On/off Hook Works But No Sound/ Dialing
I have setup my dialogic d/41esc card . All dialogic test pass in UDD. The TAPI is installed as per your instuctions and so are the wave drivers, but try as I may, I cannot get the board to dial or play any file out. I will not even detect touch tones, I have tries everything. What am I missing. I am evaluating your product .
PLease reply , I have been trying for 3 days.
You can even email me ay copper1968@yahoo.com
I also forgot to mention that when I test it, I Never get any kind of error messase. The files all say the are playing and then they say DONE. , but I never hear anything.
Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is going wrong.
Here is the log:
<<This is from a dilling numbers test >>
074216.50 5 dial [6,7863578736,405050741,1,2359,MoTuWeThFrSaSu,,2,NONE,D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs,D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs,none,60,2,120,,none]
074216.62 0 dial callque update id=6 next call time 0405050942
074216.63 0 dial callque DB update returned
074216.64 5 dial found entry: tel[7863578736] ann[NONE] vgs[D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs] am[D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs]
074216.64 5 Dialing: 7863578736
074216.65 5 MakeCall => 66067
074216.65 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
074216.65 5 TapiCbTrigSet 66067 7002
074217.32 5 tapi Reply (LineEvReply) ok 66067 0
074217.32 5 TapiCbTrigClear
074217.32 5 linedevstate 2048 0 0
074217.33 5 callstate DIALTONE 65777 0 0
074217.34 5 callstate DIALING 65777 0 0
074217.35 5 callstate PROCEEDING 65777 0 0
074217.35 5 callinfo CALLEDID
074217.36 5 callinfo REASON
074217.36 5 Lev_CallerID [0001,]
074217.37 5 callinfo ORIGIN
074238.96 5 callstate CONNECTED 65777,1,0
074239.01 5 WorkingModeTAPI@Connected=
074239.06 5 WorkingModeScript@Connected=
074239.11 5 rv add [OutDial_RetriesLeft]{2}
074239.18 5 rv add [$RV_STARTTIME]{5/5/2004 7:42:39 AM}
074239.22 5 rv add [$RV_DEVICEID]{5}
074239.27 5 rv add [$RV_CIDNAME]{}
074239.32 5 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
074239.37 5 rv add [$RV_CALLEDNUMBER]{7863578736}
074239.42 0 dial callque delete id=6
074239.50 5 AddRVns [OutDial_Result]{Contacted_Human}
074239.54 5 Live person answered, starting D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs
074239.60 2 tr NewVgsVgm_Goto D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs,,,,,0
074239.65 5 rv add [scriptEnd_Time]{5/5/2004 7:42:39 AM}
074239.70 5 rv add [scriptEnd_Goto_Script]{D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs}
074239.75 5 rv add [scriptEnd_Goto_Module]{}
074239.81 5 rv add [scriptStart_Time]{5/5/2004 7:42:39 AM}
074239.86 0 Script Load D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs
074239.93 5 Loaded D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs into:2
074239.98 5 AddRVns [scriptsPath]{D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\}
074240.04 5 cl NewVgsVgm_RunModule module not found:
074240.09 2 tr NewVgsVgm_Goto 1
074240.14 2 tr NewVgsVgm_Goto 2
074240.22 5 TimeoutClear
074240.27 5 RVreplace start: [$RV[ValueFromOrigScript]]
074240.32 5 RVns none[OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{5/5/2004 7:42:39 AM}[scriptEnd_Goto_Script]{D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\MakeCall.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{5/5/2004 7:42:39 AM}[scriptsPath]{D:\Program Files\VoiceGuide\Scripts\more sample scripts\MakeCallAndPassParams\}
074240.38 5 RVreplace end: []
074240.43 5 [sayValueFromOrigScript] Say numbers: as Digits
074240.55 5 fn PlaySoundStartNumbers , , , Digits
074240.63 5 sVbsFunctionToUse=Digits
074240.87 5 Started SayNumber VBScript OK. (D:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs)
074240.96 2 tr NewVgsVgm_Goto end
074241.35 5 cl Play_Start
074241.40 5 ScriptEventCode 8001 iLineState=1600
074241.45 5 LsSayNbrPlay EV_PLAY_FINISHED
074241.51 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
074241.56 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
074251.54 5 Timer fired EV_TIMEOUT_HANGUP
074251.59 5 ScriptEventCode 9001 iLineState=1600
074251.64 5 LsSayNbrPlay EV_TIMEOUT_HANGUP
074251.69 5 rv add [Hangup Time]{5/5/2004 7:42:51 AM}
074251.74 5 Hanging up call...
