From Text File To Variable
I would like to read 1 word from my text file.
Then I would like to insert the content of that file into the variable
$RV_VarTXT and have it accessible from other modules.
How do I go about that?
Thank you
I used the following script in "VBS" module.
set fileV = fso.OpenTextFile("X:\VarJobOffers.txt", 1)
sEntireFile = fileV.ReadAll
fileV.close
vg.RvSet $RV_LINEID, "Job_Offers", sEntireFile
set vg = Nothing 'always deallocate after use...
set fileV = Nothing 'always deallocate after use...
set fso = Nothing
In next module "f(x)"
I was trying to acces $RV[Job_Offers] variable but it is empty even that
that VarJobOffers.txt is not empty.
What am I doing wrong here.
The script cannot find file $RV[Job_Offers].wav
IHelp please. t drives me crazy.
211159.31 5 linedevstate 2048 0 0
211159.31 5 callstate OFFERING 65962 0 4
211159.31 5 Answer the call at 5/10/2004 9:11:59 PM
211159.33 5 lineAnswer(65962) => 65945
211159.33 5 callinfo CALLEDID
211159.33 5 callinfo ORIGIN
211159.33 5 ring 0
211159.88 5 callstate CONNECTED 65962,1,0
211159.88 5 WorkingModeTAPI@Connected=
211159.88 5 WorkingModeScript@Connected=
211159.91 5 Inband detection not enabled
211159.91 5 StartLoadedVgs at 5/10/2004 9:11:59 PM
211159.91 5 AddRVns [scriptsPath]{X:\}
211159.91 5 rv add [$RV_STARTTIME]{5/10/2004 9:11:59 PM}
211159.91 5 rv add [$RV_DEVICEID]{5}
211159.91 5 rv add [$RV_CIDNAME]{}
211159.91 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
211159.91 5 rv add [$RV_CIDNUMBER]{}
211159.91 5 tapi Reply (LineEvReply) ok 65945 0
211159.91 5 callinfo MONITORMODES
211159.91 5 TimeoutClear
211159.91 5 [Play 1] Playing
211159.92 5 [Play 1] Playing (1\Welcome.wav)
211159.94 5 PlaySoundStart ok [X:\1\Welcome.wav]
211159.94 5 TimeoutClear
211159.94 5 RunModule PLAY end
211159.94 5 wa(2980,46959300)
211159.94 5 callinfo MONITORMODES
211202.94 5 wb(46959300)
211202.98 5 Play End line[5] (id=469593)
211202.98 5 ScriptEventCode 8001 iLineState=1100
211202.98 5 LsPlayMsg EV_PLAY_FINISHED
211202.98 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
211202.98 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
211202.98 5 ScriptEventCode 9002 iLineState=1101
211202.98 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
211202.98 5 TimeoutClear
211202.98 5 [iD_TimeDate_Script] Running VB Script...
211203.02 5 VBScript Run continuing...
211203.02 5 TimeoutClear
211203.02 5 [Lng_Choice] Playing
211203.02 5 [Lng_Choice] Playing (1\Pause0_5.wav,1\Lng_Choice.wav,1\Hear_Again.wav)
211203.03 5 PlaySoundStart ok [X:\1\Pause0_5.wav,X:\1\Lng_Choice.wav,X:\1\Hear_Again.wav]
211203.03 5 TimeoutClear
211203.03 5 RunModule PLAY end
211203.03 5 wa(6647,47268702)
211203.03 5 callinfo MONITORMODES
211206.17 5 dtmf 1 (65962,49,2)
211206.17 5 ScriptEventCode 49 iLineState=1100
211206.17 5 LsPlayMsg 1
211206.23 5 PlaySoundStop err=0
211206.23 5 rv add [Lng_Choice]{1}
211206.23 5 TimeoutClear
211206.23 5 [script_Lng_Choice] Running VB Script...
211206.23 5 RVreplace start (strlen>500)
211206.23 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/10/2004 9:11:59 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Lng_Choice]{1}
211206.25 5 VBScript Run continuing...
