VoiceGuide Call Transfer
I HAVE A QUESTION:
I HAVE INSTALL VOICEGUIDE AND WORKING WELL. I HAVE USING MODEM OF NETODRAGON 56K VOICE MODEM. THE PROBLEM WILL HAPPEN WHEN USING TRANSFER. WHEN I TRY IT, THE VG CAN GET FLASH HOOK BUT THE MODEM CAN'T DIAL THE TRANSFER NUMBER. THEN THE VG RETURN TO WAITING FOR CALL...
IF I DON'T PUT "!" MARK IN THE PBX SETTING. THE MODEM CAN DIAL BUT OF COURSE CAN'T TRANSFER IF NO HOOK FLASH.
PLEASE HELP ME TO FIND THE SOLUTION.
THANKS
WE ARE GOING TO BUY THIS SOFTWARE SOON
This is the record of the script.
Please let me know.
195320.60 0 callstate OFFERING 65937 0 4
195320.61 0 No old processes from last call (could not obtain handle) 768, 0
195320.61 0 Answer the call at 01/08/2003 19:53:20
195320.61 0 lineAnswer(65937) => 65902
195320.61 0 ring 1
195320.61 0 callstate ACCEPTED 65937 0 0
195323.70 0 tapi Reply (LineEvReply) ok 65902 0
195323.72 0 callstate CONNECTED 65937,0,0
195323.73 0 WorkingModeTAPI@Connected=
195323.73 0 WorkingModeScript@Connected=
195323.73 0 Inband detection not enabled
195323.73 0 StartLoadedVgs at 01/08/2003 19:53:23
195323.73 0 AddRVns [scriptsPath]{E:\Program Files\VoiceGuide\Scripts\}
195323.73 0 rv add [$RV_STARTTIME]{01/08/2003 19:53:23}
195323.73 0 rv add [$RV_DEVICEID]{0}
195323.73 0 rv add [$RV_CIDNAME]{}
195323.73 0 AddRVns [PathApp]{E:\Program Files\VoiceGuide\}
195323.73 0 rv add [$RV_CIDNUMBER]{}
195323.74 0 TimeoutClear
195323.74 0 [Play 2] Playing
195323.76 0 tts generate start[Hello]
195323.76 0 tts generate wait
195323.76 0 RunModule PLAY end
195323.80 0 tts generate finish
195323.80 0 [Play 2] Playing (E:\Program Files\VoiceGuide\data\tts0.wav)
195323.87 0 PlaySoundStart ok [E:\Program Files\VoiceGuide\data\tts0.wav]
195323.87 0 TimeoutClear
195323.88 0 wa(1106,30746900)
195324.00 0 Play End line[0] (id=307469)
195324.00 0 ScriptEventCode 8001 iLineState=1100
195325.01 0 LsPlayMsg EV_PLAY_FINISHED
195325.01 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
195327.45 0 dtmf 2 (65937,50,2)
195327.46 0 ScriptEventCode 50 iLineState=1101
195327.46 0 LsPlayMsgFinished 2
195327.47 0 rv add [Play 2]{2}
195327.47 0 TimeoutClear
195327.47 0 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
195327.81 0 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
195327.81 0 ScriptEventCode 9012 iLineState=1900
195327.82 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
195327.82 0 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
195327.82 0 [ACCount] Blind Transfer to 255 (Generate)
195327.83 0 tapic lineGenerateDigits(65937,!,0) => 0
195328.34 0 generate LINEGENERATETERM_DONE
195328.34 0 TimeoutSet 1 EV_TAPI_GENERATE
195329.34 0 Timer fired EV_TAPI_GENERATE
195329.34 0 ScriptEventCode 9602 iLineState=1900
195329.34 0 LsXferStart EV_TAPI_GENERATE
195329.34 0 TimeoutSet 1 EV_HOOKFLASHFINISHED
195330.34 0 Timer fired EV_HOOKFLASHFINISHED
195330.34 0 ScriptEventCode 9200 iLineState=1905
195330.36 0 LsXferPlayVts EV_HOOKFLASHFINISHED
195330.36 0 tapic lineGenerateDigits(65937,255,0) => 0
195330.72 0 generate LINEGENERATETERM_DONE
195330.73 0 TimeoutSet 1 EV_TAPI_GENERATE
195331.67 0 Timer fired EV_TAPI_GENERATE
195331.67 0 ScriptEventCode 9602 iLineState=1905
195331.68 0 LsXferPlayVts EV_TAPI_GENERATE
195331.68 0 TimeoutSet 3 EV_TIMEOUT_HANGUP
195334.70 0 Timer fired EV_TIMEOUT_HANGUP
195334.70 0 ScriptEventCode 9001 iLineState=1905
195334.70 0 LsXferPlayVts EV_TIMEOUT_HANGUP
195334.70 0 rv add [Hangup Time]{01/08/2003 19:53:34}
195334.71 0 Hanging up call...
195334.72 0 RecSoundStop ok
195334.72 0 PlaySoundStop err=0
195334.73 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
195334.73 0 fnHangupCall end
195334.82 0 callstate DISCONNECTED 65937,1,0
195334.82 0 ScriptEventCode 9250 iLineState=900
195334.82 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
195334.83 0 rv add [Hangup Time]{01/08/2003 19:53:34}
195334.83 0 Hanging up call...
195334.84 0 RecSoundStop ok
195334.84 0 PlaySoundStop err=0
195334.84 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
195334.85 0 fnHangupCall end
195334.85 0 callstate IDLE 65937 0 0
195334.86 0 WorkingMode@Idle=
195334.86 0 TimeoutClear
195334.88 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
195334.88 0 tapi Reply (LineEvReply) ok 66090 0
195334.88 0 tapi Reply (LineEvReply) ok 66244 0
195335.80 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
195335.80 0 ScriptEventCode 9008 iLineState=900
195335.80 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
195335.80 0 ReinitTelephony due to IDLE
195335.81 0 tapic lineDeallocateCall(MainCall:65937) 0
195335.89 0 lineOpen(0)=>
195335.91 0 Waiting for a call...
195335.91 0 LineHandle=66124
195335.91 0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
195338.93 0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
195338.93 0 ScriptEventCode 9013 iLineState=900
Trace shows that the modems driver reported back to VoiceGuide that it has played the extension digits OK:
You should approach the modem manufacturer to see what is wrong here, but in practice you'd be just better of buying and using a Dialogic card instead.
