Cannot Use Dialler With .txt Or .xml Files
Hello Guru's
I have been trying to have my VG 5.2 dial from an entry in the
OutDial_New.txt and OutDial_New.xml in the VG data directory.
The strange thing is that as soon as I create any of theses files in
the directory they are deleted. I assume that is because VG dialler is reading
it in and then deleting thew file. Although the files are read in, the dialler never
dials a number from the file. I only use one at a time to test. However, as soon as
I enter a number manually it begins to dial it. I never uses my .txt or xml files
although it deletes then right away. Here are my .xml and .txt files
(.txt)
6:30 AM 06/10/04,7863578736, 2, 10, C:\Program Files\VoiceGuide\Scripts\imr\incomimr.wav, C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs, [RemNum]{7863578736}[MessType]{1} [CallName]{J1130157}[Message]{K1130157}[RemAccNm]{7863578736}[CallTime]{0157}
(.xml)
<OutDialEntry>
<PhoneNumber>7863578736</PhoneNumber>
<OnAnswer>C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs</OnAnswer>
<RV>[RemNum]{7863578736}[MessType]{1} [CallName]{J1130157}[Message]{K1130157}[RemAccNm]{7863578736}[CallTime]{0157} </RV>
</OutDialEntry>
I cannot seen to find the problem. Can you help. What am I doing wrong.
Sincerely
Constantine Hinds
PS my email address is copper1968@yahoo.com
as soon as I create any of theses files in the directory they are deleted. I assume that is because VG dialler is reading it in and then deleting thew file.
Correct.
The XML file looks fine, and indeed when copied works OK on our test system. Here is the extract from the trace log showing it being read in OK and then dialing:
203732.70  0 Loading from C:\test\vg5.2.2\data\OutDial_New.xml
203732.70  0 dial  callque insert tel:7863578736 scr:C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs time:406132037 esc:none
203732.72  0 Loaded 1 entries.
203733.72  6 dial  [9,7863578736,406132037,0,2359,MoTuWeThFrSaSu,,,,0,,C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs,C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs,[RemNum]{7863578736}[MessType]{1} [CallName]{J1130157}[Message]{K1130157}[RemAccNm]{7863578736}[CallTime]{0157} ,60,2,5,none,none]
203733.72  0 dial  callque update id=9 next call time 0406132042
203733.72  0 dial  callque DB update returned
203733.72  6 dial  found entry: tel[7863578736] ann[] vgs[C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs] am[C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs]
203733.72  6 Dialing: 7863578736
203733.72  6 MakeCall => 65826
203733.72  6 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
203733.72  6 TapiCbTrigSet 65826 7002
203734.33  6 tapi  Reply (LineEvReply) ok 65826 0
203734.33  6 TapiCbTrigClear
203734.33  6 linedevstate 2048 0 0
203734.33  6 callstate DIALTONE 65792 0 0
203734.33  6 callstate DIALING 65792 0 0
Could you please post a copy of VoiceGuide's Debug Printout from your system which captures the problem, this will allow us to see what is going wrong.
(the OutDial_New.txt support is only included for backward compatibility so I won't cover it - please use the XML format)
as soon as I enter a number manually it begins to dial it.
I assume that you are using the 'Telephone Number Loader' application here?
Here is the event trace log after I created the .xml file ( twice ):
180831.25 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
180831.27 0 dial callque insert tel:7863578736 scr:C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs time:406131808 esc:none
180831.30 0 Loaded 1 entries.
180832.14 0 sys cleanup Start
180832.14 0 sys cleanup End
181055.84 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
181055.85 0 dial callque insert tel:7863578736 scr:C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs time:406131810 esc:none
181055.88 0 Loaded 1 entries.
