ODBC connection to Borland Interbase 6.5
please help me...
I'm trying to connect to Interbase database using ODBC driver.
Please click on this link where I put all the description and screenshots of what I have and what is happening.
http://primedebtsoft.com/VG.htm
Appreciate your help.
Thanks a lot.
Nick Varnitski :(
Thanks for the good summary of the problem.
Hanve you defined the Data Source using the "ODBC Data Source Administrator" ?
the name specified for the entry in the "ODBC Data Source Administrator" should then be specified in the VoiceGuide's "ODBC Data Source" text box.
A good test to see if ODBC setup works is try to link to your ODBC Database using MS Access (using a 'Link Table') - if you have MS Access installed on this machine...
Another appraoch is to write a VB Script which connects and retrieves the data for you - and after you have it working you can just run it within VoiceGuide's Run VBS module...
Thanks for your suggestion about Access!!!
Here is what I was able to do:
From Access I linked to Interbase tables via ODBC, then I connected to Access from VG and guess what? IT WORKED!!!
I'm able to retreive information from my InterBase database...
The only question... still can not get.. why can I connect from Access but not from VG? It's the same driver!!!
any suggestions, guys???
Thansk a lot!
Nick.
Hello, Technical Support,
could you please advise me or work with me to find out why I can't connect directly to my InterBase database (using ODBC) but I am able to connect to it via Access (through linked tables in Access). Pleeeeaaase!!!!
thanks a lot...
Nick
I would try to test several possible variants of the 'ODBC Connect String' - most problems with ODBC connections are caused by this field not being specified as required by the DAO database drivers which VoiceGuide is using...
As a first thing I'd try doing is specifying the name of the ODBC driver in your connect string as well. This is what I found is necessary in some cases.
Below is a 'ODBC Connect String' for MS Access which shows how this driver name is specified:
ODBC;DRIVER={Microsoft Access Driver (*.mdb)}
without specifying the driver name ODBC connections to MS Access fail - this may be the case with Interbase 6.5...
I'm attaching traces of a successful select from MS Access using a direct connection (specifying the database filename) and using the ODBC data source.
49937 6 [GetAllMdb] DB Query
49937 6 Jet mode used (To use ODBC mode specify ODBC Connect string)
49937 6 About to execute Retrieve Operation [sELECT * FROM PATIENTS where ID=112]
49937 6 [GetAllMdb] row count=1
49953 6 [GetAllOdbc] DB Query
49953 6 ODBC mode used
49953 6 About to execute Retrieve Operation [sELECT * FROM PATIENS where ID=112]
49953 6 [GetAllOdbc] row count=1
:P:P Thank you so much!!! It all worked! i added the driver name and everything is working now!
Thanks a lot!
Nick
I want to connect from ODBC to Interbase 6.5 Database,
I was using Easysoft ODBC software to connection but it expried so I could not connect to Database.
Does anybody know how any program name for the connection ?
