Acd Software Recomended
What is ACD software that you recomend to have a best integration with VG?
I'm using VG 5.2.1, Dialogic D4/PCI and Panasonic PBX's / Siemen Hicom 3000
Anton
Which ones are on your shortlist?
None! in the time being I'm on investigating my PBX wheter it's has a CTI Interface or not. If you have the name pls let me know, perhaps I can explore it's feture and integration possibility with my system
You should speak with the PBX supplier to see if they recommend any to be used with your Hicom 3000 PBX. Many medium-range and just about all upper-end PBXs offer built-in ACDs as an add-on option.
Of course as mentioned before - if the PBX has a CTI link then it's quite easy to set up your ACD using VoiceGuide - and you would get a much more flexible system that way they choosing to use PBXs built-in ACD.