By the way - despite not dialling out, The information does end up in the
DIALLIST.TXT file when I create the OutDial_New.txt. ( What is it for anyway ?):
6:30 AM 06/10/04,3055761100, 2, 10, C:\Program Files\VoiceGuide\Scripts\imr\incomimr.wav, C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs, [RemNum]{7863578736}[MessType]{1} [CallName]{J1130324}[Message]{K1130324}[RemAccNm]{7863578736}[CallTime]{0324}
6:30 AM 06/10/04,3055761100, 2, 10, C:\Program Files\VoiceGuide\Scripts\imr\incomimr.wav, C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs, [RemNum]{7863578736}[MessType]{1} [CallName]{J1131825}[Message]{K1131825}[RemAccNm]{7863578736}[CallTime]{1825}
Thank you for responding so soon.
HHEEELLLPPP !!!!!
Looks like the OutDial_New.xml file has been loaded OK by your system.
Are you lines on your system still enabled for Dialing out? You can see this by going to the View->Line Device Config menu. The "Allow dialing on this line" should be checked.
Are you using an evaluation version or a registered version of VoiceGuide? If registered could you please post a screenshot of the "About VoiceGuide" screen showing the registration info.
Please also post the VG.INI file (in VoiceGuide directory)
No, I am NOT registered. I am evaluating the product for my company. I did not
think it mattered. Is there a limitation on the evaluation - beside the time allowed to run and the 30 module limit ? You guys have helped me before. I was the guy who could not get VG or any Dialogic card to dial out , detect touch tone , or play wav files, but passed all the Dialogic test and went off hook. Maybe you remember. By the way , that turned out to be a BAD power supply. GO GIGURE !!.
Anyway, I am still evaluating and am not registered yet. Please help. My company
is very interested and I need to show them that it can work fot us.
Please reply quickly.
Please answer the other questions in our previous post:
Yes , it IS checked off on all of my Dialogic Lines. I have 4 lines. They were all checked off by default. Sorry I did not answer the question earlier.
After loading the entries to be dialed please .ZIP up and post here:
1. the VG.INI file (in VoiceGuide directory)
2. OutDialQue.mdb file (in VoiceGuide's \data\ subdirectory)
Here is the zip file:
By the wat, I do not have MS access. I hope I do not need it. It never mentioned taht I needed it in any docmentation.
vgdat.zip
I downloaded the zip and extracted it. I renamed the originals in the VG directory and copied the extracted ones there. All three files. I was then asked to re-setup the lines, I did so and it loaded and started dilaling, ( I assume from the queue ), One problem fixed !!. However, as soon as it dials the number, I get a Microsoft error saying the "Progam has encountered errors and will be terminated" and asks if I want to report it or not. I then shuts down. Nothing I have tried has helped. I must syy that the New .exe did the trick to fix the dialling from queue problem, but has created an even bigger error. What do you think is the problem now ? I hope I am not testeing your patience !! I am waiting eagerly for your reply. Thank you.
Hello Guys:
Well, the new TAPI OCX fixed the micosoft error. You Guys really know your stuff !!. Thanks. Queued dialling from .txt and .xml files is still working ok. BUT, I now have a new problem. When VG dialled out using our outgoing script, all goes fine until it tries to use the SAY NUMBER module. At that point is suddenly hangs up. I checked the log and noticed these lines:
003937.27 6 RVreplace start: [$RV[CallTime]]
003937.33 6 RVns [OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{6/16/2004 12:39:19 AM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{6/16/2004 12:39:19 AM}[scriptStart_CalledFrom_Module]{Hangup}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\imr\}[setError_Input]{0}[setError]{0}[ECnt]{0}[Run Program 7]{1}
003937.40 6 RVreplace end: []
003937.46 6 [say Numbers 14] Say numbers: as Time am/pm - HHNN
003937.52 6 fn PlaySoundStartNumbers , , , Time am/pm - HHNN
003937.59 6 sVbsFunctionToUse=TimeHHNN
003937.68 6 Shell run Failed, err[53] Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs" //I //T:10]
003937.74 6 VBScript run Failed, dShellId=0, Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs" //I //T:10]
003937.80 6 rv add [Hangup Time]{6/16/2004 12:39:37 AM}
003937.87 6 Hanging up call... [say Number could not start VBScript]
I have included the entire log from dial out began to hang up. I hope you can help me once again. I am running XP - I do not know if that is the reason I have these strange problems.
