Problem With Escalation
I can't get escalation to work.
I have included my XML file and the cooresponding log file.
I see where it says
201619.28 5 dial escalation info invalid:
but I don't know why it is invalid.
<OutDialEntry>
<PhoneNumber>19724756676</PhoneNumber>
<CallTime>Now</CallTime>
<DayTimeStart>0001</DayTimeStart>
<DaysCallAllowed>MoTuWeThFrSaSu</DaysCallAllowed>
<AnnounceMessage></AnnounceMessage>
<OnAnswer>c:\VG_Script\answer.vgs</OnAnswer>
<OnAnswerMachine>c:\VG_Script\ans_mach.vgs</OnAnswerMachine>
<AnswerTimeout>60</AnswerTimeout>
<CallRetries>0</CallRetries>
<RetryDelay>0</RetryDelay>
<RV>[Cust_ID]{0001}</RV>
<Escalation>
<OutDialEntry>
<PhoneNumber>19724756676/PhoneNumber>
<RV>[Cust_ID]{0002}</RV>
<OnNotConnected>c:\VG_Script\no_ans.vbs "$RV[Cust_ID]" "$RV[OutDial_Result]" "$RV_CALLEDNUMBER" "$RV_LINEID" </OnNotConnected>
<Escalation>
<OutDialEntry>
<RV>[Cust_ID]{0003}</RV>
</OutDialEntry>
</Escalation>
</OutDialEntry>
</Escalation>
</OutDialEntry>
201610.53 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
201610.54 0 dial callque insert tel:19724756676 scr:c:\VG_Script\answer.vgs time:406142016 esc:
<OutDialEntry>
<Escalation>
<OutDialEntry>
</OutDialEntry>
</Escalation>
</OutDialEntry>
201610.55 0 Loaded 1 entries.
201611.56 5 dial [278,19724756676,406142016,1,2359,MoTuWeThFrSaSu,,,,0,,c:\VG_Script\answer.vgs,c:\VG_Script\ans_mach.vgs,[Cust_ID]{0001},60,0,0,none,
<OutDialEntry>
<Escalation>
<OutDialEntry>
</OutDialEntry>
</Escalation>
</OutDialEntry>
201611.56 0 dial callque update id=278 next call time 0406142018
201611.57 0 dial callque DB update returned
201611.57 5 dial found entry: tel[19724756676] ann[] vgs[c:\VG_Script\answer.vgs] am[c:\VG_Script\ans_mach.vgs]
201611.58 5 Dialing: 19724756676
201611.58 5 MakeCall => 65590
201611.58 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
201611.59 5 TapiCbTrigSet 65590 7002
201612.33 5 tapi Reply (LineEvReply) ok 65590 0
201612.33 5 TapiCbTrigClear
201612.34 5 linedevstate 2048 0 0
201612.34 5 callstate DIALTONE 65607 0 0
201612.34 5 callstate DIALING 65607 0 0
201612.34 5 callstate PROCEEDING 65607 0 0
201612.35 5 callinfo CALLEDID
201612.35 5 callinfo REASON
201612.39 5 Lev_CallerID [0000,,19724756676]
201612.39 5 rv add [DNIS]{19724756676}
201612.39 5 callinfo ORIGIN
201619.27 5 callstate BUSY 65607 4 0
201619.27 0 dial callque delete id=278
201619.28 5 AddRVns [OutDial_Result]{Uncontactable_Busy}
201619.28 5 TimeoutClear
<OutDialEntry>
<Escalation>
<OutDialEntry>
</OutDialEntry>
</Escalation>
</OutDialEntry>
201619.29 5 rv add [Hangup Time]{6/14/2004 8:16:19 PM}
201619.29 5 Hanging up call... [busy]
201619.29 5 RecSoundStop ok
201619.30 5 PlaySoundStop err=0
201619.30 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
201619.30 5 Waiting for a call...
201619.31 5 fnHangupCall end
201619.35 5 linedevstate 2048 0 0
201619.35 5 callstate IDLE 65607 0 0
201619.36 5 WorkingMode@Idle=
201619.36 5 TimeoutClear
201619.36 5 LineState(iLineId).iVgsIdx = 0
201619.36 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
201619.38 5 tapi Reply (LineEvReply) ok 66359 0
201620.34 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
201620.34 5 ScriptEventCode 9008 iLineState=900
201620.34 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
201620.34 5 ReinitTelephony due to IDLE
201620.34 5 tapic lineDeallocateCall(MainCall:65607) 0
201620.52 5 lineOpen(5)=>
201620.52 5 Waiting for a call...
201620.52 5 LineHandle=65539
201620.52 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
201623.53 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
201623.53 5 ScriptEventCode 9013 iLineState=900
In your escalation info you have a malformed "PhoneNumber" entry:
should be:
This error is in both the first escalation and the second escalation...
