Caller Id Issue
Can you have a look at the lines that contain the callerID info and tell me if that is the way it is supposed to look.
I get no values for the caller ID in VG and am trying to troubleshoot.
Caller ID is definately functioning.
I am using an ESS ES56H-PI internal modem that seems to function really good in all other respects.
Any assistance is greatly appreciated.
Modem Log snippet with the personal details changed to protect the dopey. :-)
As you can see the NMBR is being received but on several lines. It isn't breaking it up by character either.
04-28-2004 13:33:08.647 - Command Echo
04-28-2004 13:33:08.647 - Recv: <cr><lf>OK<cr><lf>
04-28-2004 13:33:08.647 - Interpreted response: OK
04-28-2004 13:41:11.552 - Recv: <cr><lf>RING<cr><lf>
04-28-2004 13:41:11.552 - Interpreted response: Ring
04-28-2004 13:41:11.992 - Recv: <cr><lf>DATE=
04-28-2004 13:41:11.992 - Interpreted response: DATE
04-28-2004 13:41:11.992 - Recv: 0428<cr><lf>
04-28-2004 13:41:11.992 - Recv: TIME=<lf>
04-28-2004 13:41:12.033 - Recv: 1341
04-28-2004 13:41:12.033 - Unknown Response
04-28-2004 13:41:12.073 - Recv: <cr>
04-28-2004 13:41:12.073 - Unknown Response
04-28-2004 13:41:12.073 - Recv: <lf>NMBR=403
04-28-2004 13:41:12.113 - Recv: 9
04-28-2004 13:41:12.113 - Unknown Response
04-28-2004 13:41:12.113 - Recv: 9999
04-28-2004 13:41:12.153 - Recv: 9
04-28-2004 13:41:12.153 - Unknown Response
04-28-2004 13:41:12.153 - Recv: 9<cr><lf>NAME=K
04-28-2004 13:41:12.193 - Recv: e
04-28-2004 13:41:12.193 - Unknown Response
04-28-2004 13:41:12.193 - Recv: nXXX
04-28-2004 13:41:12.233 - Recv: X
04-28-2004 13:41:12.233 - Unknown Response
04-28-2004 13:41:12.233 - Recv: XX
04-28-2004 13:41:12.273 - Recv: X
04-28-2004 13:41:12.273 - Unknown Response
04-28-2004 13:41:12.273 - Recv: X<cr><lf>
04-28-2004 13:41:17.570 - Recv: <cr><lf>RING<cr><lf>
04-28-2004 13:41:17.570 - Interpreted response: Ring
04-28-2004 13:41:23.549 - Recv: <cr><lf>RING<cr><lf>
04-28-2004 13:41:23.549 - Interpreted response: Ring
04-28-2004 13:41:23.549 - Answering the call.
The trace looks OK. Guess that the modem driver is not correctly interpreting it though and not passing it on to VoiceGuide...