003905.07 6 Dialing: 7863578736
003905.13 6 MakeCall => 66049
003905.19 6 TimeoutSet 90 EV_TIMEOUT_MAKECALL_NORESPONSE
003905.24 6 TapiCbTrigSet 66049 7002
003905.71 6 tapi Reply (LineEvReply) ok 66049 0
003905.78 6 TapiCbTrigClear
003905.85 6 linedevstate 2048 0 0
003905.90 6 callstate DIALTONE 66083 0 0
003905.97 6 callstate DIALING 66083 0 0
003906.05 6 callstate PROCEEDING 66083 0 0
003906.11 6 callinfo CALLEDID
003906.17 6 callinfo REASON
003906.23 6 Lev_CallerID [0000,,7863578736]
003906.29 6 rv add [DNIS]{7863578736}
003906.34 6 callinfo ORIGIN
003918.38 6 callstate CONNECTED 66083 1 0
003918.43 6 callstate CONNECTED 66083,1,0
003918.49 6 WorkingModeTAPI@Connected=
003918.54 6 WorkingModeScript@Connected=
003918.61 6 rv add [OutDial_RetriesLeft]{2}
003918.67 6 rv add [$RV_STARTTIME]{6/16/2004 12:39:18 AM}
003918.73 6 rv add [$RV_DEVICEID]{6}
003918.79 6 rv add [$RV_CIDNAME]{HINDS NORDIA}
003918.84 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
003918.90 6 rv add [$RV_CALLEDNUMBER]{7863578736}
003918.95 0 dial callque delete id=8
003919.05 6 AddRVns [OutDial_Result]{Contacted_Human}
003919.11 6 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs
003919.17 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs,,,,,0
003919.24 6 rv add [scriptEnd_Time]{6/16/2004 12:39:19 AM}
003919.30 6 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs}
003919.36 6 rv add [scriptEnd_Goto_Module]{}
003919.42 6 rv add [scriptStart_Time]{6/16/2004 12:39:19 AM}
003919.47 6 rv add [scriptStart_CalledFrom_Module]{Hangup}
003919.54 0 Script Load C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs
003919.71 6 Loaded C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs into:2
003919.77 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\imr\}
003919.83 6 cl NewVgsVgm_RunModule module not found:
003919.91 6 TimeoutClear
003919.97 6 [setError] Evaluate [0]
003920.03 6 .Eval(0)
003920.09 6 AddRVns [setError_Input]{0}
003920.14 6 AddRVns [setError]{0}
003920.20 6 AddRVns [ECnt]{0}
003920.26 6 Eval Expr result:[0] stored in $RV[ECnt]
003920.32 6 path {0} not found
003920.40 6 TimeoutClear
003920.46 6 [Run Program 7] Run Program
003920.52 6 RVreplace start: [c:\dos\testbat9.bat $RV[CallName] $RV[Message]]
003920.58 6 RVns [OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{6/16/2004 12:39:19 AM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\imr\outgo3.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{6/16/2004 12:39:19 AM}[scriptStart_CalledFrom_Module]{Hangup}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\imr\}[setError_Input]{0}[setError]{0}[ECnt]{0}
003920.65 6 RVreplace end: [c:\dos\testbat9.bat ]
003920.70 6 running:[c:\dos\testbat9.bat ] WindowMode:[NormalFocus]
003920.78 6 Run Program waiting... (shellid=2968, process=1560)
003920.95 6 [Run Program 7] Playing (incomimr.wav, WaitProc.wav)
003921.49 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\imr\incomimr.wav,C:\Program Files\VoiceGuide\Scripts\imr\WaitProc.wav]
003921.57 6 TimeoutClear
003921.61 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
003921.69 6 wa(14050,69058801)
003921.79 6 callinfo MONITORMODES
003922.82 6 Timer fired EV_TIMEOUT_CHECKONSTATE
003922.85 6 ScriptEventCode 9007 iLineState=1501
003922.89 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
003922.92 6 task still running (shellid=2968, process=1560)
003922.96 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
003924.00 6 Timer fired EV_TIMEOUT_CHECKONSTATE
003924.05 6 ScriptEventCode 9007 iLineState=1501
