Caller Id Withheld
I am having trouble getting the IVG to identify when callerID is WITHHELD.
I can clearly see the details in the event trace log, but how do you create an expression when there is no value in the $RV_CIDNUMBER, not even a zero.
If the caller has withheld the number, I am looking to ask the caller to manually enter the number.
Below is the initial event logs showing the system acknowledging the number is withheld.
I have tried a number of expressions using $RV_CIDNUMBER without success.
Does anybody have any suggestions.
45716 6 tapie linedevstate 2048 0 0
45716 6 tapie callstate OFFERING 66051 0 4
45746 6 Lev_CallerID [,WITHHELD]
45756 6 tapie callinfo CALLEDID
45756 6 tapie callinfo ORIGIN
45756 6 tapie ring 0
51735 6 tapie ring 2
51735 6 Answer the call
You can use the Evaluate Expression module, and in the module have the expression:
"$RV_CIDNUMBER" = ""
The "True" path will be taken if $RV_CIDNUMBER is not set to anything, and the "False" path will be taken if $RV_CIDNUMBER contains some value.
You can also use $RV_CIDNAME, which in these cases should be set to "WITHHELD", so you can use the following expression:
"$RV_CIDNAME " = "WITHHELD"
And if the above is true then the "True" path will be taken...
