Board Detection
I'm trying to install another D/4EPCI, the PC detects the new device but using the Dialogic DCM, with auto-detection mode, nothing appears. Do you know why the DCM does not see it ?
MH
If the DCM cannot see it then the card could be dead. I'd speak with the Dialogic distributor from where the card was purchased.
Another reason why the card could not be seen is because of IRQ or memory clash with other PCI devices on the system...
I have tried 3 other D/41E PCI boards, on the same PC but noone is detected...
Do you think it can come from the PC configuration ?
I have Windows 2000 installed ..No other PCI is installed ..
Thank you for your help
MH
Maybe something in the BIOS configuration of this system which prevents Dialogic cards from working... best to speak with the Dialogic distributor about this.