074251.79 5 RecSoundStop ok
074251.85 5 PlaySoundStop err=0
074251.90 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
074251.95 5 fnHangupCall end
074252.01 5 linedevstate 2048 0 0
074252.06 5 callstate IDLE 65777 0 0
074252.10 5 WorkingMode@Idle=
074252.15 5 TimeoutClear
074252.22 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
074252.27 5 tapi Reply (LineEvReply) ok 66425 0
074253.22 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
074253.27 5 ScriptEventCode 9008 iLineState=900
074253.31 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
074253.36 5 ReinitTelephony due to IDLE
074253.43 5 tapic lineDeallocateCall(MainCall:65777) 0
074253.58 5 lineOpen(5)=>
074253.63 5 Waiting for a call...
074253.68 5 LineHandle=66408
074253.73 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
074256.79 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
074256.84 5 ScriptEventCode 9013 iLineState=900
<< no reponse from a inbound test. sits at "Waiting for call" >>
By the way. The line does go off hook , but after that nothing until it hangs up.
Remmember the UDD testeded all OK.
you can see from the script that the script is set to start at module [sayValueFromOrigScript].
That module is not set to play anything, and 10 seconds later after timing out awaiting user input the script hangs up.
...you probably need to have a better look your MakeCall.vgs script...
The script seems to have valid values.
I made some changes and tried to use the Dialer. this is the log print out
from the test:
[copy of trace which was same as previous trace posted removed]
As you can see it played the file, I simply got no dialling or audio. It did pick up the
line and hang up , but nothing else. what am I doing wrong ?. please help
Edited by SupportTeam
We can see from the trace that your script is set to start at module [sayValueFromOrigScript].
look at this line of the trace:
the line above shows that the module is not set to play anything...
Maybe you have incorrectly set [sayValueFromOrigScript] to be the starting module but you actually want your script to start at a different module?
(See menu Edit->Script Properties in the Script Designer.)
Well I made the changes but - depite the log. It never dials out. I use my extension to monitor the out going call sometimes. I Cal alway hear it go offhook but it never dils out, just dialtone after the click and then "the telco off hook message". It ignores them as well as the touch tones . Here is my new log. Still no sound or dialling out.
234401.51 5 dial [14,7863578736,405052343,1,2359,MoTuWeThFrSaSu,,2,NONE,D:\Program Files\VoiceGuide\Scripts\copper.vgs,D:\Program Files\VoiceGuide\Scripts\copper.vgs,none,60,2,120,,none]
234401.52 0 dial callque update id=14 next call time 0405060144
234401.53 0 dial callque DB update returned
234401.55 5 dial found entry: tel[7863578736] ann[NONE] vgs[D:\Program Files\VoiceGuide\Scripts\copper.vgs] am[D:\Program Files\VoiceGuide\Scripts\copper.vgs]
234401.58 5 Dialing: 7863578736
234401.59 5 MakeCall => 65911
234401.61 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
234401.63 5 TapiCbTrigSet 65911 7002
234402.20 5 tapi Reply (LineEvReply) ok 65911 0
234402.23 5 TapiCbTrigClear
234402.26 5 linedevstate 2048 0 0
234402.29 5 callstate DIALTONE 65877 0 0
234402.32 5 callstate DIALING 65877 0 0
234402.36 5 callstate PROCEEDING 65877 0 0
234402.38 5 callinfo CALLEDID
234402.43 5 callinfo REASON
234402.48 5 Lev_CallerID [0000,]
234402.52 5 callinfo ORIGIN
234420.80 5 callstate CONNECTED 65877,1,0
234420.85 5 WorkingModeTAPI@Connected=
234420.91 5 WorkingModeScript@Connected=
234420.95 5 rv add [OutDial_RetriesLeft]{2}
234421.00 5 rv add [$RV_STARTTIME]{5/5/2004 11:44:20 PM}