211206.25 5 TimeoutClear
211206.25 5 [Evaluate_Lng] Evaluate [$RV[Lng_Choice]]
211206.25 5 RVreplace start: [$RV[Lng_Choice]]
211206.25 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/10/2004 9:11:59 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Lng_Choice]{1}
211206.25 5 RVreplace end: [1]
211206.25 5 .Eval(1)
211206.25 5 AddRVns [Evaluate_Lng_Input]{1}
211206.25 5 AddRVns [Evaluate_Lng]{1}
211206.25 5 Eval Expr result:[1]
211206.27 5 TimeoutClear
211206.27 5 [setLanguage_English] Evaluate ["C:\Program Files\VoiceGuide\system\voice"]
211206.27 5 .Eval(Cstr("C:\Program Files\VoiceGuide\system\voice"))
211206.27 5 AddRVns [setLanguage_English_Input]{"C:\Program Files\VoiceGuide\system\voice"}
211206.27 5 AddRVns [setLanguage_English]{C:\Program Files\VoiceGuide\system\voice}
211206.27 5 AddRVns [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\system\voice}
211206.27 5 Eval Expr result:[C:\Program Files\VoiceGuide\system\voice] stored in $RV[DIRSYSTEMVOICE]
211206.27 5 path {C:\Program Files\VoiceGuide\system\voice} not found
211206.27 5 stack idx=1
211206.27 5 rv add [scriptStart_Time]{5/10/2004 9:12:06 PM}
211206.27 5 rv add [scriptStart_CalledFrom_Script]{X:\Start.vgs}
211206.27 5 rv add [scriptStart_CalledFrom_Module]{SetLanguage_English}
211206.27 0 Script Load X:\Options.vgs
211206.30 5 Loaded X:\Options.vgs into:2
211206.30 5 AddRVns [scriptsPath]{X:\}
211206.30 5 TimeoutClear
211206.30 5 [Options] Playing
211206.30 5 RVreplace start: [$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Register.wav,$RV[Lng_Choice]\Options.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\$RV[Job_Offers].wav,$RV[Lng_Choice]\Hear_Again.wav]
211206.30 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/10/2004 9:11:59 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Lng_Choice]{1}[Evaluate_Lng_Input]{1}[Evaluate_Lng]{1}[setL
nguage_English_Input]{"C:\Program Files\VoiceGuide\system\voice"}[setLanguage_English]{C:\Program Files\VoiceGuide\system\voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\system\voice}[scriptStart_Time]{5/10/2004 9:12:06 PM}[scriptStart_CalledFrom_Script]{X:\Start.vgs}[scriptStart_CalledFrom_Module]{SetLanguage_English}[scriptsPath]
X:\}
211206.30 5 RVreplace end: [1\Pause0_5.wav,1\Pause0_5.wav,1\Register.wav,1\Options.wav,1\Pause0_5.wav,1\.wav,1\Hear_Again.wav]
211206.31 5 [Options] Playing (1\Pause0_5.wav,1\Pause0_5.wav,1\Register.wav,1\Options.wav,1\Pause0_5.wav,1\.wav,1\Hear_Again.wav)
211206.31 5 File not found [1\.wav]
211206.31 5 PlaySoundStart ok [X:\1\Pause0_5.wav,X:\1\Pause0_5.wav,X:\1\Register.wav,X:\1\Options.wav,X:\1\Pause0_5.wav,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav,X:\1\Hear_Again.wav]
211206.31 5 TimeoutClear
211206.31 5 RunModule PLAY end
211206.31 5 wa(14428,47598406)
211206.33 5 callinfo MONITORMODES
211220.77 5 wb(47598406)
211220.81 5 Play End line[5] (id=475984)
211220.81 5 ScriptEventCode 8001 iLineState=1100
211220.81 5 LsPlayMsg EV_PLAY_FINISHED
211220.81 5 TimeoutSet 6 EV_TIMEOUT_REPLAYMSG
211227.30 5 Timer fired EV_TIMEOUT_REPLAYMSG
211227.30 5 ScriptEventCode 9005 iLineState=1101
211227.30 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
211227.30 5 RVreplace start: [$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Register.wav,$RV[Lng_Choice]\Options.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\$RV[Job_Offers].wav,$RV[Lng_Choice]\Hear_Again.wav]
211227.30 5 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{X:\}[$RV_STARTTIME]{5/10/2004 9:11:59 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Lng_Choice]{1}[Evaluate_Lng_Input]{1}[Evaluate_Lng]{1}[setL
X:\}
211227.30 5 RVreplace end: [1\Pause0_5.wav,1\Pause0_5.wav,1\Register.wav,1\Options.wav,1\Pause0_5.wav,1\.wav,1\Hear_Again.wav]
211227.30 5 [Options] Playing (1\Pause0_5.wav,1\Pause0_5.wav,1\Register.wav,1\Options.wav,1\Pause0_5.wav,1\.wav,1\Hear_Again.wav)