003924.12 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
003924.20 6 task still running (shellid=2968, process=1560)
003924.28 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
003925.36 6 Timer fired EV_TIMEOUT_CHECKONSTATE
003925.43 6 ScriptEventCode 9007 iLineState=1501
003925.51 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
003925.60 6 task still running (shellid=2968, process=1560)
003925.66 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
003926.74 6 Timer fired EV_TIMEOUT_CHECKONSTATE
003926.80 6 ScriptEventCode 9007 iLineState=1501
003926.87 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
003926.94 6 task still running (shellid=2968, process=1560)
003927.03 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
003928.25 6 Timer fired EV_TIMEOUT_CHECKONSTATE
003928.31 6 ScriptEventCode 9007 iLineState=1501
003928.37 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
003928.43 6 task completed (shellid=2968, process=1560)
003928.50 6 Found result file: C:\Program Files\VoiceGuide\Scripts\imr\SHLRESLT.TXT
003928.57 6 rv add [Run Program 7]{1}
003928.63 6 Run Result [sUCCESS, 1]
003928.75 6 PlaySoundStop err=0
003928.84 6 TimeoutClear
003928.89 6 [Play 3] Playing
003928.95 6 [Play 3] Playing (silence.wav , silence.wav , holdname.wav, sentames.wav)
003929.06 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\imr\silence.wav,C:\Program Files\VoiceGuide\Scripts\imr\silence.wav,C:\Program Files\VoiceGuide\Scripts\imr\holdname.wav,C:\Program Files\VoiceGuide\Scripts\imr\sentames.wav]
003929.13 6 TimeoutClear
003929.18 6 RunModule PLAY end
003929.25 6 wa(1098,69861001)
003929.31 6 callinfo MONITORMODES
003930.27 6 wa(3873,69861002)
003930.33 6 callinfo MONITORMODES
003934.25 6 wa(2477,69861003)
003934.31 6 callinfo MONITORMODES
003936.79 6 Play End line[6] (id=698610)
003936.85 6 ScriptEventCode 8001 iLineState=1100
003936.91 6 LsPlayMsg EV_PLAY_FINISHED
003936.96 6 TimeoutSet 10 EV_TIMEOUT_HANGUP
003937.02 6 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
003937.08 6 ScriptEventCode 9002 iLineState=1101
003937.13 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
003937.21 6 TimeoutClear
003937.93 6 RecSoundStop ok
003937.99 6 PlaySoundStop err=0
003938.05 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
003938.12 6 fnHangupCall end
003938.18 6 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs)
003938.27 6 linedevstate 2048 0 0
003938.33 6 callstate IDLE 66083 0 0
003938.39 6 WorkingMode@Idle=
003938.45 6 TimeoutClear
003938.56 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
003938.62 6 tapi Reply (LineEvReply) ok 66117 0
003939.59 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
003939.65 6 ScriptEventCode 9008 iLineState=900
003939.71 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
003939.78 6 ReinitTelephony due to IDLE
003939.85 6 tapic lineDeallocateCall(MainCall:66083) 0
003940.03 6 lineOpen(6)=>
003940.09 6 Waiting for a call...
003940.15 6 LineHandle=66134
003940.21 6 TimeoutSet 5 EV_TIMEOUT_ATERIDLE_ALLOWOUT
003945.28 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
003945.34 6 ScriptEventCode 9013 iLineState=900
After seeing the above, I decided to make a very simple script with two modules.
1) a SAY NUMBER MODULE - to say the time in HHNN
and
2) A HANG UP Module
I set up the new script and called in. The system simply answered and then hung up. But again, I saw the same line in the log:
004441.72 6 Hanging up call... [say Number could not start VBScript]
Below is the entire log for that simple script.
