D4/pci On Window2000 Professional
I am have installed the d4/pci in the computer,
and want to use dialogic system release 6.0 to progarm it.
And I can not find the device when I run the dialogic product
configuration manage. I look at the documentation and seems
it only supports d4/pciu broad. Can I still have methord to
detect the broad using this software? Or I did something wong
about the configuration? thank you for you help
And I want to ask that I use the window server2003 to develop
an application controling the d4/pci voice broad. As window server2003
only supports system release 6.0, is it possible for me still use system release
6.0 to control the d4/pci voice broad?
Detect what, the card? SR detects cards installed in system automatically. If it does not detect the cards then the card is not installed properly (or is faulty) - or try using another PCI slot...
thank you for your rely.
I mean detecting the card. Because I have use 6.0 to detect it,
fault and after I remove the software, and install 5.0 to detect it.
It is sucess. So I think the card has no problem, you think I should
try other slot?
If you have problems with the Dialogic card itself not being detected by the Dialogic drivers then you should liaise with Intel/Dialogic to resolve this issue.
Once you get the card working OK then you can install and use VoiceGuide with it.