234421.05 5 rv add [$RV_DEVICEID]{5}
234421.09 5 rv add [$RV_CIDNAME]{}
234421.14 5 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
234421.19 5 rv add [$RV_CALLEDNUMBER]{7863578736}
234421.23 0 dial callque delete id=14
234421.30 5 AddRVns [OutDial_Result]{Contacted_Human}
234421.34 5 Live person answered, starting D:\Program Files\VoiceGuide\Scripts\copper.vgs
234421.39 2 tr NewVgsVgm_Goto D:\Program Files\VoiceGuide\Scripts\copper.vgs,,,,,0
234421.45 5 rv add [scriptEnd_Time]{5/5/2004 11:44:21 PM}
234421.48 5 rv add [scriptEnd_Goto_Script]{D:\Program Files\VoiceGuide\Scripts\copper.vgs}
234421.53 5 rv add [scriptEnd_Goto_Module]{}
234421.59 5 rv add [scriptStart_Time]{5/5/2004 11:44:21 PM}
234421.63 5 rv add [scriptStart_CalledFrom_Module]{Play 1}
234421.69 0 LoadedVgs_Find D:\Program Files\VoiceGuide\Scripts\copper.vgs at idx=3
234421.73 5 AddRVns [scriptsPath]{D:\Program Files\VoiceGuide\Scripts\}
234421.78 5 cl NewVgsVgm_RunModule module not found:
234421.84 2 tr NewVgsVgm_Goto 1
234421.88 2 tr NewVgsVgm_Goto 2
234421.95 5 TimeoutClear
234422.01 5 [Play 1] Playing
234422.05 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234422.13 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234422.19 5 TimeoutClear
234422.23 5 RunModule PLAY end
234422.28 2 tr NewVgsVgm_Goto end
234422.34 5 wa(463,49026800)
234422.38 5 callinfo MONITORMODES
234422.68 5 Play End line[5] (id=490268)
234422.72 5 ScriptEventCode 8001 iLineState=1100
234422.77 5 LsPlayMsg EV_PLAY_FINISHED
234422.81 5 TimeoutSet 3 EV_TIMEOUT_REPLAYMSG
234425.77 5 Timer fired EV_TIMEOUT_REPLAYMSG
234425.81 5 ScriptEventCode 9005 iLineState=1101
234425.86 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
234425.91 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234425.97 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234426.02 5 TimeoutClear
234426.06 5 wa(463,49411400)
234426.11 5 callinfo MONITORMODES
234426.50 5 Play End line[5] (id=494114)
234426.55 5 ScriptEventCode 8001 iLineState=1100
234426.60 5 LsPlayMsg EV_PLAY_FINISHED
234426.64 5 TimeoutSet 3 EV_TIMEOUT_REPLAYMSG
234429.61 5 Timer fired EV_TIMEOUT_REPLAYMSG
234429.66 5 ScriptEventCode 9005 iLineState=1101
234429.70 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
234429.74 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234429.81 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234429.86 5 TimeoutClear
234429.91 5 wa(463,49795900)
234429.95 5 callinfo MONITORMODES
234430.34 5 Play End line[5] (id=497959)
234430.39 5 ScriptEventCode 8001 iLineState=1100
234430.45 5 LsPlayMsg EV_PLAY_FINISHED
234430.51 5 TimeoutSet 3 EV_TIMEOUT_REPLAYMSG
234433.46 5 Timer fired EV_TIMEOUT_REPLAYMSG
234433.50 5 ScriptEventCode 9005 iLineState=1101
234433.55 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
234433.60 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234433.66 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234433.71 5 TimeoutClear
234433.77 5 wa(463,50181500)
234433.81 5 callinfo MONITORMODES
234434.20 5 Play End line[5] (id=501815)
234434.24 5 ScriptEventCode 8001 iLineState=1100
234434.30 5 LsPlayMsg EV_PLAY_FINISHED
234434.34 5 TimeoutSet 3 EV_TIMEOUT_REPLAYMSG
234437.30 5 Timer fired EV_TIMEOUT_REPLAYMSG
234437.34 5 ScriptEventCode 9005 iLineState=1101
234437.40 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
234437.45 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234437.51 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234437.55 5 TimeoutClear
234437.61 5 wa(463,50566000)
234437.66 5 callinfo MONITORMODES
234438.05 5 Play End line[5] (id=505660)
234438.10 5 ScriptEventCode 8001 iLineState=1100
234438.15 5 LsPlayMsg EV_PLAY_FINISHED