011434.35 6 linedevstate 2048 0 0
011434.36 6 callstate OFFERING 66338 0 4
011434.37 6 Answer the call at 6/16/2004 1:14:34 AM
011434.39 6 lineAnswer(66338) => 66321
011434.40 6 Lev_CallerID [7863578736,HINDS NORDIA,0000]
011434.41 6 rv add [DNIS]{0000}
011434.51 6 Lev_CallerID [7863578736,HINDS NORDIA,0000]
011434.52 6 callinfo CALLEDID
011434.53 6 callinfo ORIGIN
011434.54 6 ring 0
011434.93 6 callstate CONNECTED 66338 1 0
011434.94 6 callstate CONNECTED 66338,1,0
011434.96 6 WorkingModeTAPI@Connected=
011434.98 6 WorkingModeScript@Connected=
011435.02 6 Inband detection not enabled
011435.04 6 StartLoadedVgs at 6/16/2004 1:14:35 AM
011435.06 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Imr\}
011435.08 6 rv add [$RV_STARTTIME]{6/16/2004 1:14:35 AM}
011435.11 6 rv add [$RV_DEVICEID]{6}
011435.13 6 rv add [$RV_CIDNAME]{HINDS NORDIA}
011435.22 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
011435.30 6 rv add [$RV_CIDNUMBER]{7863578736}
011435.39 6 tapi Reply (LineEvReply) ok 66321 0
011435.47 6 callinfo MONITORMODES
011435.59 6 TimeoutClear
011435.68 6 [say Numbers 2] Say numbers: 0246 as Time am/pm - HHNN
011435.77 6 fn PlaySoundStartNumbers holdname.wav, Thankyou.wav, 0246, Time am/pm - HHNN
011435.87 6 sVbsFunctionToUse=TimeHHNN
011435.98 6 Shell run Failed, err[53] Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs" //I //T:10]
011436.07 6 VBScript run Failed, dShellId=0, Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs" //I //T:10]
011436.16 6 rv add [Hangup Time]{6/16/2004 1:14:36 AM}
011436.25 6 Hanging up call... [say Number could not start VBScript]
011436.34 6 RecSoundStop ok
011436.42 6 PlaySoundStop err=0
011436.52 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
011436.61 6 fnHangupCall end
011436.70 6 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs)
011436.96 6 linedevstate 2048 0 0
011437.05 6 callstate IDLE 66338 0 0
011437.13 6 WorkingMode@Idle=
011437.22 6 TimeoutClear
011437.31 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
011437.40 6 tapi Reply (LineEvReply) ok 66304 0
011438.38 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
011438.46 6 ScriptEventCode 9008 iLineState=900
011438.55 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
011438.64 6 ReinitTelephony due to IDLE
011438.73 6 tapic lineDeallocateCall(MainCall:66338) 0
011438.96 6 lineOpen(6)=>
011439.05 6 Waiting for a call...
011439.13 6 LineHandle=66303
011439.22 6 TimeoutSet 5 EV_TIMEOUT_ATERIDLE_ALLOWOUT
011444.31 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
011444.39 6 ScriptEventCode 9013 iLineState=900
I do not know much, but there seems to be some thing wrong with the
SAY NUMBER MODULE-
Please let me know what you find. I am eagerly waiting. I hope you guys are
not tired of me yet.
I downloaded and installed the "scripten.exe" file form Microsoft and installed it.
NO DIFFERENCE. This is supposed to be the new VBSCRIPT engine. I think I got the right file. However the scrip still crashes and gives the same vbscript error.
Any more Ideas ? I'm at my wits end. Is there anyway to test the VBscript engine outside of Voice Guide. ?
You wouldn't happen to have any anti-Virus software running on this machine?
Some anti-virus software tries to block VBScripting commands.
If you have any running please turn them off and try again.
Can you try re-installing Windows?
Well, I reloaded Windows and now all is OK. Thank you all for your time and patience. I have another question, but I think it should be addressed in a separate
thread. Again, thank you. Look out for my new question.
