6 ReinitTelephony due to IDLE
103946,36 6 tapic lineDeallocateCall(MainCall:65706) 0
103946,75 6 lineOpen(6)=>
103946,76 6 Waiting for a call...
103946,77 6 LineHandle=65604
103946,78 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103949,96 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103949,96 6 ScriptEventCode 9013 iLineState=900
Seems like tapi reports an error while flashing the line...why? :)
TIA,
Simone.
I'm advised we are looking into this issue and resolution may be forthcoming in v5.2.3 release.