211227.30 5 File not found [1\.wav]
211227.31 5 PlaySoundStart ok [X:\1\Pause0_5.wav,X:\1\Pause0_5.wav,X:\1\Register.wav,X:\1\Options.wav,X:\1\Pause0_5.wav,C:\Program Files\VoiceGuide\system\voice\SoundFileNotFound.wav,X:\1\Hear_Again.wav]
211227.31 5 TimeoutClear
211227.31 5 wa(14428,49696806)
211227.31 5 callinfo MONITORMODES
211234.17 0 sys cleanup Start
211234.17 0 sys cleanup End
211241.75 5 wb(49696806)
211241.80 5 Play End line[5] (id=496968)
211241.80 5 ScriptEventCode 8001 iLineState=1100
211241.80 5 LsPlayMsg EV_PLAY_FINISHED
211241.80 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
211241.80 5 TimeoutSet 7 EV_TIMEOUT_GOTOMODULE
Please post the script you are using as well.
Looking at the trace I don't think your VG Script is set up to call the module in which you dothe setting of the $RV[Job_Offers]....
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Job_Offers
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[Options]
Type=Play
DispSize=69
Txt=Play a sound file, then await a response...
PlayFile1=$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Register.wav,$RV[Lng_Choice]\Options.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\$RV[Job_Offers].wav,$RV[Lng_Choice]\Hear_Again.wav
Replay=1,6
strTtsText=
on {1} goto [script_Options]
on {2} goto [script_Options]
on {3} goto [script_Options]
on {4} goto [invalid_No]
on {5} goto [invalid_No]
on {6} goto [invalid_No]
on {7} goto [invalid_No]
on {8} goto [invalid_No]
on {9} goto [invalid_No]
on {*} goto [invalid_No]
on {#} goto [invalid_No]
on {0} goto [Repeat_Options]
on {timeout 7} goto [Hangup_Msg]
Position=28,112
[script_Options]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=0
VbScript=Dim xlApp, xlBook, xlSht
Dim filename, value1, value2, value3, value4
on error resume next
filename = "X:\CarFile.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
xlApp.DisplayAlerts = False
Call GetToFirstItem(xlSht, 1, "ID")
'Call GetToFirstItem(Sheets("Sheet1"), 1, "ID")
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
Sub GetToFirstItem(wkSheet, iColumn, ColumnStartCaption)
wkSheet.Select
'Range(iColumn & "1").Select
'wkSheet.Range("A1").Select
y = 0
Dim temp
Do Until temp = ColumnStartCaption
y = y + 1
temp = wkSheet.Cells(y, iColumn)
Loop
y = y + 1
Do Until temp = ""
y = y + 1
Loop
'write data into the spreadsheet
'wkSheet.Cells(y-1, iColumn+1) = $RV[Options]
If ($RV[Options]=1) Then
wkSheet.Cells(y - 1, iColumn + 5) = "Register"
ElseIf ($RV[Options]=2) Then
wkSheet.Cells(y - 1, iColumn + 5) = "Leave Msg"
ElseIf ($RV[Options]=3) Then
wkSheet.Cells(y - 1, iColumn + 5).Font.Color = RGB(0,0,0) 'works
wkSheet.Cells(y - 1, iColumn + 5).Font.Bold = False 'works
'wkSheet.Cells(y - 1, iColumn + 5).Borders.Color = RGB(255,0,0) 'works
'wkSheet.Cells(y - 1, iColumn + 5).Interior.Color = RGB(255,0,0) 'works - sets background color
wkSheet.Cells(y - 1, iColumn + 5).Font.Color = RGB(255,0,0) 'works
'wkSheet.Cells(y - 1, iColumn + 5).Font.Size = 10 'works
wkSheet.Cells(y - 1, iColumn + 5).Font.Bold = True 'works
'wkSheet.Cells(y - 1, iColumn + 5) = "Listen Job Offers"
wkSheet.Cells(y, iColumn + 5).Font.Bold = $RV[Job_Offers]
Else wkSheet.Cells(y - 1, iColumn + 5) = "Disconnect"
End If
End Sub
VbsHoldPlay=
on {success} goto [Evaluate]
on {fail} goto [Evaluate]
on {timeout 0} goto [Evaluate]
Position=35,345
[invalid_No]
Type=Play
DispSize=69
PlayFile1=$RV[Lng_Choice]\Invalid_Selection.wav
Replay=0,0
strTtsText=
on {timeout 0} goto [Options]
Position=290,107
[Repeat_Options]
Type=Play
DispSize=69
Replay=0,0
strTtsText=
Position=164,242
[Evaluate]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression=$RV[Job_Offers]
ExprNewRV=
ExprStoreRV=0
on {true} goto [Evaluate_JO_YES]
on {false} goto [Evaluate_JO_NO]
Position=35,456
[Hangup the Call]
Type=Hangup the Call
DispSize=69
Txt=Hangup the call.