234438.19 5 TimeoutSet 3 EV_TIMEOUT_REPLAYMSG
234441.15 5 Timer fired EV_TIMEOUT_REPLAYMSG
234441.20 5 ScriptEventCode 9005 iLineState=1101
234441.24 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
234441.30 5 [Play 1] Playing (C:\WINDOWS\RINGOUT.WAV)
234441.35 5 PlaySoundStart ok [C:\WINDOWS\RINGOUT.WAV]
234441.41 5 TimeoutClear
234441.45 5 wa(463,50950600)
234441.50 5 callinfo MONITORMODES
234441.89 5 Play End line[5] (id=509506)
234441.95 5 ScriptEventCode 8001 iLineState=1100
234441.98 5 LsPlayMsg EV_PLAY_FINISHED
234442.03 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
234442.09 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
234442.67 5 callstate DISCONNECTED 65877,0,0
234442.72 5 ScriptEventCode 9250 iLineState=1101
234442.77 5 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
234442.81 5 rv add [Hangup Time]{5/5/2004 11:44:42 PM}
234442.87 5 Hanging up call...
234442.91 5 RecSoundStop ok
234442.97 5 PlaySoundStop err=0
234443.02 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
234443.09 5 fnHangupCall end
234443.15 5 linedevstate 2048 0 0
234443.20 5 callstate IDLE 65877 0 0
234443.24 5 WorkingMode@Idle=
234443.28 5 TimeoutClear
234443.34 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
234443.38 5 tapi Reply (LineEvReply) ok 65860 0
234444.34 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
234444.39 5 ScriptEventCode 9008 iLineState=900
234444.43 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
234444.48 5 ReinitTelephony due to IDLE
234444.55 5 tapic lineDeallocateCall(MainCall:65877) 0
234444.72 5 lineOpen(5)=>
234444.76 5 Waiting for a call...
234444.80 5 LineHandle=65843
234444.86 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
234447.91 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
234447.96 5 ScriptEventCode 9013 iLineState=900
Also, You never gave me a reason, why it never picks up incoming calls.
Trace shows the Dialogic card is dialing out. If after it dials out you pick up the handset attached to the same line and you cannot hear the RINGOUT.WAV file being played then I'd say you have a faulty card.
Have you tried to test the card with Dialogic's own TALKER32 application? (as per VG Help file's Dialogic installation guide)
I did try it with talker32 and had the same results. I am inclined to agree about the card being bad. However this would be the second bad used ( suppoesedly A-OK) board I have gotten with the identical problem. I tried first with a d/41d . I did not hear any digits dialling and althought the wav files for the d/41d are MuLaw, The dialing out should still take place., Am I correct ? . Is my luck that bad ?. I hope not. I just assumed I was doing something wrong. Well what do you think,?Both boards, from different used suppliers are bad? Should I try a third board.
Can you try using the Dialogic's 'Voice Horoscope' sample application?
If that does not work then it's definately something wrong with the board.
An if it does work that still does not explain why the board does not dial out - dialing out does not use the Wave drivers...
I had a similar problem after trying to apply service update 53, though then i started to wonder if my application was not working even before that.
long story short, i uninstalled everything, and re-installed one piece at a time. (ie. system software 5.1.1, service pack 1, feature pack, globalcall protocols, and service update 53). what appears to have done it was re-installing the globalcall protocols.
i think it may have been due to an aborted installation when i did my first install of service update 53 (i mistakenly tried to install from setup.exe in a zipped folder).
hope this helps someone!