Position=564,453
[Hangup_Msg]
Type=Play
DispSize=69
PlayFile1=$RV[Lng_Choice]\Hangup_Msg.wav
Replay=0,0
strTtsText=
on {timeout 0} goto [Hangup the Call]
Position=569,321
[Leave_Msg]
Type=Play
DispSize=69
PlayFile1=$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Leave_Msg.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Pound_Finish.wav,$RV[Lng_Choice]\Pound_Sign.wav,$RV[Lng_Choice]\Pause0_5.wav,$RV[Lng_Choice]\Pause0_5.wav
Replay=0,0
strTtsText=
on {timeout 0} goto [Record_Msg]
Position=227,680
[Record_Msg]
Type=Record
DispSize=69
Txt=Record a sound file, and go down different paths depending on what digit was pressed to terminate recording...
RecFile=MWC_GeneralMsg\$RV[EnterPhone]Date$RV_MONTH_$RV_DATETime$RV_HOUR_$RV_MINUTE.wav
PlayTone=ON
on {timeout 60} goto [ThankYou]
on {silence} goto [ThankYou]
on {#} goto [ThankYou]
Position=411,679
[ThankYou]
Type=Play
DispSize=69
PlayFile1=$RV[Lng_Choice]\Pause1_0.wav, $RV[Lng_Choice]\ThankYou.wav
Replay=0,0
strTtsText=
Position=414,781
[JobOffers]
Type=Play
DispSize=69
PlayFile1=$RV[Lng_Choice]\Pause1_0.wav,JobOffers\$RV[Lng_Choice].wav,$RV[Lng_Choice]\Pause1_0.wav
Replay=0,0
strTtsText=
Position=37,681
[Evaluate_JO_YES]
Type=Evaluate
DispSize=69
Expression=$RV[Options]
ExprNewRV=
ExprStoreRV=0
on {1} gosub [X:\Register.vgs|EnterPhone]
on {2} gosub [Leave_Msg]
on {3} goto [JobOffers]
Position=36,568
[Evaluate_JO_NO]
Type=Evaluate
DispSize=69
ExprNewRV=
ExprStoreRV=0
Position=222,564
[Job_Offers]
Type=Run VB Script
DispSize=69
VbsFileToRun=
VbsWait=1
VbScript=set fso = CreateObject("Scripting.FileSystemObject")
fileV.close
sReturnValue = vg.RvGet($RV_LINEID, "$RV_Job_Offers")
set fso = Nothing
MsgBox sReturnValue
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set tsFile = fso.OpenTextFile("X:\VarJobOffers.txt", ForAppending, True)
tsFile.WriteLine "$RV_STARTTIME, $RV_CIDNUMBER, $RV[EnterClientNumber]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
VbsHoldPlay=
on {success} goto [Options]
Position=31,13
The script you posted is configured to start at module [Job_Offers], yet the trace shows that the script which was used when the call was answered started at module [Play 1]
So the trace is not from the same script which you posted... module [Play 1] does not even exit in the script which you posted...
Maybe you should check which script VoiceGuide is set up to use when an incoming call arrives...
it starts with Play1 ->then follows -> Job_Offers.
I don't understand what you mean.
Job_Offers(vbs script) does not have to start from the beginning or does it?
Posted trace shows:
so whatever script was ran it did not go on to module [Job_Offers] after module [Play 1]
And the posted script does not even have the module [Play1] in it...
